Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 20
LiquidGINGERSENSE REV 1.0 (port.desireHD)
    Feb 2011
    Ed ecco a voi la ROM che un pò tutti aspettavano!!
    LiQuIdHD GINGERSENSE REV 1.0 (port.desireHd)
    La Rom è basata su 3 progetti uniti:
    -LeoGingerBread v0.9.7
    -CM7 RC2 2.3.3
    -[ROM] Android Revolution HD 3.3
    se ci saranno feddback positivi, si continuerà nello sviluppo :P
    Build from AOSP: Android 2.3.3 / GingerBread / GRH78
    Sim toolkit + Terminal
    A lot of languages
    Stock Launcher2
    busybox 1.18.0 (linked)
    Rooted (su + Superuser 2.3.6.1)
    LeoParts v8,that features
    Network: supports adhoc, added OpenVPN + TUN/TAP modules
    Old App2sd
    180 rotation
    Screen ON/OFF animations (both on by default)
    Clear notifications one-by-one by swiping (on by default)
    Custom number of recent apps (8 by default)
    Custom app by long pressing home
    App killer by long pressing back
    Quiet hours
    Disable or change Battery warning level
    GalaS power widget in status bar (and configurable)
    Custom hostname
    SIP not only over WiFi
    FileManager
    Overscroll effects
    FLAC support+lots of other codecs
    nano, bash, libncurses, htop etc.
    Battery percent on LockScreen
    Transparent notif. bar
    Album art on LockScreen
    ù
    BUG:
    camcorder, ma dovrei fixarla x il lancio
    nessun'altro, funziona tutto con ram libere con taskiller di 90/95 costanti in utilizzo,la sto testando da 2/3 giorni con giochi etc..
    I worked hard on this,so,if you like my work,please consider donating
    Credits:
    leonnib for his great ROM
    koudelka roggin and thepasto for their great work with CM7: DONATION KOUDELKA
    roggin for his latest sensors fixes,his great kernel and his help: DONATION roggin
    gnufabio for his help and sharing CM7 RC2 sources: DONATION gnufabio
    Cyanogen team for their great codebase
    The guys over XDA
    Donators
    All of you flash-maniacs that continue following my work
    Coming soon:http://tinyurl.com/LiquidSennseV0-1-zip
    A Breve On Line: http://tinyurl.com/LiquidSennseV0-1-zip
    Ultima modifica di selectro; 01-04-11 alle 16:36
    Aug 2010
    Ringraziato 93 volte in 84 Posts
    mi sa ke la provo! xò voglio finalmente avere una rom ginger su cui funziona la videocamera quindi come on!!!!! XD no scherzo sono contentissimo di questo lavoro! la testerò x bene e vi farò sapere ogni minimo particolare! spero ke vada tutto davvero!
    ps: da dove si scarica???
    Ultima modifica di danitkd; 01-04-11 alle 16:04
    Feb 2011
    10 minuti....
    Feb 2011
    prontaaaaaaaaaaaaaa!!!!!!!ecco il link nel primo POST!!!!
    Jun 2010
    Il bleuthoot funziona? X me è una cosa fondamentale!
    Inviato dal mio Liquid usando Androidiani App
    HTC DESIRE HD - [ROM MIUI ]
    Feb 2011
    funziona tutto perfettamente
    Jun 2010
    Bè se hai risolto anche il prob della rete che non si conetteva piú a internet dopo una chiamata che affliggeva la CM7 e le altre rom... sei un mito... :-)
  9. #8
    Jun 2010
    Ok.... :-) ci sono cascato.... :-)
  10. #9
    Jul 2010
    Oct 2010
    Vigliacchi...
    il cuore a simili notizie potrebbe cedere...
