[ROM][4.3.1] Chameleon OS - S3 Mini
    Androidiano L'avatar di JonnyDarko
    Sep 2013
    Ringraziato 51 volte in 29 Posts
    Release : 20131111
    Caratteristiche
    Launcher Features
    · Folder icon styles: stacked, grid, or carousel
    · Folder sorting: alphabetically, reverse alphabetically, or by usage
    · Icon scaling in app drawer and on homescreen
    · Home screen previews, rearrangable homescreens
    · Set default screen from previews layout
    · Add or remove homescreens from previews layout
    · Slide homescreens with a second finger while holding widgets and icons
    · Gestures: Pinch to show previews, spread to show launcher settings
    Theme Manager
    · Based on MIUI's theme engine
    · Mix and match different themes on the fly
    · Theme options: Icons, Status Bar, Boot animation, Font (requires reboot), Messaging, Framework, and Ringtones
    · Applies native ctz files, but also will apply MIUI mtz files, not all elements will theme properly with mtz packages
    · Animated boot animation preview
    · Boot animation resolution scaling
    Status Bar
    · Customizable toggles, compact or page view (or off)
    · Extended volume panel in page view toggles
    · Access status or navigation bars while in fullscreen apps by touching the edge of the screen
    Messaging
    · Reads custom notification tones from Contacts
    · Revised layout: Added messaging bubbles, removed avatar icons from conversation and put one in the action bar, quick shortcut for emojis
    Security
    · Manage installed apps' permissions
    ...and more!
    Altre immagini QUI
    Bug e Problemi
    • Rari ravvii del dispositivo (alcuni utenti invece non hanno nessun ravvio)
    Requisiti :
    - Root
    - Recovery modificata ClockWorkMod o Team Win Recovery Project (CWM o TWRP)
    Installazione tramite CWM (questa procedura formatta il dispositivo, quindi assicuratevi un backup di ciò che vi serve conservare):
    Download :
    Chameleon OS 0.8 [4.3.1]
    GAPPS
    Sep 2013
    - Bugs -
    1 - Low quality on Youtube video playback, I suppose it's just the multiple color conversions we had to do.
    2 - Low volume from speaker on incoming calls.
    - Changelog -
    -Fixed reboot options (j4fs and param from source) // Thanks Benz!
    - Fixed changing max cpu clock speed, min setting still doesn't persists.
    - Support flash toogle on status bar.
    - Building power hal from source.
    - Not mounting preload anymore to speed up boot.
    - Minor clean-up of ramdisk and multimedia patch.
    - Deleted some buggy soft audio stagefright blobs from STE.
    - Deleted conservative and userspace governors.
    - Added abyssplug governor.
    - Fixed CRT animattion (Thanks Robert!).
    - Screeshots are now performed by CPU, should be faster.
    - Clean up of spammer services and ril class.
    - Initial SELinux support (Unstable and WIP, do not report bugs with it enabled).
    - ChameleonOS Source Code Update
    - Fixed signal strength dipslaying right (bars in statusbar)
    - Built with latest Linaro toolchain 4.8 of October
    - Minor Updates
    - Sources Update
    Ultima modifica di JonnyDarko; 12-11-13 alle 19:02
    Senior Droid L'avatar di imax95
    Lipomo (CO)
    SAMSUNG GALAXY S5 GOLD EDITION
    Ringraziato 43 volte in 35 Posts
    Funziona su s3 mini NFC ( i8190N)??
    Smartphone: GALAXY S8 64GB
    Precendeti smartphone:- GALAXY S7 FLAT - GALAXY S6 FLAT - GALAXY S5 - GALAXY S4 - GALAXY S3 - GALAXY NEXT
    Un thank è sempre benvenuto
    PM per problemi consigli o altro
