Firefox OS
Ciao ragazzi, volevo iniziare questa discussione per farvi conoscere e provare questo nuovo sistema operativo. Vi allego il link del post di xda http://http://forum.xda-developers.c....php?t=1805282
General Info:
More information about Firefox OS (B2G) is available here and here. So... I saw this and couldn't resist having a little sneaky play around with it. This is NOT a daily driver. This is NOT stable. It's pre-alpha. If you want something to use as a phone, this isn't it. If you just want to use your phone as a phone, you need android rom.
With that aside, and with the clear understanding that while this won't brick your phone, it's nothing to do with me if it did for some reason, or likewise if your cat (or other cute pet) suffers a painful death as a result of flashing this. At your own risk, like everything else here on XDA-Developers!
So without further ado, WTF is this? Well, it's a project from Mozilla (the lovely people behind the Firefox browser). I won't go into details, suffice to say I suggest you read a lot over at their wiki - start off at https://wiki.mozilla.org/B2G and work your way through the pages.
Instruction:
fastboot flash userdata userdata.img Wenn you flash usersata, you lose all data from sdcard!
Flash firmware via recovery.
What works?
WiFi
DATA
3G
Boot
!!!! As yet unexplained reasons, if not flash userdata, the screen does not work.
Download
Code:
Build 2:
-Update code base
-Support flash firmware via recovery
-Increased performance
Build 1:
- Initial release
ciccuzzo
Qualcuno lo ha provato?
Io ho provato ma rimane su una schermata nera...non so se non c'è la bootscreen o non va proprio , ma io non ho pazienza xD
