Pagina 1 di 54 1231151 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 535
[ ROM ][JB] XenonHD
    Aosta
    HTC One
    Ringraziato 76 volte in 68 Posts
    Wink
    [ ROM ][JB] XenonHD
    Team Horizon presents XenonHD
    Base : Jelly Bean 4.1.2 JZO54K : FULL AOSP BASE FROM SOURCE.
    It's Rockstable,Blazing fast.
    and now Buttery Smooth too!
    Caratteristiche:
    JB 4.1.1 JRO03L
    Root
    Busybox
    Varie:
    Apex Launcher
    DSPManager (JB) added with all the binaries.
    Apollo Music player added and fixed for JB.
    Proper extended power menu.
    180 degree rotation enabled.
    Navigation bar button pressing speed quickened. (Galaxy Nexus only)
    Digital clock widget added.
    Scrolling cache improvements.
    Support for caller display name.
    Developer settings as shortcut option.
    Added XenonHD wallpapers.
    Louder output on speaker for Maguro and Toro.
    Added Galaxy4, PhaseBeam and Holo spiral wallapers.
    Wi-fi scan time to 100 to save battery.
    Performance, battery life and other misc tweaks.
    Init.d support with added tweaks and scripts.
    SuperSU application for root.
    File manager added. (Compiled with JB SDK 10 by me )
    GPS and Camera fixed.
    Reflective soft keys.
    Build.prop tweaks.
    Battery life tweaks.
    Some secret tweaks.
    Etc
    Allarme e orologio:
    Hide buttons completely in fullscreen to prevent burn in and give a cleaner look. (Galaxy Nexus)
    Frameworks:
    Fix restoring network mode preference on reboot.
    Telephony: Add DORMANT state to GSM data link activity
    Fix automatic timezone failing on some GSM networks
    Added missing Tuna ringtones.
    LegacyUSB: Add support for legacy USB implementations.
    Bootanimation: performance enhancements.
    Much more
    Team Horizon:
    Adam Holloway (@Adam80460) auf Twitter
    Iceandfire (@arhamjamal) auf Twitter
    Grazie a:
    AOSP
    Cyanogenmod
    Romanbb
    Peter Alfonso
    JDKoreclipse
    Download:
    ROM : Index of ./roms/
    KERNEL : https://www.dropbox.com/s/e02gbglb0p...Linaro-LOC.zip
    Gapps
    Goo.im Downloads - Browsing gapps-jb-20121012-4.1.2-JZO54K
    Screenshots
    https://plus.google.com/photos/10987...43882368512113
    [U]Link alla discussione su xda http://forum.xda-developers.com/show....php?t=1667418
    03.11.2012
    Added clickable actions for clock and date with option for custom apps too.
    Allow "Vibrate on Touch" behavior for Slide unlock. (Settings>Security)
    Option to make toggles hidable.
    Added setting to allow haptic feedback on toggle press.
    CircleBattery: Revamped charging animation.
    Fixed NavRing inflate.
    Fixed NFC Toggle not working if it was not ON at boot
    Fixed multiple haptic feedback while switching Toggles
    Fixed kill app on long pressing the back button.
    Fixed widget color.
    Boot info now shows more info in boot dialog.
    Etc
    Ultima modifica di 1993Simo1993; 03-11-12 alle 13:34
  2. I seguenti 2 Utenti hanno ringraziato 1993Simo1993 per il post:
    SuperQ (01-09-12)
    Aosta
    HTC One
    Ecco i miei risultati dell altro giorno con la versione 2.0 Screenshot_2012-05-29-22-53-26.jpgScreenshot_2012-05-29-22-53-32.jpg
  5. #3
    -Android*
    come va con la batteria?è meglio questa o la android revolution ?
  6. #4
    Aosta
    HTC One
    Quote Originariamente inviato da -Android* Visualizza il messaggio
    La revo non l ho provata ma con questa e leankernel 4 ore di schermo le fai tranquillamente..ed hai più personalizzazioni che la revo.. è molto simile alla cyano ma appunto a livello di batteria è molto meglio anche con il suo kernel di base non è male
  7. #5
    Ringraziato 10 volte in 8 Posts
    Scusami..le 4 ore di schermo con quali settaggi li fai?...CPU Max e Min...Voltaggi....Governor...e soprattutto la luminosità dello schermo a quanto l'hai impostata??...Grazie x le info!!
  8. #6
    Aosta
    HTC One
    Quote Originariamente inviato da 1carpediem0 Visualizza il messaggio
    Avevo la v2.0 con leankernel..CPU min 230mhz e max1350, undervolt ho settato aggressive con i leantweaks , governor interactive, luminosità automatica e navigazione con 3g ogni tanto,wifi, e 2g sempre acceso quando non navigavo
  9. #7
    Aosta
    HTC One
    Con i leantweaks avevo anche impostato tutti i tweaks disponibili tranne il fast charge usb
  10. #8
    Qualcuno che ha provato anche la slim? Meglio o peggio dal punto di vista dell' autonomia?
  11. #9
    Aosta
    HTC One
    Quote Originariamente inviato da Mifiort Visualizza il messaggio
    Mm la slim non l ho provata
  12. #10
    la uso da qualche settimana, dalla prima versione e la trovo ottima, velocissima e stabile, tweaks utili ma che non appesantiscono la rom e durata superiore alle altre aosp
