Utente del giorno: luigif65 con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 1 di 58 1231151 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 577
[ROM] FNV-AOSP 4.2 Xylon
    Senior Droid L'avatar di noviz
    Oct 2010
    Molise
    Pixel 6 pro ; oneplus 7 pro
    Ringraziato 271 volte in 207 Posts
    Simple FNV AOSP 4.2 (JOP40C)
    Hey guys, this is FNVAOSP. A Home grown community ROM raised by remicks and the team and it was offline couple months ago, so i did an upstream changes and build to revive it because i want it. Not say it's pure AOSP, but it's hooked with some couple of my taste of the features. It's rooted, deodexed and optimized the way you wanted. I've only built this for only three devices, Maguro, Toro and Mako. I'm sorry if i'm unable to support other devices
    Credits
    * ProjectFNV - A community started by remicks, Papa Pearce, knokfirst and many more.
    * Romanbb & TeamKang - The best unicorn porn you can get ( + Kitteh too)
    * SteveSpear - The Unicorn Butter was from him and it's in the WIP state still, dat butta is melting in your phone.
    * CM Team - The legend of all.
    * TeamVanir - They're are kings of speed.
    * kufikugel - SlimRoms Developer.
    * D4rKn3sSyS - His da best.
    and the others who have helped.
    DOWNLOAD
    XYLON 4.2.1 (da 020 4.2.2 ) Goo.im Downloads - Browsing maguro
    GAPPS 4.2.1 Goo.im Downloads - Downloading gapps-jb-20121212-signed.zip
    GAPPS 4.2.2 Goo.im Downloads - Downloading gapps-jb-20130301-signed.zip
    INSTALLAZIONE
    Eseguire il backup e ASSICURARSI di avere l'ultima versione di "TWRP" O "CWM"
    - WIPE CACHE e DALVIK CACHE
    - FLASH ROM
    - FLASH GAPPS
    - RIAVVIARE
    Immagini allegate
    Ultima modifica di noviz; 29-04-13 alle 08:43 - Motivo: aggiornamento rom
  2. I seguenti 6 Utenti hanno ringraziato noviz per il post:
    6manu6 (18-11-12),Beaxus (14-02-13),Frank_9.5 (28-11-12),LuCiolla90 (20-07-13),XxXlorenzoXxX (25-11-12)
    Oct 2010
    Molise
    GAPPS INVERTED 4.2.2 (25042013)
    inverted25042013.zip
    GAPPS INVERTED 4.2.2 ( no photosphere )
    black 4.2.2 no photosphere.zip
    Ultima modifica di noviz; 29-04-13 alle 08:50
  5. #3
    Senior Droid L'avatar di Bhelzebu
    Jun 2010
    Ringraziato 96 volte in 85 Posts
    Una guida per l'installazione partendo da custom rom 4.1.2?
  6. #4
    Oct 2010
    Molise
    Quote Originariamente inviato da Bhelzebu Visualizza il messaggio
    Se hai il cell. sbloccato con root e tutto basta mettere la rom e le gapps sulla sd ed installare normalmente, ti consiglio se hai la recovery cwm di installare la twrp seguendo la guida al link che ho postato sopra.
    In caso contrario devi prima sbloccare il cell. con il toolkit seguendo la guida posta in rilievo
  7. Il seguente Utente ha ringraziato noviz per il post:
    Bhelzebu (18-11-12)
  8. #5
    Androidiano VIP L'avatar di sedor
    Jul 2010
    varese
    Mate 7-Note Edge-Lg g watch R
    Ringraziato 90 volte in 82 Posts
    messa ieri la 1°versione,bella e veloce,nessun bug riscontrato.
    Stamattina ho messo l'aggiornamento e nessun problema.
    la batteria è scesa del 35%in meno di 2 ore,ma stavo rispristinando le app e flashando l'aggiornamento.aspetterò un paio di cicli e poi vedremo il dafarsi.ciao
  9. #6
    Senior Droid L'avatar di pablomoreno
    Ringraziato 108 volte in 101 Posts
    Io la provo da ieri: con l'ultima versione ora il volume é stato molto migliorato. Per il resto la trovo molto veloce.Ora la uso con l'Ak kernel
  10. #7
    Oct 2010
    Molise
    Quote Originariamente inviato da sedor Visualizza il messaggio
    Quote Originariamente inviato da pablomoreno Visualizza il messaggio
    Provate la con il franco kernel dal link che ho postato, fluida e per adesso buona la batteria
  11. #8
    Jul 2010
    varese
    Il francokernell lho messo.vediamo come si comporta.
    Inviato dal mio GT-N8000 con Tapatalk 2
  12. #9
    Giangiui
    Ragazzi, come si chiama l'icon pack del primo screen ?
  13. #10
    Oct 2010
    Molise
    Quote Originariamente inviato da miseusegau Visualizza il messaggio
    Ciao noviz....sono in download...fra un po ti dico le mie impressioni...
    in attesa della yakju....;-)
    Di certo non è come la vanir , cmq con il franco è fluida e anche la batteria sembra reagire bene come personalizzazioni confrontata alla vanir è eccellente
