Pagina 1 di 50 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 493
[ROM] [JB] Team EOS 3 * Jellybean * Le nightly - Maguro
    Androidiano VIP L'avatar di giannib
    Ostuni
    LG G4
    Ringraziato 116 volte in 104 Posts
    [ROM] [JB] Team EOS 4 * Jellybean 4.2.1 * Le nightly - Maguro
    Team EOS JB 4.2.1 Maguro NIGHTLIES
    Screenshot_2012-12-10-14-46-21.jpgScreenshot_2012-12-10-14-46-30.jpgScreenshot_2012-12-10-14-46-39.jpgScreenshot_2012-12-10-14-46-50.jpg
    EOS is an AOSP based rom. It is developed and maintained by Team EOS and is the culmination of our own in house development efforts.
    Team EOS 4 Nightly builds:Goo.im Downloads - Browsing maguro
    G-Apps Package: http://goo.im/gapps/gapps-jb-20121212-signed.zip
    Changelog : maguro Changes [Jenkins]
    Enabling voice search in google now
    Go into Settings
    Go to "Language & input"
    Scroll down to "Speech" and click on "Voice Search"
    Click on "Download offline speech recognition"
    Swipe Across to the "ALL" tab if needed
    Download your speech pack for your language
    Note Installazione
    Queste build sono state progettate per essere installate da recovery preferito (Solarnz R4C, Rogue, Clockwork)
    Fare un wipe completo se si proviene da ROM differente , altrimenti se solo update della stessa ROM o Versione Nightly del Team Eos . serve solo wipe dalvik cache
    Scaricare la ROM corretta e copiarla sulla SD
    Installazione ROM EOS
    1-Entrare in Recovery
    2-wipe data/factory reset
    3-wipe cache partition
    4-advanced>wipe Dalvik Cache
    5-mount/storage >format/system
    6-mount/storage >format/data
    7-mount/storage >format/cache
    8-install zip from sdcard
    9-chose zip from sdcard > rom.zip
    10-Install
    11-chose zip from sdcard > Gapps Google
    12-Install
    13-++++Go Back ++++
    14-reboot system now
    Cosi in maniera che all'avvio si ha già la schermata google per il login.. Una volta inseriti i dati , vengono automaticamente scaricate tutte le applicazioni avendo aderito e acconsentito al backup con account Google
    Caratteristiche: build 143
    * Based off of Clean Android 4.2.1 (JOP40D)
    * Theme Manager
    * T9 Dialer/Landscape/Dialpad Settings (CyanogenMod)
    * Power Menu
    * Customizable Status Bar:
    - Battery Icon style
    - Battery Icon in notification bar
    - Clock style
    - Clock Am/Pm style
    - setting color clock and battery
    * Customizable Navigation Bar:
    - setting color of navigation bar
    - mode selection softkeys
    * Performance Settings:
    - Processor Speed (change cpu governor and clock speed)
    * other EOS setting
    - setting wifi regulator domain
    - volume keys switch on rotation
    - EOS toggle setting
    - Quick Reply SMS (cm10)
    Immagini allegate
    Ultima modifica di giannib; 30-12-12 alle 14:33
  2. I seguenti 4 Utenti hanno ringraziato giannib per il post:
    Gynlemon (19-07-12),iltommi (20-07-12),Pakobis (21-07-12),SamueleCiprietti (19-01-13)
    LeEco Le Pro3 6/64GB
    Ringraziato 51 volte in 48 Posts
    Bene bene, sono ancora con ICS, aspettavo di vedere qualche bella custom rom prima di passare a JB.
    Se dovessi passare adesso forse proverei questa, ma sono indeciso anche con la black jelly bean.
    Non c'è nessun features list di questa rom però mi sembra abbia già qualche bella mod, tipo toggle, percentuale batterua ecc. giusto?
  5. #3
    Ostuni
    LG G4
    Quote Originariamente inviato da Kipe Visualizza il messaggio
    si ha batteria e toggle
    Ultima modifica di giannib; 10-08-12 alle 10:02
  6. #4
    Ostuni
    LG G4
    ultima build android JRO03L integrata
    Ultima modifica di giannib; 10-08-12 alle 10:03
  7. #5
    Mar 2011
    Ringraziato 42 volte in 38 Posts
    Quote Originariamente inviato da giannib Visualizza il messaggio
    Cavolo ma la fotocamera non e presente in questa ROM? O e solo la mia che ha quxlhe problema?
    Hai flashato le gapps del team eos?
    Flashata. Finalmente toggles e batteria percentuale in rom! Come fluidità e prestazione ormai grazie alla base JB sono sempre eccezionali.
    La fotocamera io ce l'ho. Secondo me il tuo problema giannib sono le gapps.
    Ultima modifica di ilbert; 15-07-12 alle 11:17
  8. #6
    Ringraziato 10 volte in 8 Posts
    I colori dello schermo sono quelli stock?...
  9. #7
    Mar 2011
    Quote Originariamente inviato da 1carpediem0 Visualizza il messaggio
    Si si, colori stock.
  10. #8
    Ostuni
    LG G4
    Quote Originariamente inviato da ilbert Visualizza il messaggio
    No non ho messo le loro gapps..le scarico subito grazie
  11. #9
    Ostuni
    LG G4
    Prime impressioni di questa ROM..
    -WiFi più potente e veloce all'aggancio..
    -volume più alto della stock
    -toggle e % batteria nelle impostazioni e direi splendidamente integrate nel menù a tendina
    -batteria più longeva(test più approfondito domani)
    -veloce e scattante senza alcun lag..
    Wow che lavoro che hanno fatto
    Ultima modifica di giannib; 16-07-12 alle 11:43
  12. #10
    Senior Droid L'avatar di iltommi
    Google Galaxy Nexus
    Ringraziato 65 volte in 60 Posts
    stasera la provo grazie per la dritta!
    Sent from a Galaxy far, far away
