Pagina 1 di 8 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 79
[ROM]CyberGR-MOD | tweaks++ | mods++
    Rovigo
    Nexus 4
    Ringraziato 73 volte in 59 Posts
    Thumbs up
    CyberGR-MOD rom for galaxy nexus
    FEATURES:
    Android version: Build and based on AOSP source 4.2.2 JDQ39 using latest Linaro toolchain.
    Kernel Base : AK Purity Kernel ver.023 Credits to Anarkia1976 (You can still flash what ever kernel you want.)
    Rooted & Busybox.
    Fully Deodexed.
    Latest SuperSU.
    Init.d tweaks support.
    Zipalign on boot.
    Zipaling all apps for better Ram usage.
    Build.prop - Cron - Sysctl Tweaks.
    3G and HSDPA Tweaks.
    Really Fast Reboot times.
    Stock JellyBean Galaxy Nexus Bootanimation + Nexus 7 included as bootanimation-alt.
    Full GPU HW accelaration.
    SD-Nand Card I/O Speedtweaks - EXT4 | Ram Tweaks
    Tweaks for improved battery life and responsiveness.
    Multi language.
    Exteded Power Menu and Reboot Options.
    CyberGR|MOD Control (based on ROM Control by AOKP.)
    ROM Tools (based on Rootbox Settings.)
    CM T9 Dialer.
    Default 4.2.2 Launcher and Latest Nova Launcher Included.
    Tethering enabled.
    Optimized .png images + zip aligned + cleaned up scripts.
    NavBar IME keys.
    Modified Deskclock with increasing volume from CM.
    Safe Headset Volume and Launch custom Music app when you plug your headset.
    Volume Rocker Wake & Volume Rocker Music Controls.
    Statusbar clock customization.
    Statusbar signal text.
    Custom battery styles.
    Expanded Desktop option.
    Hide NavBar or StatusBar options and quck settings tiles.
    CM File Mananger with File Mananger Theme engine.
    DSP Manager.
    CyberGR|MOD Wallpapers App. (Based on PA)
    Performance control. (TricksterMOD built in).
    T-Mobile Theme-engine support. (Themechooser)
    Xposed Framework and Per-App DPI Settings Support. (Thanks to Rovo89)
    Overall ROM DPI Changer.
    Modded Play Store ver.3.10.14 with multi DPI support.
    LED Notifications Settings. (AOKP)
    Trasparency on StatusBar and NavBar supported.
    NavBar Auto hide.
    Pie controls.(ParanoidAndroid)
    OTA updates app built in.
    AOKP Quick reply MMS.
    Themeable MMS.
    Vibrate on answer-Every 60 Seconds-Hangup-Call Waiting advanced settings in Phone App.
    Call Statistics with latest commits.
    Chronus clock app with possibility to set custom colors for time-date-alarm and weather.
    CRT ON/OFF animation option.
    Profiles.
    Lockscreen targets and shortcuts.
    AdFree app and Newest Host File (Ads.remove)- 95%+ of ads are now blocked.
    DeskClock with Flip and Shake Actions.
    Dev Tools Included.
    SimToolkit - STK working.
    Default working Sound Recorder app.
    Torch app.
    Google Earth included.
    ISTRUZIONI PER L'INSTALLAZIONE:
    1)Riavviare in recovery
    2)wipe data, cache, dalvik cache, format system
    3)installare ROM e GApps
    4)reboot
    5) enjoy
    link alla rom: http://goo.im/devs/CyberGRMOD/CyberG...308_signed.zip
    link alle GApps cyberGR: http://goo.im/devs/CyberGRMOD/CyberG...308-signed.zip
    link alla discussione su xda: Galaxy Nexus > [ROM][4.2.2 JDQ39] CyberGR MOD Gnex > XDA
    ALCUNI SCREENSHOOT:
    CREDITI:
    AOKP Team.
    CyanogenMOD Project.
    ParanoidAndroid.
    RootBox.
    Google Open Source Spirit.
    Anarkia1976 Kernel.
    Rovo89 for Xposed Framework.
    TricksterMOD Team.
    Nessuno si assume la responsabilità per flash errati!
    Per ora non sono disponibili screenshot, ne aggiungerò non appena avrò fatto qualche ciclo di ricarica!
    se sono stato utile un thanks fa sempre piacere
    Ultima modifica di 123andrea; 09-03-13 alle 02:42
  2. I seguenti 2 Utenti hanno ringraziato 123andrea per il post:
    Beaxus (01-03-13),kaos80 (02-03-13)
    Rovigo
    Nexus 4
    Changelogs
    ***Changelog Ver.1 Nemesis 20130227 Build :
    - Fixed some things up from previous testing builds.
    - Fixed pattern lock settings to be fully functional again.
    - Fixed clear all notification-quick settings and notification open icons not turning blue when pressed
    - Clear some code up, DPI per-app settings and Xposed framework as well Performance settings now are included under ROM Tools app in a nice way.
    - Added Development tools.
    - Updated Nova Launcher.
    - Fixed default Sound Recorder app and Voice Search.
    - Some under the hood tweaks for better responsiveness and battery improvements.
    ***Changelog Ver.2 Nemesis 20130308 Build :
    - Merged with Latest AOSP 4.2.2 sources.
    - Updated AK Purity Kernel to ver.30
    - Fixed LockScreen Target alignment.
    - Chronus Clock can be fully displayed even at stock 320DPI.
    - PIE improvements and attempt to fix invisible PIE problem after unlocking screen.
    - Added Disable FullScreen Keyboard when your typing in landscape mode option under ROM Tools.
    - Added Low Battery Warning, Lockscreen See through and Volume Key Cusror options Control under ROM Tools.
    - Softkeys and Screen Security options removed.
    - Fixed a problem with Face Unlock.
    - Fixed Contact share problem.
    - Fixed Profile Toggle.
    - Updated Toggle Icons.
    - Added QuickRecord Toggle.
    - Fixed LockScreen NavBar Trasparency.
    - Updated CyberGR|MOD GAPPS.
    - Removed Metrostation Icon Pack app.
    - Fixed some init.d and build.prop tweaks.
    - Updated SuperSU, Talkback, Google Music.
    - Automatically lock changes will stick but they will display 5 secs time.
    - Inproved GPS Lock Times.
    Ultima modifica di 123andrea; 09-03-13 alle 02:44
  5. #3
    Jul 2010
    Ringraziato 539 volte in 393 Posts
    Le notifiche ti arrivano in tempo reale? Oppure ti arrivano solo dopo qualche momento che hai acceso lo schermo o aperto l'applicazione?
    Ieri con la xenonhd nessun problema, oggi con questa le notifiche non sono in tempo reale (mentre lo sono per un nexus s sotto la stessa wifi, con xenonhd)
    Tapatalkeggiato
  6. #4
    Rovigo
    Nexus 4
    Quote Originariamente inviato da Pelide Visualizza il messaggio
    Tapatalkeggiato
    a me per il momento nessun tipo di problema..ma non ci ho fatto molto caso..cercherò di starci più attento e in caso farò sapere..
  7. Il seguente Utente ha ringraziato 123andrea per il post:
    Pelide (28-02-13)
  8. #5
    Jul 2010
    Quote Originariamente inviato da 123andrea Visualizza il messaggio
    Riprovo con wipe cache/dalvik e fix permission, riavvio il router e domani vedo come va...
    Sarebbe un peccato lasciare questa rom, per ora è davvero molto buona e con un numero impressionante di personalizzazioni
    Grazie per il feedback!
    Tapatalkeggiato
    EDIT 01/03
    Per ora confermati solo 2 bugs
    - Force close: Settings - Security - SMS message limit
    (same from Settings - ROM Tools - Screen security - SMS message limit)
    - Non si riesce a condividere un contatto (Open a contact, tap on the share icon, then I get a fc every time I try to send (whatsapp, box, gmail,...)
    in più ho segnalato queste piccolezze, vediamo cosa dicono
    CyberGR|MOD Control > navbar > longpress key 1 or 2 or 3 ---> Recents (GB Style) doesn't work
    CyberGR|MOD Control > navbar ---> I can assign "Power" to a key, but imho "Screen power off" could be better
    Alcuni screenshot
    Ultima modifica di Pelide; 01-03-13 alle 16:40
  9. #6
    Androidiano VIP L'avatar di Pakobis
    Taranto
    Nexus 5 - Tab Acer A500
    Ringraziato 153 volte in 117 Posts
    La migliore Rom che abbia mai provato sul mio GNEX.
    Reattiva, fluida e piena zeppa di personalizzazioni. Le Rom di Cyber le seguo da quando sviluppava sul Nexus S e quindi non ci ho pensato due volte a flasharla.
    @123andrea: alcuni screenshot sono stati postati al post n.40 sul thread ufficiale di xda
    Google LG Nexus 5 D821
    Nougat - 7.1.2 - Dark Rom
  10. Il seguente Utente ha ringraziato Pakobis per il post:
    123andrea (01-03-13)
  11. #7
    Rovigo
    Nexus 4
    Quote Originariamente inviato da Pakobis Visualizza il messaggio
    grazie per la segnalazione..aggiunti
  12. #8
    Jul 2010
    Galaxy s4 - Galaxy Nexus
    Iscritto. domani la provo. Ma è full4.2.2 mi pare di leggere?
  13. #9
    Rovigo
    Nexus 4
    Quote Originariamente inviato da ;3414095
    Per il momento nessuna rom dovrebbe essere full 4.2.2 dato che i sorgenti completi sono usciti oggi..però credo lo sarà presto..
  14. #10
    Senior Droid L'avatar di NexusSte91
    Ringraziato 88 volte in 81 Posts
    In queste ROM piene di personalizzazioni l'unica cosa che non sopporto è l'mms settings, lo trovo veramente una cavolata, ogni volta che si cambia tema so sfasano scritte colori ecc, qualcuno sa come rimuovere quell'impostazione?
    Se no ritorno alla Aokp 4 solo per quello
