Pagina 1 di 14 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 139
[ROM] Rasbeanjelly [Android 4.2+][Maguro]
    Senior Droid L'avatar di edwardeutsch
    Google Nexus 5
    Ringraziato 138 volte in 109 Posts
    THIS IS RASBEANJELLY FOR THE MAGURO
    ROM basata sulla versione 4.2.1 di ANDROID
    Fantastica ROM del grande rascarlo (XDA) che offre stabilità e velocità eccezionali assieme alle funzioni più utili per i nostri device android e alle personalizzazioni grafiche accattivanti e ben curate. Dopo aver provato molte ROM su base Jelly Bean 4.2.x posso dire che la rasbeanjelly è una delle migliori anche grazie alla disponibilità e serietà dello sviluppatore
    Stabile, veloce, dark style e battery friendly!
    Don't involve rasta in your say say...
    /// WHAT IS RASBEANJELLY
    back in the ics days, i started to build rascreamsandwich for me and for my friends Morfic and Simms22.
    they told me to share my builds in the trinity thread for the maguro, and so i did and still do.
    then i started to build also for crespo and toro.
    one day Morfic, a well-known very talented developer and an extremely nice person, bought a grouper for me as a gift. so i started to build for the grouper as well.
    unfortunately it never made it to my place, it was stolen at the customs of my country. but i keep developing for this nexus device, for Morfic and Simms22.
    so far, builds have always been posted in the trinity thread for the maguro, but as suggested by many users, it is time to open a separate thread. so here it is.
    ///WHAT DO YOU GET, CHANGELOG
    /// THANKS
    Morfic and Simms22 for being my friends and for being them.
    fitsnugly for euroskank
    brainmaster for his continous support in the crespo and grouper threads with his Boot.img with init.d support
    lichti1901 for his awesome mods for maguro and toro
    GideonX for his FAQ and his continous support
    Android Open Source Project
    CyanogenMod
    /// FLASH
    latest TWRP is higly recomended
    - full wipe if coming from a different rom, else skip this step
    - wipe cache
    - wipe dalvik cache
    - flash zip
    - flash gapps ( http://fitsnugly.euroskank.com/?rom=...y&device=gapps )
    - (opt.) flash kernel since it comes with stock (i would flash trinity)
    - reboot
    - log into google and let it sync
    - (opt.) push your busybox in the way you want or use Stericson BusyBox from the playstore (system/xbin is recomended)
    - fix_permissions (in terminal if your kernel supports the script, else in recovery)
    - (opt.) reboot
    /// DOWNLOAD LINK
    euroskank
    will be posted here, in the trinity thread for the maguro and on twitter (https://twitter.com/rascarlo)
    /// CHANGELOG & FEATURES
    Sempre disponibile il changelog e le nuove futures alla pegina del download
    /// SOURCE
    https://github.com/rascarlo
    Ultima modifica di edwardeutsch; 16-12-12 alle 13:18
    NEXUS 5 (32GB) / STOCK 4.4.2 (KOT49H) or PARANOIDANDROID 4.3 (BETA) / TWRP / SU
    IT'S A TRAAAP!
    Google Nexus 5
    Ultima modifica di edwardeutsch; 05-12-12 alle 13:37
    IT'S A TRAAAP!
    Senior Droid L'avatar di mcallister
    Ringraziato 47 volte in 43 Posts
    Che dite meglio questa o la xylon?
    DISPOSITIVI:
    ATTUALI:
    1.LG G2
    2.Asus Memo Pad FHD 10-stock
    3.Htc G1- CyanogenMod 7.2 and cwm recovery
    Jul 2010
    Galaxy s4 - Galaxy Nexus
    Niente riduzione navbar?
    Google Nexus 5
    Secondo me meglio questa! Ma sono due cose diverse...la xylon è molto più personalizzabile e questa si trova alle prime build, quindi lo sviluppatore ha deciso di trovare prima una stabilità massima per poi inserire mod varie...
    Ci sono dei thread su XDA per varie mod, status bar, navigation bar ecc.. Appena ho tempo metto il link al primo post!
    Tapatalk @ Rasbeanjelly (Maguro)
    Ultima modifica di edwardeutsch; 04-12-12 alle 02:08
    IT'S A TRAAAP!
    Senior Droid L'avatar di pablomoreno
    Ringraziato 108 volte in 101 Posts
    Ma quando installate la mod per i Quick toggle anche a voi diventano blu data e icona dei toggle? Inoltre scompare la possibilità di avere la percentuale batteria sulla barra superiore
    Google Nexus 5
    Aggiunti link a mod e temi al secondo post!
    EDIT: @pablomoreno no a me non capita! prova a reflashare a rom e poi la mod...con wipe cache e dalvik
    IT'S A TRAAAP!
  9. #8
    Quote Originariamente inviato da edwardeutsch Visualizza il messaggio
    Ho provato a riflashare la rom ed ho riavviato poi di nuovo recovery wipe cache e dalvik ed ho flashato la mod ma ancora ho il problema dell'evidenziazione blu. Peraltro ho provato ad installare quella stessa mod su di un'altra rom e tutto invece è stato installato correttamente. Potreste indicarmi passo passo la procedura da voi seguita per avere una corretta installazione?
  10. #9
    Google Nexus 5
    Quote Originariamente inviato da pablomoreno Visualizza il messaggio
    OK ho riprovato a installarla...ma nessun problema...puoi postare un paio di screenshot?
    Tapatalk @ Rasbeanjelly & FK
    IT'S A TRAAAP!
  11. #10
