Pagina 1 di 61 1231151 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 604
[ROM] JBSourcery Version Official Release
    Senior Droid L'avatar di pablomoreno
    Ringraziato 108 volte in 101 Posts
    Nuova rom su XDA basata su AOSP, questa la discussione su XDA:
    [ROM] JBSourcery V1.0 Official Maguro Edition [JB4.1.1][aosp][8/12/12] - xda-developers
    Attuale versione della Rom:
    JBSourcery 5.1 - New featuring JDQ39-4.2.2_r1
    Questa la pagina ufficiale del progetto da cui poter effettuare il download della rom e della gapps (ce ne sono 3 versioni,: standard, in parte in tema black, completamente black) :
    http://teamsourcery.com/phpBB3/viewt...hp?f=25&t=1127
    Queste le caratteristiche:
    codice:
    JBSourcery Change Log for 5.1
    Apollo Music App removed
    Pie improvements
    DashClock-Sourcerized
    DashClock-tools extension
    LTE connection reporting improvements.
    fixed fc in security settings
    New kernel-Based off BuckMarble Source
    all Binaries updated-
    wake lock issues fixed
    PGM Support
    App updates
    New gapps at release site
    Hopefully(fixed reboots :) )
    changes to allow koushes superuser to work-MarcLandis
    DeskClock improvements
    Blue tooth improvements(???) heard this one before
    Stability improvements and memory usage improvements
    note—
    Browser reverted to stock browser for this release
    MMS-theming options are removed.
    We will get you an alternative but due to requests
    from our themers to offer you what they mean too
    this has been removed.
    You may pull the one from inverted gapps if you wish.
    DO NOT PULL FROM 5.0 THAT ONE WAS BAD!!!
    JBSourcery 5.0 Change Log
    Based on Android 4.2.2
    New toggles -quick record
    ability for left -right quick pulldown and pull down toggles when no notifications
    CRT on/off aniomation control
    Camera-added software HDR –swipe to gallery (aosp does not have photosphere)
    phone-flip to dismiss or silent
    increasing alarm clock volumes-
    NavBar Hide — improvements
    Contacts-add call statistics improvements-
    Changed navbar and status bar transparency and color
    security settings redone with addition slide lock before secure lock-
    Back light curve adjustments
    Pie controls
    4.2.2 Kernal based off Buck Marbles work
    Tons of fixes from android github
    speed tweaks
    memory leak fixes
    Tools additions-
    search light-animated pulldowns.
    DashClock Widget included thanks to Roman Nurik
    Notification Widget-Lior Tamam
    SuperSU updated to 1.10-ChainFire
    JBSourcery 4.5 Change Log
    resized lock screen shorcuts
    new windows style recents option
    Total rehaul of lock screen wallpaper
    New toggles -power menu , screen off
    3g toggle for GSM(not sure it does anything)
    add light dark toggle background and color text change
    switch for screen to not turn on when plugging in
    NavBar Hide
    Bluetooth Map
    haptic feedback on longpres of searchlight
    Nfc tile fixes
    MMs message rate alerts-in security settings
    Deskclock-increasing alarm tone
    Improved lockscreen unlock time
    attempt to fix wallpaper reset without system ui reboot
    speed tweaks
    memory leak fixes
    many misc fixes from AOKP/CM
    Tools additions-
    Searchlight images-ability to change the small circle on lockscreen.
    And a Return of a Sourcery Exclusive feature to be announced after release.
    JBSourcery 4.3 Change Log
    1) PGM (REBUILT KERNEL)
    2) VOLUME WAKE RETURNS
    3) RETURNED ABILITY TO COLOR CUSTOM SOFTKEYS(SEE WE LISTEN)
    4) WIFI TETHER TOGGLE FIXED
    5) KEYBOARD OVERRIDING TEXT ITEMS
    6) ADDED ABILITY TO HAVE LOCKSCREEN WIDGETS EXPANDED (THUS BEING ABLE TO SEE ALL THE WEATHER AND CALENDAR STUFF ADDED WITHOUT PULLING DOWN)
    7) UPDATED LOCKCLOCK FROM CM(NEW ANALOG OPTION)
    JBSourcery 4.2 Change Log:
    Built From 4.2.1 Google source
    Bluetooth improvements
    Chronus Lock(Home) screen widget (wheather/calander)
    updated sourcerizer kernel
    Improved nav and status bar tranparency
    fixed FC with bluetooth toggle
    Nav Keys-only stock keys have change color ability Now
    If you need a key colored send the request to bug reporting
    and we will put in mods.
    status bar brightnes toggle on/off added
    navbar arrow keys when typing
    Led settings fixes
    rambar and recents improvements
    Multi user fixes
    SVDO(data while on phone) reinstated
    Touch by longpress of powerkey when screen off added(in powermenu)
    selectable text in gtalk
    ability to show menu when nav keys are off
    add hspa+ support
    Longpress navring returns
    many memory leak fixes
    Signal and phone enhancements
    Supplemental service notifictions
    national roaming added
    gps improvements
    Many other bug fixes.
    Core Features:
    Battery :
    MIUI Battery Bar, Battery Bar Location, Battery Bar Style (Icon only, Text only, Icon with text, Battery MOD’s (too many to choose),No Battery, Cm battery mods,change battery text color
    Clock Adjustments:
    Style (Right, Center, None), AM/PM, Days of Week, Color
    Custom adjusments of the pulldown clock.
    Toggle options:
    (AOKP Style)-User Contacts1,2,3, Brightness,settings,Wi-Fi,Signal,AutoRotate,Clock,GPS,IME,Battery,AirPlane mode, Bluetooth,Vibrate,Silent,Sync,Fast Charge,NFC,Wifi tether,USB tether, Torch,LTE,2G
    Lockscreen Features:
    Volume key unlock
    Volume key long press to skip tracks(screen off)
    battery percentage on lock screen
    Quick pin unlock
    Vibrate off on unlock
    Lock screen text color changing
    Lock screen targets (5)
    Landscape lockscreen capability
    Enable advanced volume control
    Ability to have upto 10 Lock screens
    ability to show all widgets on lock screen
    Navigation Bar:
    Small menu locations, Menu visibility
    Soft key color, Glow color and animation speeds
    Customizable soft keys with long press action and custom icons
    Navigation bar height(portrait),Width(landscape)
    Navigation Bar actions–home,back, recent, search, menus, toggle widgets, kill app,open ime switcher,Notification pulldown,Custom app,Blank,Power
    Navigation bar ring targets, navigation bar Soft Key colors, navigation bar key transparencies
    Ability to make soft keys go away , power menu what you see when long press power key
    upto Seven navbar keys
    NavBAR Widgets
    navbar and status bar color and transparency changes
    Miscellaneous Options:
    updated apex launcher
    improved tmobile theme engine abilities
    rebuilt kernel(full rom rom only-avaiable in kernels for update)
    turned down volumes for Maguro(user complaints of poor audio)
    ability to set custom navbar image from file explorers(fc on 4.0)
    rolled in update to fix back key rolling up pulldown.
    added adb icon hide
    added alarm icon hide
    multiuser support (default-2 users)-tools-buildprop editor to disable or add up to 4 users
    Disable boot animation
    Show Notification counts on status bar
    Extended volume panel
    Allow 180 degree rotation
    Show/hide IME switcher
    Custom carrier label
    LED Options include, Colors, Duration, Custom Apps, Flash when screen on, charging LED, Brightness
    Separate notification and ring tone volumes
    Phone -T-9 dialing,vibrate on answer, vibrate on call waiting, vibrate on hangup, vibrate every 45 sec, lock when call ends,
    Dialpad settings
    DSP manager /Music F/X
    Apollo music player
    Ability to set host name
    nfc polling
    Brightness control on status bar(turn off auto brightness and slide finger across status bar)
    Recent’s rambar
    vibration notification for expanded status bar
    more info during boot up – JBirdVegas
    POWERMENU OPTION:
    Torch,NavBar hide and controls,Screenshot,airplane hide, Power off, reboot-reboot,Recovery,Bootloader.
    MMS Options:
    mms themeing ability
    Emoji support with QUick emoji Support Templates, Gestures, Strip unicode, Time stamps, Vibrate adjustments, Ring tone choosing.
    Quick popup message (with ability to delete from popup),delete on popups
    JBSourcery Tools Settings:
    Animations- change transition animations
    Boot animations – change boot animations
    Fonts- change fonts
    Kernels – change kernels
    TricksterMOD
    Apps Manager- easily see info and remove any apps system or data.
    Extra Apps- easy installation of new apps, themed apps ect.
    Push Notifications(team sourcery ability to communicate straight to their users)
    ROM Updates -replaces normal updates for easy install of updates
    Theme Manager-ability to install themes from within the rom
    Softkey Mods-switch out softkeys
    Pull down mods–change pull downs
    Ability to switch out all framework or system ui images.
    The first boot animation switcher that also switches boot ani sounds.(not availalbe on JB yet)
    Battery Mods–install different battery colors and styles.
    Over clock settings-ability to change governors or speeds of kernel.
    Terminal Emulator
    MIUI Root Explorer (credit to apooonet from xda)
    T-Mobile Theme engine(tmobile, CyanogenMod, xoomdev,,AOKP,MarcLandis,maniac103)
    T-Mobile theme engine themes
    Build prop editor(JbirdVegas)
    Kernel tweaks
    Wireless adb
    Block ads
    Cache cleaner
    Fix permission
    LCD Density
    VM Heap
    WIFI scan interval
    Wipe battery stats
    Zip align apps
    Background switcher
    Modalità di installazione direttamente dalla pagina del team (in inglese ma comunque molto comprensibile):
    1) Download Rom and Gapps to your Phone’s Storage drive and boot into recovery
    2) Clear dalvik cache
    3) Wipe data/cache
    4) Install your Chosen Team Sourcery Rom
    5) Install Gapps
    6) Boot into Rom
    7) Sign in and wait for all market apps to Restore
    8) After market apps have restored Reboot again
    9) Enjoy
    10)Do Not use titanium to restore data for anything other than games.
    If you do this and have bugs reinstall without using titanium and if reproducable than please file a bug report.
    come si può constatare attualmente è la rom che offre il maggior numero di personalizzazioni.
    UTILITA':
    Recovery TWRP: https://www.androidiani.com/forum/mo...-recovery.html
    Recovery CWM: https://www.androidiani.com/forum/mo...-recovery.html
    Guida Sblocco manuale con comandi adb : https://www.androidiani.com/forum/mo...ry-images.html
    Guida Nexus Toolkit per Windows : https://www.androidiani.com/forum/mo...lash-mods.html
    Guida Toolkit per Mac: https://www.androidiani.com/forum/mo...ml#post2533983
    Flash Player: Dev-Host - - The Ultimate Free File Hosting / File Sharing Service
    [B]
    Ultima modifica di pablomoreno; 08-03-13 alle 22:05
  2. Il seguente Utente ha ringraziato pablomoreno per il post:
    Beaxus (04-02-13)
    milano
    Xperia Z3 Compact
    il market non mi fa scaricare nulla. mi da sempre errore. flashato e riflashato le gapps...niente..
  5. #3
    Aosta
    HTC One
    Ringraziato 76 volte in 68 Posts
    Quote Originariamente inviato da landroS2 Visualizza il messaggio
    Hai provato a cancellare i dati e poi a riavviare il cell ?
  6. #4
    milano
    Xperia Z3 Compact
    Risolto market ...personalizzazioni veramente tante...una cosa...nei varo tools...quando vado a modificare i colori..in realtà nn me lo modifica..cè qualche altra imppstazione da modificare o attivare per farsi che si realizzi la modifica dei colori?
  7. #5
    Senior Droid L'avatar di dado70
    Forlimpopoli (FC)
    GNex, Nexus 5, Nexus 5X, RN5..
    Ringraziato 73 volte in 65 Posts
    1 sacco di personalizzazioni e a batteria poi come và, ciuccia come 1 bevitore?
    ROM
    Recovery
    [TWRP]
    Kernel
    Launcher
  8. #6
    Senior Droid L'avatar di noviz
    Oct 2010
    Molise
    Pixel 6 pro ; oneplus 7 pro
    Ringraziato 271 volte in 207 Posts
    molto fluida tante personalizzazioni, unico problema riscontrato per ora è fc in apn settings
  9. #7
    milano
    Xperia Z3 Compact
    la fotocamera non ha lo slide di JB
  10. #8
    milano
    Xperia Z3 Compact
    porca puzzola non riesco a far andare il led notifica...ho disattivato light flow, messo le impostazioni che volevo da CONTROL CENTER..anche riavviato..nma niente..non notifica..
  11. #9
    Forlimpopoli (FC)
    Ciao raga..ho installato questa rom, cavolo è spaziale a personalizzazioni, però devo ancora vedere quanto beve di batteria..volevo chiedere come mai le icone del wifi e 3G rimangono grigie nonostante poi x esempio il browse funzioni lo stesso, come mai?
    ROM
    Recovery
    [TWRP]
    Kernel
    Launcher
  12. #10
    Aosta
    HTC One
    Uscita la 2.0
