Pagina 1 di 6 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 54
[ROM][KK 4.4.x][HALO][CM11] **crDroid AOSP**
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Ciao a tutti ,dopo il grandissimo lavoro di Elia che,colgo l'occasione per ringraziare per la splendida rom versione 4.3 che ci ha regalato,voglio presentarvi la versione di questa rom per android 4.4+ grazie a dev Cristiano Matos di XDA .La crDroid AOSP è basata sui sorgenti della cm11 con l' obbiettivo è di includere il maggior numero di features interessanti.Spero di essere all'altezza del grande Elia nel presentarla xD
    Features
    Halo;
    Screenshot quick trash;
    Power menu QS tile (simple press to go into power dialog or long press to go into reboot dialog);
    Power menu added in navring targets;
    Incoming call in bakground;
    Navigation bar dimensions;
    Enable or disable navigation bar;
    Low battery warning options;
    Lockscreen PIN keypad shuffler;
    Lock before unlock (Show sliders before secure unlock);
    Notification drawer custom background and transparency;
    Notifications row transparency;
    Custom clear all recents button (place it in any corner of the screen);
    RAM bar;
    Option to hide app's status bar notification icons;
    Status bar clock and date customization;
    Open source Google dialer;
    Volume panel configurable timeout;
    Screen recorder;
    Wakelock blocker;
    Media Scanner behavior on boot;
    Notification reminder;
    Notification reminder flip interval;
    Smart Pulldown;
    SlimRoms recent panel;
    Slim recent with option to show in left side and switch sizes (100, 85 and 70%);
    Slim recent add favorite mode (click on app icon in recent panel to choose as favorite);
    Ability to switch between recent panel styles (Stock or SlimRoms);
    Improved scrolling cache;
    Ability to Enable/Disable Smart Wake covers;
    Ability to disable hardware keys via nav bar settings (Only visible in devices with hardware keys and enable through overlay);
    Keyboard: toggle to enable/disable full screen on landscape;
    Keyboard: force auto rotation on IME;
    Keyboard: force to show always enter key;
    Live volume steps;
    Custom navbar recent long press (none, last app, screenshot, kill app, notifications panel, QS panel, power menu);
    Long press back to kill configurable timeout;
    People lookup settings;
    Option to enable notifications with screen on;
    SlimRoms Location tile with addition of labels for all states;
    Brightness slider in expanded notifications panel;
    Option to disable widgets frames on lockscreen;
    Lockscreen notifications;
    Telo Radio (Connection manager);
    Smart call;
    QS extended options (tiles per row - 3, 4 or 5 -- custom background color, custom text color, custom background pressed color, transparency);
    Gesture lockscreen;
    Pause, resume or stop downloads from notification area;
    DSP Manager: Center frequency param to bassboost;
    DSP Manager: Stereo widener effect;
    PA PEEK;
    Appbar by ChameleonOS;
    Launch floating window from notification (long click);
    Launch floating window from recents panel (long click);
    Option to enable/disable hepatic feedback on tiles pressing;
    Changelogs
    In seconda pagina
    Screenshots
    Installation
    wipe cache
    wipe dalvik cache
    format system
    flash rom
    flash gapps
    reboot
    enjoy
    Downloads
    Build 23 05/11/2014 )
    PA Gapps
    Credits
    • firebird11
      Cristiano Matos
      elia222
      CM Team
      Slim Roms Team
      ParanoidAndroid Team
      AOKP Team
      temasek
      Der_schubi
      E molti altri...
    LINK UFFICIALE XDA
    Community G+
    Ultima modifica di morfances; 11-11-14 alle 11:57
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  2. I seguenti 6 Utenti hanno ringraziato morfances per il post:
    19venom89 (14-01-14),asterixb (14-01-14),Cnoxs (14-01-14),dadenet (17-01-14),elia222 (24-01-14),fedelamb (14-01-14)
    Sep 2010
    ROMA
    Changelog
    Build 05-11-14
    - Synced with all CyanogenMod sources (build date);
    - HW keys enabled by default;
    - this is not a major update but on some devices HW keys where disabled;
    Non quotare grazie
    Ultima modifica di morfances; 11-11-14 alle 11:58
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  5. I seguenti 3 Utenti hanno ringraziato morfances per il post:
    Cnoxs (14-01-14),elia222 (24-01-14),fedelamb (14-01-14)
  6. #3
    Sep 2010
    ROMA
    Segue CHANGELOG
    OLD RELEASES
    Non quotare grazie
    Ultima modifica di morfances; 21-05-14 alle 16:02
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  7. #4
    Senior Droid L'avatar di dado70
    Forlimpopoli (FC)
    GNex, Nexus 5, Nexus 5X, RN5..
    Ringraziato 73 volte in 65 Posts
    Grandissimo lavoro di Elia222 e anche tuo che apri interessantissimi 3d...
    crDroid KK? -> Presente
    Leggo che per ora come personalizzazioni che mi interessano c'è solamente Halo ma penso che implementeranno anche il Pie....e comunque grazie alla presentazione della tua mitica app Exposed Framework posso già installarle...seguiamo seguiamo questa nuova rom...buon lavoro...
    ROM
    Recovery
    [TWRP]
    Kernel
    Launcher
  8. Il seguente Utente ha ringraziato dado70 per il post:
    morfances (14-01-14)
  9. #5
    Ciao a tutti, attualmente sul mio gnex ho la cm11 vorrei installare questa rom, perchè con la 4.3 mi trovavo molto bene,oltre ai wipe della cache e dalvik occorre necessariamente fare il format system o basta fare il wipe system?
  10. #6
    Sep 2010
    ROMA
    Quote Originariamente inviato da werewolfz Visualizza il messaggio
    Si ti conviene faro perche comunque è un'altra rom e cosi parti da un sistema piu pulito.
    Non si tratta di un aggiornamento della CM11.
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  11. Il seguente Utente ha ringraziato morfances per il post:
    werewolfz (16-01-14)
  12. #7
    ok grazie mille!!
  13. #8
    Sep 2010
    ROMA
    la mia crDroid completamente moddata con xposed
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  14. #9
    Ringraziato 44 volte in 29 Posts
    bè allora facci sapere come và....
    LG G2 Lineage 14.1 - root - TWRP //// S8
  15. #10
    Sep 2010
    ROMA
    bUILD 1.2 IS OUT!!
    Changelogs
    -added Active Display
    -latest crDroid updates
    -latest CyanogenMod updates
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
