Pagina 1 di 10 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 92
[KERNEL][[4.3.x/4.4.x] Franco Kernel
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Ciao a tutti ,senza nulla a togliere alla versione del medesimo kernel per la versione android 4.2.x, volevo qui parlare,anche per tenere divise le problematiche (se mai ce ne fossero) di questo fantastico KERNEL !!
    Parleremo quindi qui (mi raccomando agli OT) delle versioni r390 e successive valide per tutte le rom con android 4.3 .
    Al secondo post invece raccolgo quelle per android 4.4.x
    VERSIONI per ROM 4.3.x (PER 4.4.x secondo post)
    CHANGELOG
    r392:
    * Fix SU problems. If your SU was broken before flashing r392 you gotta re-install it regardless
    * Add the memory reclaim feature from mpokwsthsand boype (reclaims 50Mb from the YUV Tiler)
    * Add a proper touch boost implementation 100% on the Kernel side. It boosts the CPU to 1GHz on touch for at least 250ms = 0.25s. The PowerHal is disabled since this implementation works only from the Kernel side. Interacting with the device should be smoother
    r391:
    * Add fsync toggle back
    * Disable Smartreflex calibration which would cause some frequency steps to be overcalibrated wrongly and causing overheat
    * Enable modules support so Touch Control will work again
    * Properly set up Timer Slack
    * Merge some patches from Android gerrit with some fixes
    * Re-code Sound Control from scratch and now it will boost the hardware register directly and will boost accordingly. If you're using FKU (which has not yet been updated for this change) setting the Headphone boost to 0 disables the boost, setting it to 1 enables the boost. 2 and 3 values won't do anything at all. This approach will enhance the Volume and will prevent bugs like low volume on calls etc.
    r390:
    * Start fresh from 4.3 Kernel sources
    * Merge everything that was worth merging from all the previous work
    * Works on all roms, including CyanogenMod
    DOWNLOADS PER 4.3.x
    Versioni Nightlies
    INSTALLATION
    1)wipe cache
    2)wipe dalvik cache
    3)flash kernel
    4)reboot
    N.B.Per chi volesse aggiornare il franco kernel direttamente tramite app (io vi consiglio sempre il metodo manuale) potete acquistare dal Play Store franco.Kernel updater
    F.A.Q
    1. My device rebooted or crashed, how can I help?
    A: Get me /proc/last_kmsg on pastie.org.
    2. Battery sucks, my device is not entering deep sleep. FIX PLOX!
    A: Fix it yourself, it's an app waking your device up not the kernel's problem
    3. Signal is dropping since I flashed the kernel, amg u sucks!
    A: The kernel has nothing to do with gsm/cmda signal. Make sure you have the latest radios
    4. Do I need to wipe anything when flashing this kernel?
    A: No.
    5. Does this kernel has X or Y mod?
    A: Learn to read, everything you need to know is in the features list, changelog or public repo.
    Thread ufficiale XDA
    Ultima modifica di Zof; 14-05-14 alle 16:57
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  2. I seguenti 6 Utenti hanno ringraziato morfances per il post:
    Crotan (15-09-13),fedelamb (15-09-13),Fra8 (15-09-13),leonardodettoileo (11-10-13),satchmo (15-09-13)
    Sep 2010
    ROMA
    Ultima modifica di morfances; 17-09-14 alle 08:48
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  5. I seguenti 2 Utenti hanno ringraziato morfances per il post:
    fedelamb (15-09-13),skizzomsn (15-05-14)
  6. #3
    Sep 2010
    ROMA
    @zof mi aggiusti il titolo del thd : volevo mettere tutto in maiuscolo,grazie
    --cancella---
    Ultima modifica di morfances; 17-09-13 alle 13:52
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  7. #4
    Sep 2010
    ROMA
    grazie ..ma la prima pagina non si quota mai...xD
    --cancella--
    Ultima modifica di morfances; 17-09-13 alle 13:53
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  8. #5
    Androidiano L'avatar di Fra8
    Ringraziato 22 volte in 17 Posts
    Quote Originariamente inviato da morfances Visualizza il messaggio
    Sorry... mi sai dare info per la r391 su CM 10.2???
  9. #6
    Sep 2010
    ROMA
    Quote Originariamente inviato da Fra8 Visualizza il messaggio
    credo che puoi andare tranquillo..è un buon kernel.
    se vuoi altri pareri attendi qui le recensioni xD
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  10. #7
    Zof
    Zof non è in linea
    Androidiani Power User L'avatar di Zof
    Parma
    One Plus 3
    Ringraziato 891 volte in 595 Posts
    all done
    Senior Editor @ Androidiani.com -> Stefano
    Follow me on Twitter-> Stefano
    Follow me on Instagram-> Stefano
    Follow me on Spotify-> Stefano
  11. #8
    Sep 2010
    ROMA
    Quote Originariamente inviato da -Zof- Visualizza il messaggio
    all done
    adesso compare cosi [kernel][jb][4.3] FRANCO KERNEL e non come dovrebbe essere
    [KERNEL][JB][4.3]FRANCO KERNEL secondo al sintassi del forum
    grazie e scusa se ..rompo
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  12. #9
    Senior Droid L'avatar di NforceRaid
    Xiaomi Mi 9T - Mi 9T Pro
    Ringraziato 173 volte in 144 Posts
    Ciao, io ho la 391 ed ho fatto (per ora ) queste modifiche
    Freq. Max Cpu 1228 MHz (forse era così anche prima)
    Freq. Min. Cpu 192 MHz
    Freq. Min. quando lo schermo è Spento 192 MHz
    e Governor Interactive
    e devo dire che la mia impressione è che abbia guadagnato + o - un buon 20% di durata in più del Nexus, facendone lo stesso uso.
    Ci sono ovviamente altri parametri da modificare, ma non vorrei fare danni
    Ciao
  13. #10
    Androidiano L'avatar di Alexh2o
    Ragazzi ogni volta che apro qualche app pesante nova launcher si riavvia causando ovviamente vari lag... Ho letto che questo non accade con il fancy kernel ...c è qualche modo per implementarlo anche sul franco kernel?? Mi trovo grandiosamente ma ultimamente ho questo problema...
