Utente del mese: megthebest con ben 42 Thanks ricevuti nell'ultimo mese
Pagina 1 di 2 12 ultimoultimo
[ROM] [AOSP][LINARO] LIQUIDSMOOTH JellyBean [4.2.1] Beta 3.2 [mako] » Jan 25
    Google Nexus 4
    Ringraziato 40 volte in 36 Posts
    Ho notato che mancava un 3d sulla LiquidSmooth, cosi ho pensato di aprirne uno io stesso
    Features:
    -Comprehensive speed enhancements, including Linaro -O3
    -Customizable lockscreen buttons and sliders
    -Chronus clock widget
    -Customizable hardware and software keys
    -Transparent navbar and status bar
    -Customizable navbar ring
    -Navigation bar widgets
    -Customizable power menu
    -Notification power widget
    -Customizable quicksettings panel
    -Statusbar mods
    -Theme engine
    -Quiet hours
    -Volume rocker music controls
    -Full Rotation
    -Customizable battery and notification light
    Changelog:
    -Proper graphics overlay lag fix for D2 - CyanogenMod
    -Built with official Linaro toolchain - Nocoast
    -Added Bluetooth MAP support - CyanogenMod
    -updated MDP profile for all smdk4412 devices - Codeworx
    -Audio reverts to enable A2DP for D2!! *note* this breaks wired headset mic - Mastamoon
    -GPS Enhancements for d2 - CodeAurora
    -New Performance Settings - xoomdev
    -GooManager now included - goo.im team
    -Latest device tree updates including RIL data stability enhancements - liquid0624
    -USB OTG Added - brewcrewfoo
    -Removed accidental Nova Prime - liquid0624
    -Added Gtalk Copy Paste - Credit TeamBamf
    -Fixed mako ANYkernel support - nocoast
    -Fixed ramdisk issues - liquid0624
    -Added in depth linaro optimizations Inlcuding gcc 4.7, compiling the ROM in full -O3 etc - Steve Spear, Liquid0624, nocoast
    -Added i9300/n7100 Support back - nocoast
    -Fixed Nexus10 NavBar Bug - Steve Spear
    -Added absolute download paths to all downloads - JbirdVegas
    -An Insane number of system optimizations (really truly insane)
    -Fixed various boot issues with nexus devices - nocoast/liquid0624
    -Full goomanager functionality
    -And Much Much MORE!
    Screenshots:
    Download: Goo.im Downloads - Browsing mako
    GApps: Goo.im Downloads - Downloading gapps-jb-20121212-signed.zip
    Guida all'installazione:
    NECESSARIO: Bootloader sbloccato, permessi di root e recovery modificata.
    -Scaricare la ROM e le GApps
    -Copiare il tutto nel cellulare
    -Entrare in recovery
    IMPORTANTE: eseguire un backup!!
    -Factory reset, wipe cache e dalvik cache
    -installare la ROM e successivamente le GApps
    -Opzionale: installare kernel
    -Riavviare
    Link da XDA: [ROM] [AOSP][LINARO] LIQUIDSMOOTH JellyBean [4.2.1] Beta 3.2 [mako] » Jan 25 - xda-developers
    Impressioni personali:
    Rom molto bella e personalizzabile, unico difetto che non ha sfondi inoltre consiglio di accoppiarla col Trinity kernel, è l'unica ROM con sui sono riuscito a superare le 5 ore di schermo attivo in due giorni di autonomia. Inoltre c'è scritto che è stato aggiunto il supporto all'OTG, ma a me non funziona.
    NB: non ho sviluppato io questa ROM e non voglio prendermi i meriti, ho solo fatto copia e incolla da XDA. Nè io nè lo sviluppatore siamo responsabili di eventuali danni.
    Senior Droid L'avatar di SoxxoZ
    LG v30 H930
    Ringraziato 129 volte in 81 Posts
    Grande.. La sezione ha bisogno di vitalitá..
    Ovviamente come prima domanda ti faccio la piu classica: bug noti?
    Google Nexus 4
    Finora l'unico problema che ho trovato e che opera mobile crasha ogni tanto.. Ma è preinstallato il browser stock quindi nessun problema
    milano
    Xperia Z3 Compact
    con trinity abbassi clock?
    Google Nexus 4
    No lo lascio così com'è, ma abbasso il minimo da 1 GHz a 370 MHz.. Uso l underclock solo con batteria sotto il 20% se volete posto gli screenshot sulla batteria..
    LG v30 H930
    Quote Originariamente inviato da Grimvard Visualizza il messaggio
    Che dire.. sono sicuramente ben accetti..
    Ma le icone grigie bisogna tenerle per forza? XD
    Androidiano L'avatar di lore2710
    Livorno
    Galaxy S i9000, Nexus 4
    ma è normale che quando riesci ad installare tutto e appena si avvia la rom viene fuori la scritta "l'applicazione tastiera android si è bloccata in modo anomalo"?
    ho fatto tutti i vari wipe ed ho installato pure le gapps... ora provo a cambiare kernel e vedere se cambia qualcosa....
    EDIT: no non cambia nulla
    Ultima modifica di lore2710; 12-02-13 alle 11:12
  9. #8
    Google Nexus 4
    Una volta che la tastiera si chiude dopo non si riapre più?
    Le icone grigie intendi quelle negli screenshot? Io non ce l'ho xD
  10. #9
    Livorno
    no... quando riavvio il dispositivo ed entro nell'installazione iniziale, devo scrivere la password del wifi ma appena clicko nella parte apposita si apre la tastiera e viene fuori quel messaggio, e la tastiera si richiude.. al momento ho risolto installandomi la baked (ottima rom tra le altre cose)
  11. #10
    Google Nexus 4
    Ancora non l'ho provata e sto usando la liquid.. E mi sto trovando benissimo
