[ROM] [4.4.1] Vanir
http://img835.imageshack.us/img835/1372/4o3j.png
Join our G+!
https://plus.google.com/u/0/communit...3754160?tab=wX
Features:
-Halo 2.0
-Android 4.4
-PIE
-AppBar
-Freaking insane speed
-Custom toolchains, -O3, OptiPNG, bionic, krait, and dalvik performance commits, -fstrict-aliasing, custom CFLAGS, and MORE!
-A Vanir performance on/off toggle
-UI mode switcher
-Tablet statusbar split
-Compiled with GCC 4.8
-etc (But seriously, this frickin' thing is PACKED with features).
Information:
This is the OFFICIAL thread for Vanir Mako nightlies. And yes, they were crazy enough to allow me to become the official maintainer.
Will be compiled almost every night, and I will include a changelog straight from GitHub.
Nightlies:
DOWNLOD:
ROM:Download
Gapps:Download
SuperSU:Download
FLASH ROM:
1. Riavviare in recovery
2.wipe Data & cache
3.wipe Dalvik cache
4.wipe System
5.Flash zip Rom
6.Flash zip GApps
7.Flash ultima versione di SuperSU
8.Reboot system
(App) Vanir-AIO 2.0:
codice HTML:
This is a refined version of my original Vanir-AIO application.
Mentionable changes include:
* An entirely Holo UI
* Permission explanations
* Lag-free
* HALO))), my modified Performance Control, and a Build.prop editor has been included in this application
* Updates will be constant.
This is considerably better than the first iteration of the application, and it will only get better.
Libraries used:
'PagerSlidingTabStrip' by Andreas Stütz
and
'ckChangelog' by cketti
I did not develop the Build.prop editor, the HALO))) application, or the Modified Performance Control application. I have modified them all to work properly in my application, but that is about as far as it goes.
HALO))) was developed by 'ParanoidAndroid'
The original Performance Control application was developed by 'AOKP' .. I simply edited the UI to my liking
The Build.prop updater was developed by 'nathanpc' and is licensed under GPLv3
DOWNLOAD APP:
https://play.google.com/store/apps/d....vaniraio2paid
Version Free:
https://play.google.com/store/apps/d....vaniraio.FREE
Nessuno l'ha ancora provata?
Io la proverei volentieri. Ma non riesco a scaricarla :)
Inoltre l'app serve a qualcosa?
l'app non è indispensabile, serve per supportare economicamente lo sviluppatore e perlopiù può servire per avere il link diretto al download della rom o di addon vari.
