[ROM][CM11][KOT49H][HALO] Nexus 5 Experience - CM11 Based Version [R 2.7 - 08Jan]
		Ecco a voi una rom che sto provando da qualche giorno e la sto trovando molto buona.
CM11 - Rooted and Rooted LTE Enabled Versions
CM11 CAF Kernel or Stock Kernel from Google
FEATURES
COMPILATA DAI SORGENTI CM11 PER NEXUS 4
BOOTLOADER,RADIO E ROM FLASHABILI IN UN UNICO ZIP
BOOTLOADER MAKO30D DALLA FACTORY IMAGE
FULL NEXUS 5 EXPERIENCE FIN DAL PRIMO BOOT AVRETE IL GOOGLE LAUNCHER,GOOGLE DIALER,STOCK WALLPAPER
INCLUDE I WALLPAPER DEL NEXUS 5 SUONERIE LOOKSCREEN TRASPARENTE E APPS STOCK.
SEMPRE LE ULTIME GAPPS AGGIORNATE DA GOOGLE
ROM DEODEXED
OTTIMIZATE LE LIBRERIE DALVIK DAL MOTO X 4.4 RELEASE(DALVIK E BIONIC OTTIMIZZATI)
ART FUNZIONANTE CON OTTIMIZZAZIONE LIBRERIE AL PRIMO AVVIO
KERNEL STOCK E CM11 KERNEL(SCEGLI LA TUA VERSIONE)
POSSIBILITA' DI UTILIZZARE SWEEP2WAKE,SWEEP2SLEEP E DOUBLETAP2WAKE(FLASHABILI DALLA RECOVERY)
CALIBRAZIONE DEI COLORI CON LA VERSIONE CON IL KERNEL DELLA CM11
AUTO ZIPALIGN DI DATA/APP
SQLITE3 SCRIPT
BUSYBOX 1.21.1 CON IL SUPPORTO ALL' INIT.D
SUPERUSER INTEGRATO DALLA CM11 DIRETTAMENTE NELLE IMPOSTAZIONI
INTEGRATO PRIVACY GUARD NELLE IMPOSTAZIONI
BLACKLIST PER I MESSAGGI E LE CHIAMATE IN ENTRATA
THEME SUPPORT NELLA VERSIONE CON IL KERNEL DELLA CM11
HALO CON LA POSSIBILITA' DI ATTIVARLO DISATTIVARLO COMPLETAMENTE
AWESOME BEATS EFFETTI AUDIO
SUONO DI RICARICAMENU' AVANZATO DI RIAVVIO FUNZIONANTE CON DALVIK E ART
PULSANTE PER KILLARE LE APPS RECENTI
DESKTOP ESPANSO
PERSONALIZZAZIONI DEI PULSANTI DELLA BARRA DI NAVIGAZIONE E COLLEGAMENTI RAPIDI
PERSONALIZZAZIONE DEI PULSANTI VOLUME
POSSIBILITA' DI EDITARE GLI APN DI DEFAULT
ALCUNE BUONE COSE DALLA CM11
RELEASE 2.7
Kernel improvements on both versions (no more freezes when using Sweep2wake - report this)
Added a script to keep Root when a custom Kernel with init.d support is used.
Fix Camera FC
Latest HALO updates. Now just have an one way to disable it to avoid confusion. Enable or Disable it on Settings > HALO
Status Bar customizations
Latest CM11 commits (Many commits)
SE STAI INSTALLANDO QUESTA ROM PER LA PRIMA VOLTA O STAI PASSANDO DALLA VERSIONE CON KERNEL STOCK ALLA VERSIONE CON KERNEL DELLA CM11 EFFETTUA I WIPE SYSTEM, CACHE, DATA E DALVIK.SE PROVIENI DA UNA VERSIONE PRECEDENTE DELLA STESSA ROM NON WIPPARE NULLA E' NECESSARIO IL SOLO FLASH.
INFORMAZIONI.
LA ROM NON HA BISOGNO DI GAPPS SONO GIA' INCLUSE NELLA ROM.E' TUTTO FLASHABILE IN UN SOLO ZIP
TUTTE LE VERSIONI DI QUESTE ROM SONO GIA' ROOTATE QUINDI NON OCCORRONO ALTRE OPERAZIONI PER IL ROOT.
DOWNLOAD:
RELEASE 2.7 STABILE CON KERNEL STOCK QUI
RELEASE 2.7 STABILE CON CAF KERNEL QUI
PER ABILITARE IL DOUBLETAP2WAKE ETC ETC DA FLASHARE DOPO LA ROM
DOUBLETAP2WAKE QUI
DOUBLETAP2WAKE E SWEEP2SLEEP QUI
SWEEP2SLEEP QUI
L OPZIONE PER PASSARE DA DALVIK A ART SI TROVA IN FONDO NELLE IMPOSTAZIONI SVILUPPATORI, SE QUANDO PASSI AD ART COMPARE UN POP UP DI NOTIFICA DI ALLERTA IGNORALO IN QUANTO ART FUNZIONA PERFETTAMENTE.
ISTRZIONI PER IL FLASH
1 ASSICURATI DI AVERE L ULTIMA RECOVERY(CWM O TWRP CHE SIA)
2 ESEGUI UN NANDROID BACKUP
3 COPIA LA ROM ALL INTERNO DEL CELL
4 ESEGUI IL WIPE DATA WIPE CACHE WIPE CACHE PARTITION
5 FLASHA LA ROM CHE VUOI UTILIZZARE
6 REBOOT E CONFIGURA
NE' IO NE' ANDROIDIANI SIAMO RESPONSABILI DI MALFUNZIONAMENTI DEI VOSTRI TERMINALI.
