Pagina 1 di 6 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 59
[4.2.2] LIQUIDSMOOTH JellyBean RC1
    Feb 2011
    G-Next, G-Nexus
    [ROM][4.2.2][AOSP][LINARO] LIQUIDSMOOTH JellyBean RC1 [mako] » Feb 15
    Nessuno ne parla: la Liquidsmooth ha ripreso ad aggiornarsi. I futuri aggiornamenti saranno via ota con GOOManager.
    In questa versione ci si basa sulla 4.2.2: per me è la miglior rom...molto leggera e parca di batteria.
    Link Pagina ufficiale XDA: [ROM][4.2.2][AOSP][LINARO] LIQUIDSMOOTH JellyBean RC1 [mako] » Feb 15 - xda-developers
    Changelog:
    Code:
    Rom Changes
    About Liquid section under About Phone in settings (Credit itsmikeramsay & liquid0624)
    added touch key light timeout duration for d2 devices to display settings (Credit gmillz)
    removed goo manager from app drawer to settings “Updater” (Credit itsmikeramsay)
    Make clearer of SMS Security Limit and added 500 messages/15 min limit (Credit DvTonder)
    Added Nexus 7 3G (Tilapia) Support
    Added Samsung i9305 Support
    Wifi Tether/Mms added to Tilapia (Credit Paranoid-Android)
    Tweaked Auto brightness/Touch-to-Vibrate for Mako (Credit Paranoid-Android)
    Custom Carrier label, Lockscreen Custom text color & Widget settings (Credit AOKP)
    Settings menus for Statusbar, Battery/Clock, Lockscreen, Navbar, Quick-Settings (Credit
    SlimRoms)
    Flip to Mute/Dismiss call (Credit SlimRoms)
    Landscape in Call/Exit to home (Credit AOKP)
    Enable Stylus Gestures (Credit slimroms)
    CM updates & Misc Bugfixes (Credit CM)
    Base Package phone features (Credit CM)
    Array & String refactoring/Layout & Design change (Credit Liquid)
    Fixed image cache problems (Credit or150)
    Add option to switch between UMS and FTP Mode (Credit espenfjo)
    Made lockscreen targets multi user compatible (Credit Danesh)
    Fix app info long-press (Credit Danesh)
    Highlight quicksettings and notification clear button (Credit jt1134)
    Removed duplicated code in keyguard (Credit jruesga)
    Fade CM Widgets on Low-Profile mode (Credit ThiagoVinicis)
    Re-Implement magnetic targets (Credit Danesh)
    Changed profile selection to single-press action (Credit Sven-Dawitz)
    Camera add additional ISO Modes (Credit jt1134)
    LINKS
    rom: Goo.im Downloads - Browsing mako
    extras: Goo.im Downloads - Browsing extras
    gaaps: Goo.im Downloads - Downloading gapps-jb-20121212-signed.zip
    Problemi:
    Non trovo il link che funga della extras.
    C'è un problema su Goomanager: il telefono dà che è installato di default, ma non funge.
    Soluzioni?
    Google Nexus 4
    Ringraziato 40 volte in 36 Posts
    Ehm.. Avevo fatto io un post sulla liquid solo che non lo avevo aggiornato :P
    Anche io consiglio questa ROM.. è fantastica con ottima durata della batteria.. Per gli extra a me dice semplicemente che non è stata trovata la pagina..
    Inviato dal mio Nexus 4 con Tapatalk 2
    Androidiano VIP L'avatar di Aetos
    LGoogle Nexus 4
    Ringraziato 280 volte in 210 Posts
    Comunque è uscita l'RC2
    Feb 2011
    G-Next, G-Nexus
    Giusto ieri!
    Mi domando perché nessuno caghi questa rom privilegiando altre più carine ma con consumi stellari di batteria
    Senior Droid L'avatar di SoxxoZ
    LG v30 H930
    Ringraziato 129 volte in 81 Posts
    è uscita la versione STABLE..
    Non sopporto le ROM con nova già installato.. non è possibile toglierlo??
    Androidiano VIP L'avatar di Ares77
    GN4 + DHD
    Ringraziato 529 volte in 359 Posts
    Puoi sempre disinstallarlo e installare quello che preferisci
    Se se stanco delle solite trollate e vuoi fare davvero sul serio, vieni con noi nel MVR: MANICOMIO VANILLA ROOTBOX.http://www.androidiani.com/forum/off...l-delirio.html.
    Senior Droid L'avatar di mlucky
    Ringraziato 160 volte in 139 Posts
    Si possono flashare le gapps più aggiornate invece che quelle linkate nel post su xda?
  9. #8
    GN4 + DHD
    Quote Originariamente inviato da mlucky Visualizza il messaggio
    Io non credo che ci possano essere particolari controindicazioni....
  10. Il seguente Utente ha ringraziato Ares77 per il post:
    mlucky (16-03-13)
  11. #9
    LG v30 H930
    Quote Originariamente inviato da Ares77 Visualizza il messaggio
    è un applicazione di sistema, e non è possibile disattivarlo da li...
  12. #10
    Quote Originariamente inviato da SoxxoZ Visualizza il messaggio
    lo puoi eliminare manualmente, rimuovendolo da system\app (io uso root exporer, ad esempio)
