2 allegato(i)
[KERNEL] [22.11.2013] [KK4.4] [HAMMERHEAD] n3oHammer_v14 [CPUQUIET|S2W|DT2W|WIFI FIXE
banner by jonas2295
==[n3oHammer]==
codice:
FEATURES:
- USERSPACE VOLTAGE CONTROL
- FAST CHARGE
- CPUQUIET HOTPLUG
- KERNEL BASED THERMAL CONTROL
- SMARTMAX GOVERNOR FOR BALANCE BETWEEN BATTERY AND POWER
- XZ COMPRESSED
- SWEEP2WAKE
- DOUBLETAP2WAKE
USE TRICKSTER MOD FOR CONTROLING ALL FEATURES
HOWTO REPORT ERRORS -> THE RIGHT WAY
-) YOU need to provide me the following information, otherwise I´m not able to help:
-) On wich ROM you are
-) Wich Kernel and wich modules did you flash
-) ALWAYS provide a last_kmsg AND a logcat (you dont know how to do that ? Use google or search here in this forum, its posted nearly everywhere)
-) posts like "XYZ feature on ROM XYZ does not work" will be ignored (what should i do with that information ???)
CHANGELOG (old versions) & KERNEL FEATURES
codice:
Code:
n3oHammer_v1
-initial release
-backported earlysuspend
-fast charge
-voltage control
-stock freqs
-cpuquiet hotplug
n3oHammer_v2-v7
-internal testing
n3oHammer_v8
-added s2w, s2s, dt2w (thanks showp1984)
-added francos sound control
-removed mpdec so its off by default and should stay off
-new lowest freq: 96 MHz thanks showp1984
-OC upt to 2,53 GHz thanks showp1984
- slightly cooler colors, whites are more white (thanks franciscofranco)
n3oHammer_v9
- fixed flashing issue, everythings working now
n3oHammer_v9_fix
-fix Wifi
n3oHammer_v10
-ditch out mpdecision, u cant turn it on anymore so cpuquiet can do its job as it should
-should fix reboots
n3oHammer_v11
-hopefully fixed L1 cache error
-ditched out earlysuspend and keep in line with google
-better battery life
KERNEL Battery infos:
v11: s2w,dt2w disabled, cpuquiet load stats, smartmax governor, mobile data
lost 3 % in 7 hours. Think thats ok
Allegato 91573
Allegato 91575
HUGE THANKS TO @maxwen who always support and teaches me
Github
Link
Disclaimer
-) I am not responsible for bricked devices / Non sono responsabile per eventuali brick dei telefoni
-) If you flash this, your warranty will be void / Sappi che perderai la garanzia
CREDITS
MAXWEN: FOR ENDLESS SUPORT AND TEACHING STUFF
FRANCISCOFRANCO:mako_hotplug control
SHOWP1984: sweep2wake, doubletap2wake, and always be friendly guy that helps
XDA:DevDB Information
n3oHammer Kernel , a Kernel for the Google Nexus 5
Contributors
n3ocort3x, nimrodity, LorD ClockaN
Kernel Special Features:
Version Information
Status: Testing
Created 2013-11-13
Last Updated 2013-11-
LINK AL THREAD SU XDA FORUM
