1 allegato(i)
[ROM][LRX21T] FoxHound The Phantom Pain 1.3 [19 NOV] Lollipop | Clean | Black
http://www.foxhoundfile.com/Download.../FoxHound2.png
http://foxhoundrom.net/pagina/FEATURES.png
Based on last factory image
LRX21Q
Optimize based
Insert
5 soft key on navigation bar (power off,menù)
Pre-rooted
Black UI
Black Dialer
Black Contacts
Black Settings
Date control in settings
Traffic control in settings
Navigation bar option in dislpay settings
Insert GAPPS,no need to flash other external Zip
Insert BusyBox
Fix Google Play Services Errors
Update 1.3
Update to android-5.0.0_r6 (LRX21T)
update supersu to 2.23
Reboot, Airplane mode and Sound options in Power menu
Quick Settings panel pull down with one finger on Status bar extreme top right
Battery percentage in >Display > Status bar
Timeout and instant lock options in Swipe screen lock
SuperSU in Settings
New Bootanimation
Updated GAPPS
Black Hangout included
Insert Logo Rom in info device
Black Calendar Google
Filter spam notifications in Settings > Battery > Battery saver
Volume rocker wake up in Settings > Display
Wake up device if charger is plugged/unplugged in Settings > Display
Safe headset volume,Settings > Sound > Advanced options
Instruction:
1.Boot into recovery
2.Flash FoxHound zip
3.If root not work flash this
ZIP
4.Reboot and ejnoy!
http://foxhoundrom.net/pagina/DOWNLOAD.png
Link
Credit:
Djdarkknight96 black apps
Anderson Aragão base Rom
Chainfire for Root
OldDroid for IMG
flar2 Elemental X kernel
