midnighteight
Quale kernel mi consigliate di abbinarci ?? Sempre il blu_spark?
Grazie :)
si blue spark
A proposito uscito r118
https://forum.xda-developers.com/sho...postcount=9539
Oggi ho installato la rom e mi sembra fantastica. :D
Ho una domanda: in impostazioni Pure Nexus-Display-Luce di notifica non riesco a cambiare il colore del led di notifica per le singole app. E' un mio problema o è una funzione che deve essere ancora aggiunta??
Grazie mille! :)
midnighteight
Grazie mille! :)
Credo la seconda ipotesi
Inviato dal mio Nexus 5 utilizzando Tapatalk
morfances
Nuova build con tanti fix!!!
https://www.androidfilehost.com/?fid=745425885120708530
Updates Google+ Community BeansTown's Twitter Donate
02/15/17 Release Changelog
Update: update to latest february source android_7.1.1_r21
Update: update proprietary binaries for all supported devices
Update: update kernel source for all supported devices
Update: update Masquerade app to latest version
Added: initial translations for N have been merged
Change: expose back icon tint color for themers in contacts common
Change: expose adb N icon for themers
Change: expose quick settings tiles tint color for themers
Change: expose keyguard affordance circle background for themers
Change: expose bluetooth pin confirm dialog text colors for themers
Change: change numberpicker divider color to pixel blue
Change: do not disturb tile longpress when active to show detail view
Feature: add toggle to make bluetooth/data/wifi toggles east toggles
Feature: add incall vibration options compatible with google dialer
Feature: add option for immersive recent apps
Feature: add option to enable a recents kill all fab button and location
Feature: add option to enable/disable the quick setting battery icon syncing with statusbar
Fix: sideloading of apks with certain apps installed (one handed mode regression)
Fix: restore user brightness level after reboot with night light on
Fix: visual glitch in network traffic meter
La provo e vi faccio sapere
edit : sembra funzioni tutto
mod audio suggerita :
https://www.androidfilehost.com/?fid=817550096634746597
Con aroma scegliete quello che vi pare
Ho flashato supersu per il root e usato le open gapps
Il link della rom non funziona, come mai?
In questa ROM c'è il quick unlock??
paolobroker
Inviato dal mio Nexus 5 usando
dovrebbe essere questo : https://www.androidfilehost.com/?fid=529152257862703723
morfances
Questa è la precedente che sto usando, va beh speriamo!
Al momento monto una rom basata su Android 6 (la Mark) ma ultimamente lagga di brutto quindi ho intenzione di formattare tutto e flashare questa rom. Ho visto che ci sono vari "add-on" come pixel launcher o la mod audio, vale la pena installarli? Ciò che mi interessa principalemnte è la fluidità quindi non vorrei appesantire troppo.
In qualsiasi caso la procedura sarebbe: formatto, flash bootloader e radio, flash rom, gapps e kernel (ho visto che consigliate il blue sparks) e eventualmente a seguire pixel launcher e mod audio. Giuso?
TK3
Tutto corretto ,ma se ti piace la PureNexus ti consiglio di vedere anche la AOSP Extended
Quanto alla mod audio...io sono fanatico la metto sempre
Pixel lAuncher se ti piace..altrimenti usa il tuo launcher preferito
morfances
Ok garzie mille, scusa l'OT ma tra a pure e l'aosp quale è più fluida?
