Visualizzazione dei risultati da 1 a 10 su 42
[RECOVERY] TWRP per Nexus 7
    Androidiano VIP L'avatar di lebrac
    LG P990, Nexus 7
    Ringraziato 782 volte in 578 Posts
    TWRP Touch recovery per Nexus 7
    TWRP è una recovery interamente touch, disponibile per molti dispositivi tra cui il nostro Nexus 7.
    Ha un interfaccia semplice e veloce, è anche possibile applicare dei temi.
    SCREENSHOT
    DOWNLOAD E INSTALLAZIONE
    Niente adb, toolkit o altro, è semplicissimo!
    - Scaricare dal Play Store GooManager https://play.google.com/store/apps/d...0up.goomanager
    - Concedergli i permessi di root al primo avvio
    - Da Goomanger - Menu - Install openrecovery
    CHANGELOG
    -Add screen timeout - screen will turn off automatically after 60 seconds, saves battery and prevents screen burn-in especially on AMOLED devices
    -Add a brightness setting (requires device specific setup and only some devices have been added)
    -Add a root checker and offer to install SuperSU if the device isn't already rooted
    -Add a write buffer to libtar backups, significant improvements to speeds when backing up to exFAT target, minor improvements for other file systems
    -Check and offer to fix root permissions if broken
    -Add an option for a 24 hour clock display instead of AM/PM (aka military time)
    -Move stock recovery reflash check to occur during the reboot cycle
    -Add support for some MTK6xxx devices
    -Change libtar to vfork to help prevent memory problems
    -Add a "clicked" effect to most buttons, file selector, and listbox
    -Improve timezone listbox to be more like file selector (per pixel kinetic scrolling, etc)
    -Remove some no longer used settings (Forced MD5 sum on zips, size checking on image backups)
    -Other minor bugfixes and improvements
    Fonte XDA
    Ultima modifica di lebrac; 20-04-13 alle 21:27
  2. I seguenti 2 Utenti hanno ringraziato lebrac per il post:
    mene82 (03-03-13),Wallace75 (06-03-13)
    Genova
    Xiaomi Redmi 4X, MI A2 Lite
    Ringraziato 2 volte in 1 Post
    AIUTO!!!
    Installato GooManager e selezionata installazione TWRP da programma.
    Download effettuato e appare scritta di aggiormamento effettuato.
    Dopo un po' spengo il Nexus 7, ma non si avvia più.!!!
    Non prende la carica da caricatore su presa di rete e se lo collego al PC prima mi dice driver ABX ( o simile, ma non ADB) non installato. La seconda volta se avvio con up-down + power mi dice Unknown Device!
    Qualche idea per favore...son semidefunto...
    EDIT: dopo 4 o 5 tentativi di riavvio, tenendo premuti i tasti per molti (veramente) secondi...ora funziona come prima e la TWRP è installata e funziona...
    MISTERI dei dispositivi elettronici!?!?!?!?
    ANCORA NON TUTTO RISOLTO...
    Se cerco di avviare da Recovery con UP+Down e power, non succede niente. E se dopo provo ad avviare normalmente devo tenere premuto Power per più di 10 secondi, altrimenti non si accende.
    Se chiedo reboot da GooManager mi avvia la TWRP....che sembra funzionare.
    Sbaglio qualcosa ad avviare la Recovery da spento o c'è qualche problema noto?
    Grazie 1000
  5. #3
    LG P990, Nexus 7
    Allora, innanzitutto, fai uno spegnimento e accensione normali, poi spegni di nuovo. Per avviare in recovery da spento devi fare cosi: PRIMA tieni premuto il tasto vol- e POI tieni premuto il tadto accensione, dopo 3 secondi circa, compare il logo google e subito dopo il bootloader. Usando i tasti volume ti sposti su "recovery mode" e premi il tasto accensione per confermare. Nel giro di 5 secondi da spento sarai in recovery, è più lungo a dirsi che a farsi.
    Io uso rom custom che hanno il reboot recovery direttamente nel menu dello spegnimento.
    Ultima modifica di lebrac; 10-03-13 alle 00:45
    GUIDE UTILI:
    - MULTIROM NEXUS 7
    - GUIDA AL WUG'S TOOLKIT
    - GUIDA WIPE/FORMAT
    NON FACCIO SUPPORTO VIA PM, POSTATE NEI THREAD.
  6. Il seguente Utente ha ringraziato lebrac per il post:
    sinthemau (10-03-13)
  7. #4
    Androidiano VIP L'avatar di stefan95
    Nexus 4, Nexus 7, S4, LG G2
    Ringraziato 156 volte in 141 Posts
    Forse perché per andare nel bootloader effettivamente non c'é bisogno del Volume Su
  8. Il seguente Utente ha ringraziato stefan95 per il post:
  9. #5
    LG P990, Nexus 7
    Quote Originariamente inviato da stefan95 Visualizza il messaggio
    Ma infatti...non so dove avevo letto il contrario...mah, comunque uso sempre le scorciatoie dal menu di spegnimento, o dalla recovery, praticamente non lo spengo mai il nexus XD
    Inviato dal mio Nexus 7 con Tapatalk HD
    GUIDE UTILI:
    - MULTIROM NEXUS 7
    - GUIDA WIPE/FORMAT
  10. #6
    Genova
    Grazie a tutti!!! Che gnocco che sono... C'era un + di troppo, Per fortuna che esistono i Forum.
    Buon domenica a tutti!
  11. #7
    XD e io che mi stavo chiedendo, ma non é che col vol SU vai direttamente in recovery? HAahhahaha
  12. #8
    Jul 2010
    Io ho una domanda, ho letto da qualche parte che con questa recovery quando fai un "full wipe" ti cancella tutti i dati che hai nella memoria principale è vero? Perché essendo abituato con la "cwm" che comunque dopo i "full wipe" ti lascia i dati.. (titanium, zip vari da flashare, musica foto ecc....) con questa twrp non saprei come fare... Voi come fate? :what:
    Inviato dal mio Nexus 7 con Tapatalk 2
  13. #9
    Androidiani Power User L'avatar di iGuich
    Cattolica
    Ringraziato 2,998 volte in 2,007 Posts
    Quote Originariamente inviato da led zeppelin Visualizza il messaggio
    Non è assolutamente vero...
    A meno che non fai il wipe relativo alla memoria...
  14. #10
    Jul 2010
    Quote Originariamente inviato da Guich Visualizza il messaggio
    Grazie ok meno male allora la installo tranquillo, (qual'è il wipe in questione?) visto che con la "cwm" penso che non c'era.
