New boot animation
Su Xda (fonte inesauribile di materiale *.*) ho trovato questi Boot animation 480x800, quindi anche per il nostro NX.
AndroidGlow1
https://dl.dropbox.com/u/19412696/AndroidGlow1.gif
http://api.viglink.com/api/click?for...13268325674101
AndroidGlow2
https://dl.dropbox.com/u/19412696/AndroidGlow2.gif
http://api.viglink.com/api/click?for...13268325918572
AndroidMinimal1
https://dl.dropbox.com/u/19412696/AndroidMinimal1.gif
http://api.viglink.com/api/click?for...13268326913343
AndroidParticles1 (Green)
https://dl.dropbox.com/u/19412696/AndroidParticles1.gif
http://api.viglink.com/api/click?for...13268327592464
AndroidParticles1 (Blu)
http://www.inkreel.com/xda/preview-blue.gif
(Questo dell'immagine non è ris. 480x800 ma il file si ;) )
http://api.viglink.com/api/click?for...13268327870115
AndroidParticles2
https://dl.dropbox.com/u/19412696/AndroidParticles2.gif
http://api.viglink.com/api/click?for...13268380653161
l' AndroidParticles1 (Blu) è bellissimo *.*
installazione:
ADB
ADB
- Install the android SDK
- Open Command Prompt
- Locate the SDK tools folder where ADB is located (example: <cd c:\android-sdk-windows\tools>)
- Now enter the following code in Command Prompt
adb remount
adb push c:\temp\480x800_AndroidGlow1.zip /data/local/bootanimation.zip
adb reboot
TERMINALE
- Connect your phone to your computer via USB
- Copy the downloaded file to your sdcard
- Disconnect phone from computer
- Open Terminal Emulator on your phone and enter the code below:
su
cp /sdcard/480x800_AndroidGlow1.zip /data/local/bootanimation.zip
reboot
ROOT EXPLORER (procedura che ho seguito io)
- Rename the downloaded file to 'bootanimation.zip' and copy to your sdcard
- Open 'Root Explorer'
- Copy/Paste the /sdcard/bootanimation.zip to /data/local/ (make sure it's read/write)
- Reboot
Cadi0 mi hai preceduto di poco, stavo per postare una domanda sui boot. Io ho quello blu di cyanogen, mi piace un sacco, ed era il più bello tra quelli flashabili direttamente da recovery.
Avevo trovato dei boot davvero belli con un android che ballava, un altro intitolato android vs apple. Li ho scaricati ma non sono flashabili. Contengono un file "bootanimation.zip" da sostituire in system/media. Quando apro questo file però, ho 2 cartelle: una "480x800" e l'altra "Mac OS". I file dentro sono gli stessi. Devo flasharla così per intero o mettere solo quella 480x800?
foxmolder
No, il file non lo devi aprire ;)
Mi linki il download? :D
Allora: l'android che balla da solo non mi ricordo dove l'ho preso. Ho caricato il file su mediafire, aprilo e vedi se secondo te può andare bene o creare problemi. Questo è il LINK.
Android vs apple è molto divertente. Ho provato la versione flashabile ma non completa l'installazione perché c'è qualcosa di vecchio in quel file non compatibile con android 1.5 o superiore (almeno questo ho capito). Il link è QUESTO. (c'è anche la versione non flashabile)
L'ultimo che ho visto è un android che balla da solo, con la scritta android e quant'altro. Non ricordo dove l'ho preso, una sera ho girato più di 50 pagine internet in cerca di boots. Comunque questo è il video youtube e se ti piace ho caricato anche questo su mediafire. Mi piacciono tutti e 3 ma ancora non ho avuto coraggio di sostituire la cartella bootanimation rotfl
foxmolder
LINK.
La risoluzione è ok ;)
Il file zip (senza cambiargli nome) lo devi mettere in quella cartella system, oppure in data/local
il discorso bootanimation è sempre divertente :)...se ritrovo la cartella con tutti i file (compresi i gif di preview) faccio l'upload ;)...erano bellissimi quelli dei transformer, dei trailer dei film o dei video divertenti di youtube :D
Se vi capita provate Boot animation changer lite (free sul market) ;)
Anche questi sono carini http://forum.xda-developers.com/show...php?p=19958667
@cadi0: ho messo quello dell'android che balla, il primo che ho postato. Quando ho avviato però è uscita la schermata nera e poi si è avviato normalmente. Penso sia un fatto di permessi del file bootanimation.zip. Potresti per cortesia vedere con root explorer che permessi hai su quel file? Io li ho impostati così:
http://img846.imageshack.us/img846/8...2011811435.png
@maped: già avevo installato BAC, ma tra quelli proposti non mi entusiasma nessuno, sono troppo rudimentali secondo me.
foxmolder
io ho questi permessi sul bootanimation.zip in System/media
http://img.tapatalk.com/022cec49-ad39-1e52.jpg
Inviato dal mio Nexus S usando Tapatalk
Grazie maped! Comunque ancora non va, rimane lo schermo nero per un po' e poi si avvia normalmente. Ho provato a mettere "android vs apple" e funziona benissimo. Ci deve essere qualcosa nel primo zip che non va bene, ma non so cosa!
foxmolder
Prova a cambiare la cartella di destinazione.
Se l'hai messo in System..metti lo zip in Data (o viceversa)
porca pupazza non trovo più la cartella zippata :(...date un occhio anche qui
X|S Bootanimation
Finalmente sono riuscito a creare la bootanimation che da tanto desideravo!
Ho pensato di condividerla con voi, in quanto è pensata appositamente per il Nexus S.
Come avrete capito, mi sono ispirato al bellissimo logo posto sullo screen protector di fabbrica del telefono.
Eccovi un'ANTEPRIMA (l'animazione è ciclata solo per farla rivedere, ma durante il boot si ferma al completamento del logo).
Il tutto è realizzato a partire da immagini vettoriali, quindi è ad altissima definizione :D
Se vi piace, scaricatela da QUI.
Niente da fare, ho cancellato il .zip da system/media e l'ho messo in data, ma invece di uscire quello, mi è uscito il boot stock di questa rom, la scritta android. o_O
Comunque ho provato ad usare una tool per la creazione dei bootanimation e mi è uscito l'avviso
Your images contains indexed colors. The boot animation won't work on your android device.
Grazie SegFault, sembra davvero bella, la provo subito!
Ciao ragazzi volevo sapere visto che nel web ho trovato alcune animazioni carine per il bootloader se era possibile installarle perchè queste che ho trovato sono per il nuovo galaxy nexus.
mi aggiungo alla discussione, mi interessa!
PS: io trovo utilissimo il tool del nostro amico QUI...si fa tutto in modo automatico per la sostituzione dell'animazione ;)
ribellee85
L'importante è che siano 480x800. Puoi linkarle?
foxmolder
certo spero solo di non andare contro il regolamento facendolo...controlla un pò e poi fammi sapere se si possono mettere.
» Boot animation alternative per Galaxy Nexus » Modding & Firmware, - AndroidWorld.it
ah comunque attualmente ho messo quella che hai postato del robottino che mangia la mela...carino!
Ho provato e non funziona, si dovrebbe cambiare la risoluzione di ogni singola foto all'interno e poi cambiare la dicitura del file .txt
Io ho provato a sostituire solo la cartella bootanimation.zip e cambiare la risoluzione nel file di testo in 480x800, ma non ha funzionato.
peccato perché erano davvero carini...
Inviato dal mio Nexus S usando androidianiapp
W i forum e W la libertà di parola e di pensiero
Se ne trovano di bellissimi anche per il Nexus S :) Giusto per chiarire il problema che avevo avuto col bootanimation.zip dell'android che balla: sono riuscito a risolverlo grazie ad un utente di XDA e photoshop. In pratica le immagini nell'archivio bootanimation.zip devono essere in scala di colore RGB per essere eseguite dal nostro nexus. Ora ho l'android che balla come boot, proverò a metterci anche una musichetta rotfl
foxmolder
ma l'animazione è la stessa che ha postato qualche post fa?quella su youtube?
L'animazione è un primo piano dell'android come in questo video. Sarebbe un loop dei primi 6 secondi, senza le scritte e tutto il resto.
Dancing Android Commercial #1 [Horrible Translation] (Korea) - Original Video - YouTube
foxmolder
wow forte :) poi con quella musichetta non sarebbe niente male.magri se durava di più e al posto di quella t ci sarebbe stata la mela allora sai che figata.rotfl
