[ROM][AOSP][4.0.3][NEXUSS] GummyNex 0.7.0 - 01/27/12 - The B-Day release
Features:
AOSP build based on 4.0.3 complied by me
Mathkid95 Matr1X kernel OC / UV voodo sound / color init.d etc... - Credit Mathkid95
Performance Settings - Credit CM / Jrummy16 / Kejar31
GUI manageable init.d scripts tweaks - Credit Jrummy16 / Kejar31
Customisable SystemU tweaks - credit Xoomdev / Syaoran12 / Kejar31
Battery % always available in the lockscreen (now with the option to turn on and off) - Credit Syaoran12
Faster rotation initiation - Credit XoomDev / Kejar31
T9 Dialer - Credit CM
Quad Lockscreen with open customizable seats
Customizable battery icons options ( Hide, miui, stock, fat battery with %, side bar with % and circle)
Softkeys can be turned on and off(only for G-Nex)
LED settings - credit Romanbb
Modified Trebuchet - credit CM
Pulldown Widgets - credit Syaoran12 / LTE toggle credit - CM (notice it may take a min two for your phone to make the transisiton)
OI FileManager (compiled with the ICS SDK)
Softkey Mod and settings - Credit XoomDev / Icons - WJD Designs
FaceBook contact sync - Credit Roman
AOSP Wifi tether enabled
Busybox
Su and Superuser apk - Credit ChainsDD
Android Term - Credit jackpal
Stk
Livewallpapers compiled and included
All png's are optimized during build via CM script and PNG Crunch
Compcache support
ChangeLog ROM:
Added full language support
fixed misc hspa and bluetooth configs
Fixed hide battery reboot issue
Forced lockscreen settings to only be portrait due to FC on landscape view
Added Battery Text %
Added color support for the Battery Text %
0.7.0
Hold Back Force Close Apps -credit cm
Allow 180 degree rotation -credit cm
Volume Rocker Wake
Battery Bar % calculations fix -credit romanbb
Fixed Music Widget layout on lockscreen (that i broke... oops!)
Battery Text Low color now works
Additional Lockscreen status lines added to pin/password/pattern unlock
Swapped over to Trebuchet Launcher (we plan on revamping liberty launcher eventually) - credit cm
Updated Contacts to newest version -cm
Install:
Download the ROM
Download Gapps
adb reboot recovery
wipe data in CWM
install ROM
install gapps
reboot
Per Screen Vai Su XDA Thread Link : [ROM][AOSP][4.0.3][NEXUSS] GummyNex 0.7.0 - 01/27/12 - The B-Day release - xda-developers
Download GummyNex 0.7.0 ROM : Goo-inside.me Downloads - Downloading GummyNexS0.7.0.zip
Need G.Apps -> : Goo-inside.me Downloads - Downloading gapps-ics-403-Kejar31-011412.zip
Testata e approvata!
Enjoy Your Rom! :D
