Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 11
[ROM] AOKP |ilmk74| ics 4.0.3 speedy-7
    Androidiano VIP L'avatar di iaio72
    Jul 2009
    Ringraziato 618 volte in 346 Posts
    Aokp moddata by me
    Basata su AndroidOpenKangProject IMLK74 IceCreamSandwitch 4.0.3
    Caratteristiche
    - App mms inverted color
    - App Contatti inverted color
    - Launcher Trebuchet 0.1
    - RomControls by Kangy (haka)
    - App Facebook (sinc attiva)
    - App aTorrent
    - FlashPlayer 11.xx
    - GestoreFile
    - Market aggiornato
    - RomManager v4.8.1.4
    - NSTools 1.13
    - Fotocamera ottimizzata (auto focus)
    - Ringtones Miui
    - Kernel 3.1.10-ICUP :
    **** ->>> Ice Cream Universal Product <<<-->>> ICUP Kernel Edition <<<- ****
    ~ Updated Kernel Version to 3.1.10-ICUP
    ~~~ Fixed issues with MIUI & Other Rom's
    ~~~ GPS 100% Fixed for NS4G Users
    ~~~ Tweaked Conservative Gov.
    ~~~ Tweaked lulzactive Gov.
    ~~~ Added brazilianwax Gov.
    ~~~ Added intellidemand Gov.
    ~~~ Added lionheart Gov.
    ~~~ Added ondemandx Gov.
    ~~~ Added savagedzen Gov.
    ~~~ Added Wheatley Gov.
    ~~ Updated to 3.1.10
    ~~ USB Tethering Fixed
    ~~ CFQ I/O By Default now
    ~~ misc Fixes
    ~~ Camera Fixed for NS4G Users
    ~~ VR I/O Added
    ~~ LCD Voltage Drop
    ~~ Lagfree Governor
    ~~ Interactivex Governor
    ~ OTA ICS Compatible + Newer Custom Rom's
    ~ OC now Stable up to 1.44GHz ( GPU FB Fixed as well at this speed )
    ~ Live OC Supported (limited to 115%, anything over that wont take effect)
    ~ Data Corruption is now Fixed
    ~ Reboots Fixed
    ~ 100Mhz Screen on Idle Fixed
    ~ GPS Tweaks is unknown via NS4G User at this current time.
    ~ ro.secure=0
    ~ Voodoo Sound
    ~ Voodoo Color
    ~ BLD Supported
    ~ BLN Supported
    ~ Touch-wake Supported
    ~ Deep Idle ( DIDLE ) Not to be confused with Ezekeel Deep_Idle Mod
    ~ BT Sleep ( Needs Patched Rom to work correctly )
    ~ Stock Voltage
    ~ Added Bigmem patch
    ~ TUN is now built-in
    ~ CIFS is now built-in
    ~ Battery 100% fix ( Only Cosmetic, still stops charging at 96% like all android Devices )
    ~ NSTools Supported
    ~ added dm-cache
    ~ kernel:sched: LOAD_FREQ (4*HZ+61) avoids loadavg
    ~ BFQ Supported
    ~ CFQ Supported
    ~ SIO Supported
    ~ Noop Supported
    ~ Deadline Supported
    ~ readahead edits
    ~ block: limit default readahead size for small devices
    ~ ext4 edits
    ~ init.d Supported
    ~ *Governors Supported* ~
    * lulzactive
    * minmax
    * lazy
    * smartassV2
    * smartass
    * interactive
    * conservative
    * ondemand
    * userspace
    * powersave
    * scary ( Fixed Sleep of Death )
    * performance
    - Music2
    - Installate ultime GAPPS AOKP
    - Nessun bug riscontrato ( a scelta potete installare un altro kernel)*------------------------------*
    Installazione
    - Scaricare la rom e copiarla nella microsd
    - entrare in recovery e fare wipe/data-cache e dalvik
    - installare la rom come zip
    - riavviare e godersi la rom
    AOKPbyIAIO72-signed.zip
    OnePlus 3T
    Meizu Mx6
  2. I seguenti 3 Utenti hanno ringraziato iaio72 per il post:
    belladavide (27-01-12),lordnergal (30-01-12),miticoferry (26-01-12)
    Wow!! Sembra molto interessante, domani la provo,
    Grande!!
    Ciao
  5. Il seguente Utente ha ringraziato miticoferry per il post:
    iaio72 (26-01-12)
  6. #3
    Senior Droid L'avatar di belladavide
    Jan 2010
    Brianza
    Moto G5+
    mi sembra di aver provato qualcosa di tuo anche con il milestone!!! quindi devo provare anche questa!!! ahahahah
  7. #4
    Jan 2010
    Brianza
    Moto G5+
    messa sù! peccato però che non ha ripristinato le mie impostazioni!!!speriamo di ricordarmele tutte!!! ora testiamola per bene!!!
    grazie!!!
  8. #5
    Senior Droid L'avatar di Luca5h
    Iaio la mia paura era quella di non trovarti qui sul nexua. Hai reso la vita androidiana molto pi bella per me che ho avuto backflip-milestone e defy
    Inviato dal mio Nexus S usando Androidiani App
    Aspettando uno top gamma con tastiera qwerty!
  9. #6
    Jan 2010
    Brianza
    Moto G5+
    ho un problema con google plus che non riesce a funzionare! poi non riesco a mettere nella barra delle notifiche i tasti di scelta rapida!!
    boh
  10. #7
    Kernel alternativi?
    Inviato dal mio Nexus S usando Tapatalk
  11. #8
    Jul 2009
    Quote Originariamente inviato da Luca5h Visualizza il messaggio
    il mio consiglio è quello di usare il kernel di ezekeel il glados 2.9 cfs
    partendo dal presupposto che tutte le rom base aokp (kang) hanno il problema del riavvio anche con il kernel originale, mettendo un kernel moddato si hanno altri minor bugs come appunto il malfunzionamento di qualke applicazione come appunto g.plus!
    cerchero di sistemarla nella prossima versione
    poi se preferite icecream pulito senza tweaks vi posso pubblicare la mia versione originale creata dai sorgenti google........a voi la scelta!!
    OnePlus 3T
    Meizu Mx6
  12. #9
    Palermo
    Nexus S I9023 Root
    Perché quando faccio il download il Mac non mi legge il file in .zip? In poche parole me lo estrae direttamente e quindi se lo metto nella sd del nexus s non mi fa partire l'installazione!..Avete qualche consiglio da darmi?? Desidero provare a tutti i costi questa rom!
  13. #10
    Androidiano L'avatar di lordnergal
    Nexus 4
    ho installato questa rom sul mio nexus e devo dire che va una bomba, l'unica cosa strana che ho notato e quando il cell. è in standby a volte si illumina automaticamente. Capita anche a voi?
