Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 11
[ROM]Sense 2.1 on Nexus S!
    -Android*
    Salve,
    Su xda un utente ha pubblicato una rom in stile htc sense 2.1 e android 2.3.3.E' sviluppata per nexus s 3g i9023 e nexus s 4g.La rom è in sviluppo e quindi ci sono molti bug.
    Lista bug:
    -HTC Mail app is causing problems for some users, confirmation would be nice
    -Locations widget has problems downloading info
    -HTC Clock widget weather animations don't render correctly
    -Power off is weird, fastboot does not work on Samsung devices.
    -Camcorder does not record (yet) but camera takes photos perfectly
    screenshots : li trovate qua xda-developers - View Single Post - [ROM][PORT][SENSE 2.1] Nexus Sense 4G v1 | Full HTC Sense Experience | 2/9/12
    topic xda : [ROM][PORT][SENSE 2.1] Nexus Sense 3G v1.3 | Full HTC Sense Experience | 2/10/12 - xda-developers
    Download : http://minus.com/mfvsccsD8#1
    kernel : v11.5 cfs
    fix:
    fix browser force close : http://www.mediafire.com/?1r761cm7bdj0hj5
    fix with v1.3 :
    -= Changelog V1.1->V1.3 =-
    -Added support for huge amount of languages
    -Added option to enable/disable screen on/off animation through settings > display
    -Some small build prop edits, increased vm heap to 72 for smoothness in apps (to test it out, reduce it if you feel like it.)
    -Added in some missing framework parts
    -Added files to allow for more mods in the future
    -The rom feels much faster and fluid than first release
    Sense 3.0 Lockscreen
    http://www.mediafire.com/?xf2cl2c6rc8v52t
    versione 1.3
    FIRST BOOT ONLY GPRS 3G ISN´T ENABLED YET. U NEED TO SET THAT MANUALY. USE *#*#3646*#*# GO TO THE FIRST SCROLL DOWN YOU WILL SEE GSM ONLY PRESS IT AND CHANGE TO WCMDA PREFERED TURN OF RADIO TURN IT BACK ON AND REBOOT WAIT 1 MINUTE AND YOU WIL HAVE 3G
    Nexus s 4G
    v.1.3
    kernel : matrix v 11.5
    bug : stessi della versione 3g
    download : http://minus.com/mbgo5JKxbz#1
    thread : http://forum.xda-developers.com/show....php?t=1489851
    topic xda : http://forum.xda-developers.com/show....php?t=1489851
    Ultima modifica di -Android*; 18-02-12 alle 15:47
    Samsung Nexus S
    Già flashata, ha abbastanza bug, tra cui quello fastidioso dello spegnimento ma per il resto va bene.. spero nel porting della sense 3.0 o 3.5 che rispetto alla 2.1 sono molto piu belle.. comunque bel progetto..
    Inviato dal mio Nexus S usando Androidiani App
    Modello: Samsung Nexus S i9023
    Rom: Pixel Rom 1.60
    Kernel: Air Kernel v3.6
    IL TOP!
    Remembers the day when blackberry and apple were just fruit.
    Androidiano VIP L'avatar di Glad
    Pescara
    Nexus 5
    Ringraziato 134 volte in 129 Posts
    da apprezzare l'impegno....non avendo i sorgenti!!!!
    Nexus S, Galaxy Nexus, Nexus 5, Nexus 7 (2013)
    Ringraziato 78 volte in 76 Posts
    L'ho ad occhiata anch'io stamattina... se risolvono i bug torno a gingerbread per provarla!
    Inviato dal mio Nexus S usando Tapatalk
    -Android*
    v. 1.1 : fix data!
    Quote Originariamente inviato da -Android* Visualizza il messaggio
    v. 1.1 : fix data!
    *-* dicci come ti trovi se la flashi...
    -Android*
    insomma , le scritte sono troppo grosse ad esempio quelle nella barra di notifiche! Poi piccoli bug però se si vuole una sense experience si deve comprare un htC!Buona durata della batteria e però ci sono poche skill per la home!Ma chi vuole cambiare un pò la può flashare
  9. #8
    Ci fai qualche screen? Volevo vedere queste scritte quanto sono grandi (non si può cambiare dimensione dalle impostazioni?) E poi vedere lo schema della batteria e utilizzo display
  10. #9
    -Android*
    Quote Originariamente inviato da massimiliano_93 Visualizza il messaggio
    puoi guardare sul sito di xda dove ci sono già gli screen ! Per la durata batteria lo puoi anche leggere nel topic! Comunque io non la rimetto per ora.
  11. #10
    Provata per una mezz'oretta... molto bella la se se purtroppo non c'è l'italiano ed è basata su gingerbread... se si post asse su ics sarebbe una cosa stupenda!
