[ROM][4.0.4]][MIUI] Oodie pRiMe " rOcket fUeled "
Qualcuno l'ha provata:
[ROM][4.0.4][01/03][MIUI][2.2.24] Oodie pRiMe " rOcket fUeled " V2 - xda-developers
What you get from installing this rom
- This is a slightly modded Stock Miui 4 rom / Now with Android 4.0.4
- Some tweaks added
- Comes with the Matr1x 17.0 CFS Kernel ( Feel free to use it with other custom kernels & report back )
- Some apps updated due to some errors in stock apps
- HW acceleration Enabled
- Superuser Fully working ( Miui security app )
- Usb debugging enabled straight from ramdisk
- Zipaligned - Deodexed
- Voodoo Colors
- 4 way reboot power menu
- etc .. etc
INSTALLATION
Download Rom - OodieMiUi pRiMe [2.2.24] rOcket fUeled V2 - Flash it with Recovery ( Plz Don't mirror )
{Full Wipe is reccommended for Better Stability}
Then Reboot -First boot might take a while .
After The First Boot , Do another reboot after 3-5 mins For apps to get settled
Enjoy !!
If you get Any FCs Try Fixing Fix Permissions from recovery or using rom manager .
Credits Goes to ..
MiuiAndroid & MiuiAu , KalimochoAz , Mathkid ,SWAT miui team , Cobrato , Doomlord , Brainmaster , Kong , evillisto & All who helped me getting here .
