come da richiesta se qualcuno ha una rom sua o un backup se lo puo postare :) grazias
Postata da bajansurfer su XDA
Download
Hi all,
Here's a nandroid backup of Stock 2.3.4 (GRJ22) rooted from my GT-I9020T. Just extract the zip and place the folder that's inside the zip into the /sdcard/clockworkmod/backup folder on your phone. Then reboot your phone into recovery and restore the backup that says "Stock_2.3.4_rooted"
I've only tested this on my phone but hopefully it should work for you. You may want to install Busybox after.
NOTE: the zip that you download contains another folder within it so when you extract it, make sure you use the folder inside and not the actual extracted folder.
