MIui
Cioè veramente ragazzi oggi volevo mettere la miui su desire s e ho visto che per metterla ci vuole un casino!
Questo è il tutorial O.o
Update your recovery.
Check HBOOT version is 1.7 or below
Boot to recovery.
Flash stock ZIP file which is included in ZIP file.
Tutorial if you DONT have 4.0 / Updated HBOOT
You need S-OFF and HBOOT 7.0. If you have HBOOT 6.8 follow steps 2
Rename the file PG88IMG_hboot7.0.zip to PG88IMG.zip. Follow Steps (4-7)
If you have HBOOT 7.0 and S-OFF. Flash this PG88IMG_SAGA_ICS.zip.
Place on root of SD Card.
Turn phone off.
Boot with Vol Down and Power to enter Fastboot (or adb reboot bootloader)
Press vol key. That will start update of HBOOT. Restart at step 3
After you have HBOOT 7.0 and HTC 4.0, you must flash a new recovery.
There is a file for every OS (ends in .bat -> Windows, etc)
Double check that file for your OS and it'll flash a new recovery.
Then flash MIUI ZIP via Recovery
Che sinceramente non ho ben capito se volete i link per scaricare i pacchettisono questi!
https://rapidshare.com/files/2484731...s_20120724.zip
http://bigota.d.miui.com/tools/g12_v...s_20120724.zip
Se ci fosse qualcuno che mi sa dire come si fa! :)
...forse messo così è un po più chiaro
Steps i followed,
1. I downloaded the g12_v4_tools large zip file of more than 500Mb..
2. Extracted and found new HBOOT 7 and Official HTC ICS 4.0 leaked Chinese ROM
3. Installed HBOOT 7
4. Installed HTC ICS ROM (Both by renaming corresponding zip files to PG88IMG.zip and copying to SD Card Root and from bootloader , it gets automatically detected)
5. Booted into the Chinese Rom, All went well, booted fine,
6. Installed 4EXT Touch Recovery 1.0.0.5RC
7. Rebooted into Recovery
8. Wipe Data/Factory Reset
9. Wipe Cache
10. Wipe Dalvik Cache
11 Install From zip and i chose MIUI 2.8.3 zip
12. Reboot after installation
Ah ok piu o meno ci sono :) Devo solo scaricare lo zip che è enorme!
Net una domanda ma se io mettessi questo hboot 7 non dovrei creare problemi no!? anzi magari è un po meglio essendo piu aggiornato no!?
E poi volessi rimettere che ne so la fallout posso farlo senza problemi no!?
Ciao Net.Aiuto....
Ho aggiornato a HBOOT 7.0 e sin qui tutto ok. A questo punto mi pianto non riesco a flashare la ROM ICS V4. .....
-dal Bootloader non riesco ad uscire se non con power down
-mi spieghersti passo passo come fare.
Grazie mille....
Daxic
nessun problema.;)
Henri
Ciao Net.Aiuto....
Grazie mille....
le istruzioni,in inglese,le ho postate sopra.come fai a flashare la rom ICS v4?l'hai rinominata PG88IMG.zip,messa nella root della sd e riavviato in bootloader?
Aspetta messa nella root della sd ovvero dove? nella sd in nessuna cartella no!?
esatto.in nessuna cartella
1. Estratto HBOOT 7 e Official HTC ICS 4.0 leaked Chinese ROM
3. Installato HBOOT 7 (messo il file PG88IMG_hboot7.0.zip risoprannominato PG88IMG.zip nella root della sd, avviato in bootloader(fastboot) e dovrebbe aggiornare in automatico l'hboot)
Giusto va bene fino a qui?
Poi penso si deva flashare la ROM dentro allo zip normalmente.
Riavviamo in recovery, vari wype e poi flashiamo la vera e propria miui 2.8.3 no!?
Dovrebbe essere cosi in italiano :)
Sono insicuro perche non ho ben capito i passaggi 4 e 5!
Henri
non riesco a flashare la ROM ICS V4..
Domanda : che rom è questa? quella del punto 4 che non capisco!
Perche dentro allo zip c'è questo ma non so se sia una rom o altro "PG88IMG_SAGA_ICS_35_S_HTCCN_CHS_3.07.1400.2_Radio _20.72.30.0833U_3831.17.00.310_release_266765_sign ed"
Dopo aver fatto quella cosa dell hboot spengo tutto e devo risoprannominare anche questo solo PG88IMG.zip per poi riaprire in bootloader?
Dovrebbe sempre trovarlo da solo e quindi aggiornare alla 4.0!? Poi flasho la rom miui come una rom normale no!?
Daxic
...traduzione
I passi che ho seguito,
1. Scaricato g12_v4_tools file zippato grande più di 500Mb..
2. Ho estratto lo zip e ho trovato il nuovo HBOOT 7 e la rom ufficiale cinese HTC ICS 4.0
4. Installato HTC ICS ROM (entrambi rinominando i rispettivi file zippati in PG88IMG.zip e copiandoli nella SD Card e riavviando in bootloader , sono automaticamente riconosciuti)
5. Avviato la rom cinese, tutto è andato bene, avviata bene,
6. Installato 4EXT Touch Recovery 1.0.0.5RC
7. Riavviato in Recovery
9. Wipe Cache
11 Install From zip e ho scelto MIUI 2.8.3 zip
12. Riavviato dopo l'installazione
Daxic
si è la rom cinese contenuta nello zip.
Quello che mi chiedo è come faccio a mettere due file con lo stesso nome nella stessa cartella...se faccio uno alla volta pensa vada bene uguale!?
Prima quello dell'hboot, installo e poi metto nella sd quello della rom installo e poi ecc ecc...
PS: grazie e scusa se faccio tutte queste domande :)
...infatti devi farlo uno alla volta.prima hboot e poi rom cinese.
Net ho installato la Rom in cinese.
ho provato a flashare la CWM Recovery tramite Bootloader solo che mi da sempre questo errore:STATUS MALFORMED (1 BITES)
Henri
se la flashi tramite fastboot flash recovery recovery.img,ti da quel errore perchè non sei nel menù fastboot del telefono ma bensì nel menù bootloader.seleziona fastboot usb e ridai il comando.
Io ho gia la 4ext installata non devo reinstallarla vero?
grazie Net.
ok istallato la CWM ora tutto ok.
tutto funzionante grazie di tutto.
Daxic
devi reinstallarla in quanto ,il flash della rom cinese,ti mette la recovery originale.
Fatto tutto! Tutto bellissimo ma non riesco a capire una cosa..ho installato l italian pack ma non c'è la tastiera italiana...percheeeeeeeeeeeeeeee?
