[AlphaRevX] Public Beta 2 for Desire S
È stato inserito nelle compatibilità della nuova Public Beta 2 anche l’HTC Desire S che potrà quindi essere sbloccato.
Non ho(ancora) testato personalmente il procedimento
questa è la guida che ho trovato su Xda:
1. Download the Android SDK from here: Android SDK | Android Developers
2. Unzip and go into the folder you just downloaded
3. Run the 'android' application within the 'Tools' folder
4. Select 'Available Packages', and select 'Android SDK Platform-tools' and 'Android Compatibility package', and install these.
5. Make sure ADB can see your device by cd-ing into the SDK folder, and then the 'platform-tools' folder, and running './adb devices'. Your device should show up (mine had a string of question marks, but it should work as long as it is there)
6. Download AlphaRevX and get your beta key
7. Run AlphaRevX as root, and follow the instructions, and you should have S-OFF
[AlphaRevX] Public Beta 2 for Desire S - xda-developers
