Utente del giorno: hobin con ben 1 Thanks ricevuti nelle ultime 24 ore
Visualizzazione dei risultati da 1 a 10 su 49
[ROM] MIUI v4 ICS [ultimo LORD Kernell]
    Androidiani Power User
    Dec 2009
    Rimini
    nuova hylz MIUI v4 2.2.24 RC5(27/02)
    • Camcorder ( But TP Camera )
    • Camera
    • Sound
    • Boots withought any issue
    • Wallpapers
    • Live Wallpapers
    • Phone works 2G/3G
    • Touch
    • Keys
    • SD Card
    • Wifi
    • Sensors
    • Root
    • Headphones
    • Bluetooth
    • EGL
    • Advanced Power Menu
    • Screenshots
    • Market
    • Mic
    • 3D Games
    • Gallery
    • 3D Acceleration
    • Video Playback
    • GPS
    non funziona bene
    video HD
    https://www.androidiani.com/forum/mo...ml#post1180595
    aggiornamento MIUI v4 ICS - 2.2.3-r4
    Aggiornamento MIUI v4 ICS - 2.1.27-r1 [Android 4.0.3] 27/01
    notevole passo avanti di questa rom dove funziona quasi tutto e ha una piu che buona usabilita'
    sicuramente la miglior ICS provata fino a questo momento
    la fotocamera funziona decentemente, funzionano anche i video in riproduzione
    * Sim Toolkit added
    * Overscroll and Fancy IME animation options added (in “Control”)
    * Developer Options added (in “Control”)
    * Dialer and Market lag fixed somewhat.
    * Replaced the custom A2SD with my own Data2Ext script. Requires an ext3/4 partition as 2nd partition on the sd card.
    * Market cache always bind mounted to data so that any app can be downloaded without free space issues.
    * Wi-Fi sleep policies fixed (array was the wrong way around)
    * Removed Bug Report.
    * Many, many English improvements thanks to Fllash.
    * Due to this week not being an official update from MIUI, and the vast changes I’ve made, this one won’t be OTA again. While the rom is slightly unstable and changing rapidly, I feel it best to use OTA mainly for patch updates to fix problems, but for full rom updates I’d prefer people have to come here and READ PROPERLY to see what they’re getting into. Hope this is understood.
    ...e sto usando la 2.1.17...mentre è uscita la rc1...
    appena installata non mi permetteva di usare la tastiera,un messaggio mi chiedeva di cancellare i messaggi nell'area di notifica anche se non c'era niente,ho risolto facendomi una chiamata per far comparire un messaggio nell'area di notifica,una volta cancellato è andato tutto a posto
    avendo reinstallato tutte le applicazioni(una ottantina) con titanium non potevano mancare diversi episodi
    di FC,ma dopo un po di rodaggio e devesi aggiustamenti la rom a cominciato a correre regolare
    l'accesso hai widget fa rallentare parecchio la rom ,ma una volta usciti torna tutto normale
    alcune applicazioni con ICS ancora non sono totalmente compatibili ma questo non è colpa della rom
    i filmati in HD vengono riprodotti con difficolta'
    Aggiornamento:
    BASE 2.1.20 per questa ICS [LORD Kernel]
    aggiornata alla base 2.1.20
    cambia il kernel ,adottato il Lord kernel (sicuramente meglio)
    e poi:
    - new base: v4 - 2.1.20
    - Back to Lordclockan Kernel
    - MIUI Backup fixed
    - MIUI Themes fixed
    - Cyanogend Mod 9 Music Player
    - updated Genie Widget
    - Launcher tweaks for faster ui
    - updated Google Maps
    - added LGCamera Free version
    - Headphones fixed
    MIUI-v4-DesireHD-2.1.20.zip
    scompare la scritta "BETA" ??? tutta da provare
    non funzina il camcoder e USB Tethering ...piu quello che scopriremo da soli
    l'autore sostiene che la rom è stabile per un uso giornaliero...staremo a vedere....
    miui-4-19-01-ace.zip
    [ROM] [BETA] Miui v4 ICS [2.1.13] for Desire HD BETA 1 - xda-developers
    miui v2
    cam funzionante (quasi)e superuser funzionante.....
    usabile ma non da considerare stabile ovviamente
    lavora sicuramente meglio della sorella ICS sulla quale è totalmente costruita
    come dimostra anche l'email di ringraziamento per aver attivato il nexus.....
    mancano quindi ancora tanti elementi tipici di miui come l'organizzazione dei menu
    come alcune app proprietarie ,e tante altre cosette da aggiustare
    Chi è abituato alla miui non trovra' molte piccole cose importanti che rendono la miui unica nel suo genere per usabilita'
    speriamo che non venga abbandonata questa strada .......
    fa riflettere pero' il passo degli sviluppatori che lavorano a queste rom ICS che sono gia' arrivati a questi risultati grazie ad un lavoro di squadra che coinvolge un discreto numero di persone
    e il contributo non da poco del team CiyanogenMOD
    sono gia riusciti a creare delle rom gia installabili e funzionanti su un dispositivo come il DHD che certamente è molto lontano dai dispositivi samsung sui quali nasce ICS
    Mentre sul lato sense per avere qualcosa di usabile bisogna aspettare che venga prodotta una rom da HTC gia' molto vicina alle caratteristiche del DHD
    è vero che sense è una rom piu complessa, che l'unica sense ICS ha bisogno di adeguamento della risoluzione, e tante altre cose...ma molto è anche dovuto alla "litigiosita'" tra addetti hai lavori che forse per mancanza di idee o di capacita' si "rubano" a vicenda
    anche la comparsa di diversi "imbrattarom" sta creando il proliferare di rom sempre piu approssimative e prive di contenuti veri
    Se la situazione non cambia dobbiamo solo aspettare e sperare che HTC rilasci una gia' ottima rom per il sesation xl come è successo per sense 3.5 dalla quale sara' semplice realizzare un porting per il DHD
    ...e magari ce lo dovremo fare da soli
    Ultima modifica di linux33it; 27-02-12 alle 10:46
    Androidiani Power User L'avatar di leorogue85
    Feb 2011
    Potenza
    LG G2
    Ringraziato 514 volte in 378 Posts
    Ooooh linux, ma hai le notifiche sul cellulare che ti avvisano quando escono nuove roms? Diamine, volevo fare io il post xD
    Ps: in download, poi magari la aggiungo al topic delle rom!
    Inviato dal mio Desire HD usando Androidiani App
    Dec 2009
    Rimini
    Quote Originariamente inviato da leorogue85 Visualizza il messaggio
    gran bella rom
    solo non riesco a far funzionare il superuser.....
    Senior Droid L'avatar di ficciomc
    Padova
    OnePlus 7 PRO
    Ringraziato 108 volte in 78 Posts
    X me Linux è ormai in collegamento sinaptico cn xda..
    Feb 2011
    Potenza
    LG G2
    Quote Originariamente inviato da ficciomc
    Vero? Hahahahahahahaha riceve le notifiche mentali
    Ti vogliamo bene linux
    Tornando IT.... Il superuser pare lo stiano risolvendo.
    La fotocamera stanno cercando di farla partire anche
    Per chi vuole, ho postato una foto nella sezione della beatmode... Giusto per farvi vedere come va
    Feb 2011
    Potenza
    LG G2
    Edit: uscita la beta 2 con fotocamera funzionante! Appena posso la aggiungo al topic, o se può farlo qualche moderatore per me è uguale!
    Androidiano L'avatar di David1986
    HTC Desirè HD
    uhmm questa si che è una rom interessante
    ROM: IceColdSandwich - Android 4.0.4 (ICS) - AOKP
  9. #8
    Dec 2009
    Rimini
    Ecco una ulteriore evoluzione il lavoro svolto sulla carta sembra tanto...
    Thanks ;
    emexci, Turkpda, Diamondback, zFr3eak, LorD ClockaN
    Working
    • Camera
    • Sound
    • Wallpapers
    • Live Wallpapers
    • Phone works 2G/3G
    • Touch
    • Keys
    • SD Card
    • Wifi
    • Sensors
    • Root
    • Headphones
    • Bluetooth
    • EGL
    • Screenshots
    • Market
    • Mic
    • 3D Games
    • Gallery
    • 3D Acceleration
    • Video Playback
    • GPS
    Not Working
    • USB Tethering
    • Tell me
    RC1
    • Release : MIUI 2.1.17
    • Base : MIUI Turkey - TURKPDA.COM
    • Kernel: LorDMod 8.8 - ICS - BFS - B7
    Build.prop
    • Added Wi-Fi Scan Rate 100
    • Added Some Extra Performance Fixes
    Features
    • CM9 Music
    • Better SD Card Performance
    • Inspire 4G Mod
    • Some UI Performance Tweaks
    • RAM Optimisation script
    • Initial Sound Setup: Dolby V for Speaker, SRS for Headsets (a user)
    • GPS Conf.
    • Edit Updater-Script
    Added
    • Added LG Camera (Works 8MP and HD Video Record )
    • Added Fast Brust Camera ( Mirror )
    • Added Es File Explorer
    • Added Adobe Reader
    • Added Adobe AIR
    • Added Facebook 1.8.1
    • Added eBuddy
    • Added Flash Player 11.1
    • Added Youtube
    • Added Twitter
    • Added Google+
    • Added Google Maps 6.0.3
    • Added 76 New Wallpapers
    • Added 25 New Lock Screen Wallpapers
    • Added SyncMyPix
    • Added Google Search
    [ROM][4.0.3] hylz MIUI 2.1.17 RC1 | 17/01/2012 - xda-developers
  10. #9
    wgk
    wgk non è in linea
    ciao a tutti io ho un paio di problemi
    la suoneria per le chiamate in entrata parte con un pò di ritardo, diciamo dopo il secondo squillo effettivo.
    e non riesco a visualizzare i contatti della sim
    come posso fare ?
  11. #10
    Quote Originariamente inviato da wgk Visualizza il messaggio
    come posso fare ?
    Per i contatti ti consiglio di usare l'account di google...
  12. Il seguente Utente ha ringraziato Gobbo93 per il post:
    wgk (19-01-12)
