Pagina 1 di 221 1231151101 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 2202
[ROM] Desire HD CoreDroid v9.2 | sense 3.5 WVGA
    Androidiano VIP L'avatar di Rantolux
    Feb 2011
    Xiaomi Mi 8
    Ringraziato 514 volte in 446 Posts
    CoreDroid v. 9.3 Sense 3.5
    MD5: 30a1f23af254b9f067e239783c7e5e69
    CoreDroid v. 9.0 Sense 3.5
    CHANGELOG:
    Android 2.3.5 (Gingerbread) HTC Sense 3.5
    Multi-language Including Arabic
    95% Coredroid Skinned (Due too M10 Limitations)
    COREDROID SKIN APK (Most Sense 3.5 widgets parts are skinned. Make sure to apply skin from personalize)
    Performance optimizations
    Rooted, unsecure boot.img
    Bash command & nano editor
    EXT 4 optimizations
    Ram optimizations
    Keep your home launcher in memory
    Improved overall UI smoothness
    All System apks ZipAling & Optimized
    All User Apps Zipalign at Boot
    init.d scripts support
    Excellent battery life
    Improved auto-brightness values
    Blocked Adds (AddFree App provided for Updates)
    Fully Deodexed
    Enabled GPU UI rendering
    Improved Andreno configuration
    SD Card speed tweak
    CIFS support
    Wi-Fi module improved drivers
    Screenshot by pressing Power and Home
    Advanced Power Menu
    Increased Audio
    Beats Enabled
    All system & 3rd party apps updated to latest
    Keyboard Animation
    Amaze Camera
    Camera performance Improved
    Sony Bravia Engine (HQ Image and Movie improvements)
    Extended Settings in Browser
    Enable/disable Sense unlock animation (carousel effect)
    4 column app drawer or 5 column app drawer (configured in Tweaks)
    CUSTOM personalize button on Sense 3 launcher! (you can choose your own app! Defaults to browser)
    Disable/enable paginated app drawer
    Custom Quick settings (Hide any extended settings you don't want!)
    Ability to hide recent apps in pulldown (hidden by default)
    Clock options (colors/am pm settings/hide)
    Signal options (color/dbm text/hide)
    Battery options (text/automatically colored text based on battery level/hide icon)
    Choose between showing H or 4G in the statusbar
    Center clock!
    Quick-quick settings option (automatically turn to settings when no notifications to clear)
    MD5:68BBE7AA787064B50589A2373DC31A41
    CoreDroid v. 8.1 Sense 3.0
    CHANGELOG:
    Updated Firmware to Sensation 1.45.401.2 Android 2.3.4
    Completely resized and optimised for DHD
    Lord Clockan Kernel V2.1
    More Tweaks options added under Settings
    New GFX and Lockscreen animation
    All apps updated
    Performance, Battery & Network Improvements
    MD5: 80C7EC8943E910A75B1C11675434EDF4
    Tema Col BlueManiacs per CoreDroid 8.0 by Memnoch (Grazie)
    L'app per controllare il daemon (versione 2.11) la trovate qui
    Prima si deve installare OC daemon e poi installare l'app con astro e settarla. (Grazie @Memnoch)
    MODS: Lockscreen - SystemUI - Rosie - Fonts - Browser
    Prima di flashare qualunque di questi zip, è necessario fare il wipe dalvik
    recovery : clockworkMod 3.0.x.x
    oppure (meglio ancora ) 4EXTRecovery v2.1.1b
    MD5checksum: 2E0DB99BE06B1CB4282E67B60485F0C0
    Per chiunque volesse cambiare il tema di questa rom......può trovarne di bellissimi qui Coredroid Mod 6.7/6.8 (NEW-Horror theme) - xda-developers
    PROCEDURA CORRETTA PER FLASHARE QUALSIASI COSA DA RECOVERY
    --Flash della rom. (metodo DEFINITIVO
    -Riavviare in recovery
    -andare su "Mounts and Storage"
    -Selezionare format system, poi data, e poi cache.
    -al termine, eseguire un wipe data factory reset (normalmente cancella i soli dati utente, ma noi serve a rimontare le partizioni GIA' PERFETTAMENTE PULITE CON I FORMAT.
    -ora flashate la rom.
    NOTA: qualsiasi altra procedura è da considerarsi errata. Full wipe , mount vari, altre procedure, sono tutte SBAGLIATE. Questa procedura vi assicura una pulizia molto vicina agli erase da fastboot.
    --Flash del kernel
    -Riavviate in recovery
    --flashate il kernel
    --eseguite un wipe dalvik cache
    --riavviate
    Flash del RIL
    --Riavviate in recovery
    --NON FATE ALCUN MOUNT( anche se vi viene consigliato)
    --flashate il RIL
    --riavviate
    NOTA: se doveste avere problemi nell'applicazione del RIL, postate qui e vedremo di capirci di più.
    Flash dei temi o add-on (tipo sense 3.0 all in one package)
    --riavviate in recevery
    --flashate il tema
    --fate un wipe dalvik
    --riavviate
    --IDEM PER GLI ADDON
    @Rantolux scusa l'intrusione;-)
    Memnoch
    Ultima modifica di Rantolux; 28-01-12 alle 20:54
    Xiaomi Mi 9
  2. I seguenti 16 Utenti hanno ringraziato Rantolux per il post:
    Abrax (12-05-11),angiotell (07-05-11),antonaq (05-05-11),Astore (20-05-11),Berto392 (21-05-11),darkengine (19-06-11),EnricoDHD (21-05-11),leogalaxys (03-06-11),lorevan (08-05-11),mungello860 (21-05-11),orsochecorre (10-05-11),Paigoz (10-06-11),savioonline (05-05-11),TuLKaS (13-05-11),unixer (05-05-11)
    Feb 2011
    Qualcuno l'ha installata? Io ho paura nel farlo, ma per il semplice fatto che tutte le ROM con ginger con il Lee Kernel mi hanno dato un forte ritorno fastidioso della voce del mio interlocutore...
    HTC Desire HD -> HTC Sensation -> T-Mobile Mytouch 4g (HTC Doubleshot) -> HTC One S -> HTC One X+ -> ?
  5. #3
    Androidiano L'avatar di unixer
    Mar 2011
    in download
    ma sono indeciso visto che solo ieri ho montato la 5.4
  6. #4
    Feb 2011
    Xiaomi Mi 8
    la sto testando.........ottima, oltre che bellissima come tutti i lavori di Sergio
    attualmente il bug che ho rivelavo è nel meteo che dà come giorni della settimana sempre domenica.....ma ci dovrebbe essere una ptch in giro
    Xiaomi Mi 9
  7. #5
    axl409
    Quote Originariamente inviato da Rantolux Visualizza il messaggio
    se trovi questa patch postala
  8. #6
    Androidiano L'avatar di teisho
    Mar 2011
    Nexus 5x stock
    Quote Originariamente inviato da axl409 Visualizza il messaggio
    stasera je tocca....
    Inviato da Teisho dal Pc
  9. #7
    Mar 2011
    appena finito di scaricare
    ma come checksum mi da
    044774cf864d56e46945dea29e65c2fb
    come mai ??
    controllato con md5sum.exe
  10. #8
    Androidiano VIP L'avatar di savioonline
    Apr 2011
    Bari
    Ringraziato 70 volte in 63 Posts
    Quote Originariamente inviato da unixer Visualizza il messaggio
    come mai ??
    L'md5 è questo: AEA3C6C6274769F69C895494317D916B
    l'hai scaricata da qui??: Welcome to CoreDroid ROMs - The home of the best HD2, DHD & Inspire 4G custom ROMs.
  11. #9
    Feb 2011
    Xiaomi Mi 8
    come mai ??
    io l'ho appena fatto tutto ok
    riprova:
    Xiaomi Mi 9
  12. #10
    Mar 2011
