Pagina 1 di 66 1231151 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 656
[ROM][Aug 29-2011]RCMix3d 234 v2.6 [First android 2.3.4 incl. sense3.0 on dhd][OC]
    Jan 2011
    Ringraziato 17 volte in 13 Posts
    Rom su base Pyramid 1.45.401.2 android 2.3.4
    Questo è il risultato di un duro lavoro di squadra tra samuel2706, QD2DC and RCTeam (robocik, klquicksall and capychimp)
    Features:
    Base - RUU Pyramid HTC android 2.3.4 build 1.45.401.2
    Deodexed
    Kernel: RCMix3D
    Extra quicksettings
    Busybox, Root, Superuser...
    ES file explorer
    Requirement:
    Full wipe required.
    Personalmente consiglio, anche se è stato detto e ridetto, l'operazione di wipe classica/manuale che si può riassumere in poche righe:
    - Riavviare in recovery
    - andare su "Mounts and Storage"
    - Format system, poi data, e poi cache.
    - Wipe data factory reset.
    - Flashate la rom.
    Changelog:
    v2.7
    Added Tweaks and Bloater from Bulletproof sensation rom (great stuff!) (thx romanbb)
    v2.6
    New Kernel
    Callrecording added
    USB mount fixed
    v2.5
    Wifi fixed again
    gallery changed back to pyramid android 2.3.4 (fixed effects)
    Inspire4g full phone identity
    v2.4 (BUG: WIFI NON FUNZIONANTE)
    user apps auto install written by rmk40 readded, known form kingdom
    gallery updated to evo3d android 2.3.4 to behave as meant by htc
    rosie sizing edits
    nl_be language added
    inspire detection corrected
    trim video fixed
    v2.3
    crt readded
    keyboard slide in animation
    last resizing
    rom optimized by coolexe huge thx there buddy
    ext4 aligment by coolexe
    other tweaks and fixes
    user apps auto install from kingdom added (made by rmk40)
    auto detection of inspire phones, for audi gps and such by coolexe
    updated su
    v2.2
    widgets fixed after mistake on sizing
    watch app should work now
    videos in app drawer
    other sizing
    v2.1
    resized new widgets
    cam fixed (thanks to sam)
    phone identity should be right now
    v2.0
    wwe 1.45.401.2 (thx baadnewz)
    wifi dhcp fixed (thx LorD ClockaN )
    friendstream widget displays correct
    email widget displays correct
    v1.0
    Added advanced power menu
    crt and all the usual things
    Deodexed
    Working Trends widget, not seen before on sense 3 dhd
    Initial release
    Downloads:
    RCMix 234 2.7 Multiupload
    MD5: bb6187a80d19b6d6a72a9c55f504aff6
    Old download
    RCMix 234 2.6 Multiupload
    MD5: 92E79699A430DEF3D7FAED911D20EC76
    RCMix 234 2.5 Multiupload
    MD5: coming
    per questa versione si consiglia l'utilizzo del kernel Unity V5, in quanto con il kernel stock non viene rilevata la connessione USB al PC!
    download: UNITY_V5_2.6.35.14_2.3.4_FINAL.zip - 4shared.com - online file sharing and storage - download
    RCMix 234 2.4 Multiupload
    MD5: 91793790929f854f0eea85c29927a64d
    RCMix 234 2.3
    MD5: 1ada1703c25d624c37b5ea67fb621648
    Ultima modifica di devilrex; 01-09-11 alle 09:48
  2. I seguenti 4 Utenti hanno ringraziato devilrex per il post:
    angiotell (15-08-11),Berto392 (16-08-11),Stifler (21-08-11),Timisoara (28-08-11)
    Jan 2011
    La sto testando da un'oretta.
    Premetto che per me la rom Sense di riferimento era la Virtuous ma quest'ultima sembra, almeno per ora, una passetto avanti per fluidità.
    Ho lasciato il clock di default a 128-998 mhz, ondemand.
    Vediamo un pò come si comporta con i consumi e tutto il resto.
    Ultima modifica di devilrex; 14-08-11 alle 19:11
  5. #3
    Mar 2011
    Prato
    samsung galaxy s6 edge
    l'ho installata,ma quando collego il pc al computer non mi chiede cosavoglio fare,mi ricarica il cellulare e basta.Premetto che ho formattato la sd prima di installarela rom.Cosapuò essere accaduto?
  6. #4
    Jan 2011
    E' un bug in fase di risoluzione.
  7. Il seguente Utente ha ringraziato devilrex per il post:
    antoniounico10 (14-08-11)
  8. #5
    Quote Originariamente inviato da devilrex
    Si! Come anche la fotocamera....
    Spero che lo risolvino presto,perche mi sembra una piu che ottima rom!
    Avete notato tutti bene...anche a me mi sembra un pelo piu fluido della virtus.
    Menomale che pian piano abbiamo superato la fatidica soglia 2.3.3 sense 3.
    Ora sono propio curioso come sarra la Virtus 2.3.4 che esce tra poco......su xda si mormora che sarra un super lavorone.
    Qualcuno sa come fare,con I'll deamon sulla Rcmix?
    Visto che non esiste la cartella dell Deamon come nella 2.3.3.
    VIRTUS UNITY 1.31 full sense3
    kernel. mdj UNITY V5
    DEAMON OC 245000 min 1190400
    radio12546026u 26110421m
    ril 0160
    mods: ATZ1.31/BLU MAGIC1.8/uot mixet teme. skin Glass.
    5X5 TRANS ROSIE /PERFECT ROSIE
    crt patch. EVO camera. Pyramid DOLBY MOBILE 3.1. prox sensor. Chinacat Font.
    MicroSD class10
  9. #6
    Jan 2011
    A me la fotocamera funziona, a cosa ti riferisci precisamente?
    Hanno pubblicato il change log della 2.3 presumo che il download è a breve.
    Sent from my Desire HD using Tapatalk
  10. #7
    Androidiano L'avatar di dhd79
    Mar 2011
    milano
    XIAOMI REDMI 3
    buongiorno gente
    la sto testando da ieri ed e spettacolare senza alzare il clock e velocissima e fluidissima....sapete se ci sono mod da poter istallare tipo un app draver 5*5?e kernel da flaschare?
    Poi anche a voi quando effettuate una chiamata il nome del contatto e i tasti vivavoce e mic sono accavallati?la fotocamera anche a me funziona perfettamente..sembra anche che come durata batteria non sia male...
    grazie e buon ferragosto
    Xiaomi Redmi 3
    Miui ita 6.5.26
    DesireHD Radio S-Off
    SuperCID
    ROM miui
    Kernel -?
    Galaxy s3
    ROM nu sto capenn nient chiu'
    KERNEL-
    è un missile...
    ASUS transformer tf101g
    rotto
    IPad Mini 16 gb nero...
    non c'e ne
  11. #8
    Mar 2011
    milano
    XIAOMI REDMI 3
    Scusate,
    Un altra cosa..non si collega l'account di hot mail,mi dice che è impossibile collegarsi al server...
    Inviato dal mio Desire HD usando Androidiani App
    Xiaomi Redmi 3
    Miui ita 6.5.26
    SuperCID
    ROM miui
    Kernel -?
    Galaxy s3
    KERNEL-
    è un missile...
    rotto
    non c'e ne
  12. #9
    Jan 2011
    E' stata rilasciata la 2.3
    Ultima modifica di devilrex; 15-08-11 alle 14:16
  13. #10
    Mar 2011
    Prato
    in download...è stato risolto il bug dell'usb?e un'altra domanda...ci sono temi per questa rom con la percentuale della batteria?
