AndroidControl_Tool
    Androidiano VIP L'avatar di adonis
    Nov 2009
    Samsung Galaxy S6 Flat
    Ringraziato 224 volte in 141 Posts
    AndroidControl_Tool
    Hi guys
    I want to introduce you a multi-functional tool which makes your life with your Android device much easier.
    There are so many tools which can do one helpful thing. But here are the most needed things ins one place:
    Features:
    Copy files from device to pc
    Copy files from pc to device
    Normal restart, reboot in bootloader and reboot in recovery
    ADB kill- and start-server, and Remount
    List all on the device installed packages and uninstall, enable and disable them (good against float ware)
    Install apk from pc (internal storage OR SD card)
    Flash radio image
    Flash recovery image
    Flash zImage (Kernel) and kernel-modules
    Flash boot image
    Requirements:
    .NET Framework 3.5 (on your pc)
    Drivers (HTC Sync)
    USB Debugging turned on
    Android Phone
    USB cable
    DOWNLOAD
  2. Il seguente Utente ha ringraziato adonis per il post:
    Berto392 (26-04-11)
    Androidiano VIP L'avatar di labronico
    Feb 2011
    Livorno
    Huawei Mate 20 Pro
    Ringraziato 117 volte in 99 Posts
    Huawei Mate 20 Pro
  5. #3
    Nov 2009
    Thread aggiornato scusate ma non ho manco tempo di respirare ^_^
  6. #4
    Feb 2011
    Livorno
    Huawei Mate 20 Pro
    Quote Originariamente inviato da adonis Visualizza il messaggio
    Thread aggiornato scusate ma non ho manco di respirare ^_^
    no problem
    Huawei Mate 20 Pro
