Pagina 1 di 22 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 218
[KERNEL][June24]-=UNITY V3=-[2.6.35.13][OC/UV][CIFS/TUN][SLQB][V(R)][2WCR]
    Banned
    Jan 2011
    Nuova generazione:-)
    HELLO FLASHMANIACS;-)
    Features:
    Based on Official GB kernel source code from HTC
    Patched to .13
    2-way call records
    SmartAss governor default
    OC up to 1708MHz (Default 245 - 1017MHz @ Ondemand)
    Tweaked Interactive governor
    Tweaked SmartAss governor
    Audio Boosts
    CIFS
    TUN
    CFS
    SLQB
    V(R) I/O scheduler (default)
    BFQ I/O scheduler
    TINY RCU
    EXT4 Support for system partitions (/system, /data, /cache)
    Compatible with:
    All Sense ROM's
    Issues:
    - Kernel Info: Unavailable (you can see it in System Panel app or SetCPU app)
    - you tell me
    Install:
    - Flash via CWM
    Download V1:
    Multiupload.com - upload your files to multiple file hosting sites!
    -_-CHANGELOG-_-
    UNITY V1:
    - Added support HTC Desire Z & HTC My Touch 4G
    - Tweaked video drivers
    - CIFS/TUN/UTF set as modules
    UNITY V2:
    - Reverted new audio drivers
    - Added 2WCR patch for new audio drivers
    - Added Wi-Fi Calling support for T-Mobile users (Kineto GAN)
    - Disabled BFQ / Enabled Deadline
    - Disabled btrfs & ext2 support
    UNITY V3:
    - New OC method with 50 steps
    - New acpu table
    - Fixed kernel info
    - Some cleanups
    download
    Ultima modifica di memnoch; 25-06-11 alle 13:31
    Banned
    Jan 2011
    QUI trovate tutti i kernel buzz e quelli precedenti di @m-deejay
    thanks to @Whiskey103
    Ultima modifica di memnoch; 13-06-11 alle 23:18
    Banned
    Jan 2011
    ACPU Table
    Codice PHP:
    245760pll_3,    52,  61440,  1000vdd_raw(900) },
    368640pll_3,    51,  1228001000vdd_raw(950) },
    768000pll_1,    20,  1536001025vdd_raw(1000) },
    806400pll_2,    30,  1920001025vdd_raw(1025) },
    825600pll_2,    30,  1920001025vdd_raw(1025) },
    844800pll_2,    30,  1920001025vdd_raw(1025) },
    864000pll_2,    30,  1920001025vdd_raw(1025) },
    883200pll_2,    30,  1920001025vdd_raw(1025) },
    902400pll_2,    30,  1920001025vdd_raw(1025) },
    921600pll_2,    30,  1920001025vdd_raw(1025) },
    940800pll_2,    30,  1920001025vdd_raw(1025) },
    960000pll_2,    30,  1920001025vdd_raw(1025) },
    979200pll_2,    30,  1920001025vdd_raw(1025) },
    998400pll_2,    30,  1920001050vdd_raw(1050) },
    1017600pll_2,   30,  1920001075vdd_raw(1075) },
    1036800pll_2,   30,  1920001075vdd_raw(1075) },
    1056000pll_2,   30,  1920001075vdd_raw(1075) },
    1075200pll_2,   30,  1920001075vdd_raw(1075) },
    1094400pll_2,   30,  1920001075vdd_raw(1075) },
    1113600pll_2,   30,  1920001075vdd_raw(1075) },
    1132800pll_2,   30,  1920001075vdd_raw(1075) },
    1152000pll_2,   30,  1920001075vdd_raw(1075) },
    1171200pll_2,   30,  1920001100vdd_raw(1100) },
    1190400pll_2,   30,  1920001125vdd_raw(1125) },
    1209600pll_2,   30,  1920001150vdd_raw(1150) },
    1228800pll_2,   30,  1920001150vdd_raw(1150) },
    1248000pll_2,   30,  1920001150vdd_raw(1150) },
    1267200pll_2,   30,  1920001150vdd_raw(1150) },
    1286400pll_2,   30,  1920001150vdd_raw(1175) },
    1305600pll_2,   30,  1920001175vdd_raw(1175) },
    1324800pll_2,   30,  1920001175vdd_raw(1175) },
    1344000pll_2,   30,  1920001175vdd_raw(1175) },
    1363200pll_2,   30,  1920001200vdd_raw(1200) },
    1382400pll_2,   30,  1920001225vdd_raw(1225) },
    1401600pll_2,   30,  1920001250vdd_raw(1250) },
    1420800pll_2,   30,  1920001250vdd_raw(1250) },
    1440000pll_2,   30,  1920001250vdd_raw(1250) },
    1459200pll_2,   30,  1920001250vdd_raw(1250) },
    1478400pll_2,   30,  1920001275vdd_raw(1275) },
    1497600pll_2,   30,  1920001300vdd_raw(1300) },
    1516800pll_2,   30,  1920001300vdd_raw(1300) },
    1536000pll_2,   30,  1920001300vdd_raw(1300) },
    1555200pll_2,   30,  1920001300vdd_raw(1325) },
    1574400pll_2,   30,  1920001300vdd_raw(1325) },
    1593600pll_2,   30,  1920001300vdd_raw(1350) },
    1612800pll_2,   30,  1920001300vdd_raw(1350) },
    1632000pll_2,   30,  1920001300vdd_raw(1350) },
    1651200pll_2,   30,  1920001300vdd_raw(1350) },
    1670400pll_2,   30,  1920001300vdd_raw(1375) },
    1689600pll_2,   30,  1920001300vdd_raw(1375) },
    1708800pll_2,   30,  1920001300vdd_raw(1400) },
    __________________
    Ultima modifica di memnoch; 25-06-11 alle 13:29
    Banned
    Jan 2011
    io l'ho flashato con la recovery 3.0.0.6 ( ma vanno benissimo anche le versioni successive) sulla rcmix 5.9.1., ho installato no frills impostandolo a 1,018 GHz max e 245 MHz min, governor on demand..credo ke il kernel sia solo OC e nn UV...chiederò a M-Deejay per ora tutto sembra funzionare! A tra un pò con qualche feedback!
    edit: primo bug in versione kernel nn si legge la versione ma solo "unavailable";-)
    re-edit: feedbacks
    No video ( nn si possono registrare e nemmeno guardare on line o scaricare)
    set cpu o no frills nn riescono ad abbassare la frequenza del kernel (che è a 1516 di default)..si riesce però ad impostare la freq. minima e il governor (nn c'è il gov. "smartass"..io cmq avrei usato e uso "ondemand")
    Ultima modifica di memnoch; 25-04-11 alle 20:01
    Banned
    Jan 2011
    versione v.2 pronta
    v.2:
    - Fixed video playback (YouTube, Gallery, etc)
    - Added SMARTASS governor
    - Fixed video 720p record
    - Added Audio boost 20%
    Download:
    ragazzi provate voi ad abbassare la frequenza perchè a me da sempre 1516;-) vabbè che con ondemand la frequenza è ben gestita ma un OC più basso nn guasterebbe;-) anzi..!
    Ultima modifica di memnoch; 25-04-11 alle 20:53
    Androidiano VIP L'avatar di alvarotodini
    Mar 2010
    corchiano vt
    Ringraziato 108 volte in 97 Posts
    Non ti smentisce,6 un grande ;-)
    Sent from my Desire HD using Tapatalk
    Attenzione a Manule Tibaldi di ivrea (TO),è un truffatore
    Senior Droid L'avatar di Guardroid
    Mar 2011
    Bari
    ciao memn.. non avevo visto la tua discussione :P
    non so se provarlo.. fare un nandroid apposta..oppure non c'è il kernel stock del desire s di Spyke da rifleshare eventualmente?
  9. #8
    Banned
    Jan 2011
    Quote Originariamente inviato da Guardroid Visualizza il messaggio
    beh un nandroid lo DEVI avere sempre;-) approffitta e fattelo se vuoi un consiglio!
    cmq..questo kernel sembra davvero ben fatto, l'audio boost è strepitoso e nn provoca fruscii da nessuna parte..le notifiche e la musica dallo speaker sono troppo più alte mi sono ampiamente "lamentato" con M-Deejay su xda per avere la possibilità sacrosanta di "downclockare" la cpu! domani uscira la v.3 con OC a 1800!! se nn ci sarà la possibilità di downclock nn lo installerò
    consumi ok;-) 4\7mA in standby e 106\137mA con screen on e wifi attivo!;-)
  10. Il seguente Utente ha ringraziato memnoch per il post:
    Guardroid (25-04-11)
  11. #9
    Mar 2011
    Bari
    Quote Originariamente inviato da memnoch Visualizza il messaggio
    non downclocca con nofrills? vabbè ci vuole poco a convincermi... nandro e flasho
  12. #10
    Androidiano VIP L'avatar di zzzg
    Jul 2010
    Provincia di Milano
    Galaxy s4
    Ringraziato 108 volte in 105 Posts
    Confermo,funziona fisso a 1516
    Per chi volesse provare e tornare qui c'è il kernel stock
    https://rapidshare.com/files/459149834/2.31Kernel.zip
    Smartphone:SENSATION XE
    ROM : SmartDroid Resurrection
    RADIO: 11.22.3504.07_M
    RIL : 4.0.0013HMQ
  13. I seguenti 2 Utenti hanno ringraziato zzzg per il post:
    Guardroid (25-04-11),savioonline (01-05-11)
