[ROM AOSP] CronosGingerX 1.7.1
		Here is a new release of your favorite Cronos ROM for your Device. This time it has the first release of Cronos X included.
This is still WIP (Work In Progress) by me and Computerfreak so please dont go flaming us about features that are not included.
If you have a wish list of functions please use a proper Forum thread to post them so that we can have a look at it.
NOTE: DOES THE PHONE FEEL SLOW AFTER THE FIRST FLASH?
GO TO X SETTINGS, CPU SETTINGS AND CHANGE THE MINIMUM AND MAXIMUM SPEED TO YOUR DESIRED SPEED.
I HAVE HAD TO PUT A LOWISH DEFAULT THAT IS SAFE FOR EVERY DEVICE.
Release Notes:
26 July 2011 | Cronos Ginger X 1.7.1:
Fixed: Android Battery Drain.
   Please recalibrate your battery.
   Please fully charge the battery to 100%.
X Settings updated to version 0.0.3
Font sizing will stay permanent.
Fixed: ScreenStatus Scaling.
Fixed CRT ON/OFF Lagg.
Fixed 30tweak file, thanks bleep42.
System should be a bit snappier.
Added a new version string for X Settings Mod itself.
Volume rocker wakeup port by ComputerFreak
Enable/disable CRT on/off animationport by Feeyo/Computerfreak
Added option to change the indicator color in the notification widget port by ComputerFreak
Fixed some checkboxed incorrectly checked by default by ComputerFreak
Fixed some incorrect text when selecting brightness mode by ComputerFreak
Feeyo sta facendo una grande lavoro non solo per il desire HD ma anche per tanti altri terminali...
Per ulteriori info QUI bisogna essere registrati.
