[ROM] Core Droid 9.0 sense 3.5
    Jun 2010
    Ragazzi, ho visto dal sito di xda che è finalmente uscita la nuova Core Droid 9.0 con sense 3.5....
    posto il link diretto [ROM][05 JAN]CoreDroid HD V9.0|GB 2.3.5|SENSE 3.5|SUPER SMOOTH|LordMod KERNEL|ONLINE! - xda-developers
    comunque le caratteristiche principali sono le seguenti:
    codice:
    Android 2.3.5 (Gingerbread) HTC Sense 3.5
    Multi-language Including Arabic
    95% Coredroid Skinned (Due too M10 Limitations)
    COREDROID SKIN APK (Most Sense 3.5 widgets parts are skinned.  Make sure to apply skin from personalize)
    Performance optimizations
    Rooted, unsecure boot.img
    Bash command & nano editor
    EXT 4 optimizations
    Ram optimizations
    Keep your home launcher in memory
    Improved overall UI smoothness
    All System apks ZipAling & Optimized
    All User Apps Zipalign at Boot
    init.d scripts support
    Excellent battery life
    Improved auto-brightness values
    Blocked Adds (AddFree App provided for Updates)
    Fully Deodexed
    Enabled GPU UI rendering
    Improved Andreno configuration
    SD Card speed tweak
    CIFS support
    Wi-Fi module improved drivers
    Screenshot by pressing Power and Home
    Advanced Power Menu
    Increased Audio
    Beats Enabled
    All system & 3rd party apps updated to latest
    Keyboard Animation
    Amaze Camera
    Camera performance Improved
    Sony Bravia Engine (HQ Image and Movie improvements)
    Extended Settings in Browser
    Enable/disable Sense unlock animation (carousel effect)
    4 column app drawer or 5 column app drawer (configured in Tweaks)
    CUSTOM personalize button on Sense 3 launcher! (you can choose your own app! Defaults to browser)
    Disable/enable paginated app drawer
    Custom Quick settings (Hide any extended settings you don't want!)
    Ability to hide recent apps in pulldown (hidden by default)
    Clock options (colors/am pm settings/hide)
    Signal options (color/dbm text/hide)
    Battery options (text/automatically colored text based on battery level/hide icon)
    Choose between showing H or 4G in the statusbar
    Center clock!
    Quick-quick settings option (automatically turn to settings when no notifications to clear)
    And much more...
    (fonte CoreDroidRoms : : Get You Connected)
    Sotto con i test!!!
    Ultima modifica di cesco; 06-01-12 alle 00:58
    HTC DESIRE HD - [ROM MIUI ]
    Androidiani Power User L'avatar di cesco
    Sep 2010
    Bg
    TYTN2,desire,desireHD, oneX
    Ringraziato 1,346 volte in 724 Posts
    ragazzi, fateli almeno un po presentabili i thread, scritti cosi' non sono per nulla utili. per il changelog usa il codice BB [CODE] oppure quote, un minimo di presentazione e magari 1 o 2 immagini prese dal thread di XDA. cosi' com'e' crea solo confusione.
    Follow me on:
    <!-- Place this tag where you want the widget to render. -->
    <div class="g-person" data-width="180" data-href="//plus.google.com/113012341277613226011" data-theme="dark" data-rel="author"></div>
    <!-- Place this tag after the last widget tag. -->
    <script type="text/javascript">
    window.___gcfg = {lang: 'it'};
    (function() {
    var po = document.createElement('script'); po.type = 'text/javascript'; po.async = true;
    po.src = 'https://apis.google.com/js/plusone.js';
    var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(po, s);
    </script>
    <br>
    <a class="twitter-timeline" href="https://twitter.com/xcesco89" data-widget-id="398762031488040960">Tweets di @xcesco89</a>
    <script>!function(d,s,id){var js,fjs=d.getElementsByTagName(s)[0],p=/^http:/.test(d.location)?'http':'https';if(!d.getElementB yId(id)){js=d.createElement(s);js.id=id;js.src=p+" ://platform.twitter.com/widgets.js";fjs.parentNode.insertBefore(js,fjs);}} (document,"script","twitter-wjs");</script>
    Androidiani app
    Estensione Androidiani per Google Chrome
    Androidiano L'avatar di dhd79
    Mar 2011
    milano
    XIAOMI REDMI 3
    ciao Gall830 mi verrebbe da chiederti se l'hai provata?
    Xiaomi Redmi 3
    Miui ita 6.5.26
    DesireHD Radio S-Off
    SuperCID
    ROM miui
    Kernel -?
    Galaxy s3
    ROM nu sto capenn nient chiu'
    KERNEL-
    è un missile...
    ASUS transformer tf101g
    rotto
    IPad Mini 16 gb nero...
    non c'e ne
    Jun 2010
    Ciao.. l'ho scaricata ma non sono ancora riuscito a provarla... spero in serata... qualcuno l'ha provata?
    Inviato dal mio HTC Desire HD usando Androidiani App
    Baby Droid L'avatar di HalexTC
    HTC desire hd
    E' bella come sempre,anzi forse piu' delle precedenti versioni,ma purtroppo (almeno per me) è ancora lenta e scattosa e per il momento ho notato che mettendo il silenzioso dalle impostazioni veloci resta tale anche dopo averlo tolto e bisogna usare i tasti laterali per ripristinare il volume.
    Inoltre sarebbe carino se qualcuna di queste nuove rom avesse la fotorubrica ridimensionata.
    Rettifico: dopo aver installato il virtous oc é molto più fluida!davvero molto bene!
    Ultima modifica di HalexTC; 08-01-12 alle 15:43
    HTC DESIRE HD CARBON FIBER by ME
    htc Desire HD Eng S-OFF
    ROM: rcmix runny 4.0
    RADIO: 12.65.60.29U_26.14.04.28_M
    KERNEL: rcmix v8
    Mar 2011
    milano
    XIAOMI REDMI 3
    E vero bella piu di sempre,
    ma ancora scattosa,chi sa se mettendo lo script v6 cambia qualcosina..o e' gia incorporato nella ROM?
    non mi pare di aver visto qualcosa nel cengelog..
    Xiaomi Redmi 3
    Miui ita 6.5.26
    SuperCID
    ROM miui
    Kernel -?
    Galaxy s3
    KERNEL-
    è un missile...
    rotto
    non c'e ne
    Senior Droid L'avatar di Berto392
    Ringraziato 86 volte in 82 Posts
    Quote Originariamente inviato da dhd79 Visualizza il messaggio
    A me scatta solo il Rosie per il resto è molto fluida! Credo che tra non molto ci sarà la patch Ultrasmooth Rosie per portarla in 2D. Poi ci sarà da ridere. Come consumi la trovo veramente fantastica! Riesco a fare quasi 2 ore con WiFi acceso account google in push e meteo ogni 3 ore e push per la locazione.
    Speriamo rimanga così.
    Inviato dal mio Desire HD usando Tapatalk
