Pagina 1 di 231 1231151101 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 2308
[ROM][Aug 29][ACE] Virtuous Unity 2.35.0 Sense 3.0 based on Pyramid1.45.401.2
    Bologna
    Htc One - Desire HD
    Ringraziato 36 volte in 28 Posts
    Virtuous Unity is the first custom Sense 3.0 ROM, scaled for WVGA screens, to be based on an official shipping release from HTC (Pyramid_HTC_Europe_1.28.401.1).
    Download 1.31
    Virtuous ROM: Download
    (Thread xda)
    [ROM][Jul 18][ACE] Virtuous Unity 1.29.0 Sense 3.0 based on Pyramid - xda-developers
    Features
    * Based on the official Sensation shipping ROM (Pyramid_HTC_Europe_1.28.401.1).
    * Ported for full functionality on the HTC DesireZ/G2 and DesireHD. Additional device support is coming soon.
    * Resized for WVGA (800x480) displays, using a purpose built tool to modify HTC.s proprietary m10 binaries, developed by Flemmard and Diamondback.
    * Heavily optimized for fluid performance and usability.
    * Overclocked kernels with numerous additional kernel modules. DHD kernel courtesy of m-deejay, Vision kernel by rmk.
    * Built-in screen state frequency scaling (1.2Ghz-245MHz/ondemand screen-on, 806Mhz-245Mz/conservative screen-off), via custom built virtuous_oc C daemon.
    * Trackpad wake support (DesireZ/G2 and myTouch 4G only).
    * WiFi calling (G2 T-Mobile USA and myTouch 4G only).
    * Fully functional device hardware, including wifi, bluetooth, camera, camcorder, etc.
    * Market-sourced applications (Gmail, Maps, Voice, etc) automatically installed on first boot into /data/app for easy removal.
    * Bloatware and unnecessary applications removed.
    CURRENT VERSION
    Changelog for Virtuous Unity v2.35.0
    Here is the long expected new version of Virtuous Unity. We changed our base to 1.45.401.2 from the official Pyramid RUU. This is a Android 2.3.4 release. And after more than two weeks of beta testing we will provide it fully tested to all of you.
    As there were so many changes it's really hard to make a changelog for this. But we integrate all changes from previous versions into the new one. And we also made some changes which you will hopefully like.
    Enhancements/Features
    Update Base to 1.45.401.2 of Pyramid.
    Reduced overall font sizes.
    Virtuous Unity options in the Settings.
    Configurable Quicksettings.
    Perfect Rosie Integrated.
    Many applications were fully re-sized again.
    Numerous other changes.
    Limitations
    Droid Incredible are currently unsupported, pending patched egl libs.
    Incredible S and Incredible 2 backlight not currently working.
    Download
    DOWNLOAD
    (Size: 410MB | MD5: 8d6f420602d8652ed3a09d39a6366738)
    Changelog for Virtuous Unity v1.31.0
    Bug Fixes
    1. Fixed missalignment of timer on lockscreen
    2. Fixed weather app ® for translated ReelFeel®
    3. Fixed weather app too long translations in detail view (special polish)
    4. Fixed close tab button in browser
    5. Fixed graphic glitch on bottom of calendar (thanks to liamstears)
    6. Fixed graphic glitch on bottom of gallery (thanks to liamstears)
    New Features
    1. Added Cypis’ ‘Amazing Sense’-Theme
    2. Added Transparent-Default-Theme (use this theme if you want transparent Rosie bar)
    1. huge thanks to Cypis for this one too, he did a great job here (wasn’t as easy as it sounds )
    3. Added Virtuous Overclocking Controller app
    4. Added backup and secure folder in MMS app
    5. Added Wifi Ad Hoc mode
    6. Added new locales
    1. Estonia
    2. Latvian
    3. Lithuanian
    4. English Indian
    7. Added partial Arabic support (rest will be available as patch)
    8. Increased read ahead buffers for sdcard
    9. Enabled hearing aid compatibility
    crt patch per Virtuous 26,27,29, 1.31.0
    Add-on %Batteria con caratteri piccoli per 2.35
    MEGAUPLOAD - The leading online storage and file delivery service
    PROCEDURA PER IL FLASH CORRETTO DI QUALSIASI COSA. LE PROCEDURE DESCRITTE FUNZIONERANNO INTEGRALMENTE SOLO CON LE NUOVE RECOVERY 4EXT.
    --Flash della rom. (metodo DEFINITIVO)
    -Riavviare in recovery
    -andare su "Wipe | Format"
    -Selezionare format system, poi data, e poi cache.
    -al termine, eseguire un wipe data factory reset (normalmente cancella i soli dati utente, ma noi serve a rimontare le partizioni GIA' PERFETTAMENTE PULITE CON I FORMAT.
    -ora flashate la rom.
    NOTA: qualsiasi altra procedura è da considerarsi errata. Full wipe , mount vari, altre procedure, sono tutte SBAGLIATE. Questa procedura vi assicura una pulizia molto vicina agli erase da fastboot.
    --Flash del kernel
    -Riavviate in recovery
    --flashate il kernel
    --eseguite un wipe dalvik cache
    --riavviate
    Flash del RIL
    --Riavviate in recovery
    --NON FATE ALCUN MOUNT( anche se vi viene consigliato)
    --flashate il RIL
    --riavviate
    NOTA: se doveste avere problemi nell'applicazione del RIL, postate qui e vedremo di capirci di più.
    Flash dei temi o add-on (tipo sense 3.0 all in one package)
    --riavviate in recevery
    --flashate il tema
    --fate un wipe dalvik
    --riavviate
    --IDEM PER GLI ADDON
    @Lamb69 scusa per l'intrusione;-)
    Memnoch
    Ultima modifica di lamb69; 01-09-11 alle 10:04 - Motivo: agg titolo
  2. I seguenti 6 Utenti hanno ringraziato lamb69 per il post:
    angiotell (27-07-11),Berto392 (02-08-11),danloppa (20-08-11),dimitri12 (03-08-11),pentacolo (04-08-11),RDeckard (07-08-11)
    Androidiano VIP L'avatar di Sinir696
    Apr 2011
    Desire HD
    Ringraziato 48 volte in 39 Posts
    Quote Originariamente inviato da lamb69 Visualizza il messaggio
    http://forum.xda-developers.com/showthread.php?t=1115312
    specifica! è meglio!
    Desire hd completamente sbloccato! mi sembra una descrizione abbastanza completa!
    Nexus 7 preso e sbloccato tutto nello stesso giorno!
  5. #3
    axl409
    ma quale è il senso di aprire un thread così? bah, io proprio non capisco.
  6. #4
    Bologna
    Htc One - Desire HD
    Quote Originariamente inviato da axl409 Visualizza il messaggio
    Era per evidenziare che un'altro "cuoco" ha cominciato a lavorare sulla pyramid ma se crea disturbo cancello immediatamente il thread
  7. #5
    axl409
    non mi disturba assolutamente. anzi! però potevi strutturarlo meglio no? non mettendo solo un link e mettendo come titolo del thread "un altro avventuriero!!". e magari potevi anche mettere la dicitura [ROM] prima del titolo.
    per questi motivo imho è un thread inutile, certo se lo strutturi meglio, ben venga
  8. #6
    Bologna
    Htc One - Desire HD
    mi cospargo il capo di cenere è che non so come si faccia!!!
  9. #7
    axl409
    il titolo non lo puoi rinominare, semmai per quello si aspetta qualche moderatore, però il thread volendo puoi riordinarlo tu, sulla falsariga di come sono strutturati altri thread qui su androidiani, sempre se hai voglia
  10. #8
    Androidiano VIP L'avatar di Ganzdroid
    Aug 2009
    Ringraziato 296 volte in 259 Posts
    Cappero lamb sei un senior member!
    Da cupcake ad oggi:
    HTC Magic 32b (mangiato dal cane) - HTC Desire (venduto) - HTC Desire HD (venduto) - ASUS TFT 101 (venduto) - Galaxy NEXUS (reso) - Nexus 4 (rotto) - Nexus 5 (rotto) - Nexus 7 2013 (rotto) - OnePlus Two (venduto) - Galaxy S8
  11. #9
    Bologna
    Htc One - Desire HD
    Quote Originariamente inviato da Ganzdroid Visualizza il messaggio
  12. #10
    Aug 2009
    Virtuous Unity is the first custom Sense 3.0 ROM, scaled for WVGA screens, to be based on an official shipping release from HTC (Pyramid_HTC_Europe_1.28.401.1). The entire ROM is brand new, taking no application or framework components from any prior Sense 3 releases.
    Vedi se specifichi cosa salta fuori?! Bel lavoro! Potrebbe promettere molto bene. Se la provi dicci come va a fluidità e come rendono gli effeti in 3d della sense 3.0!
    Da cupcake ad oggi:
  13. Il seguente Utente ha ringraziato Ganzdroid per il post:
    zenzolone (23-07-11)
