Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 11
[ROM][4.4.2][HW-VSYNC][LINARO-4.8][OFFICIAL] LiquidSmooth v3.0 BETA
    Androidiano VIP L'avatar di Sduzz
    milano
    htc evo 3d, galaxy s3
    Ringraziato 476 volte in 391 Posts
    Il sottoscritto, il forum Androidiani e il developer Jhonnyslt non si assumo alcuna responsabilità in caso di :
    -brick del telefono
    -distruzione della terra
    - animali che si comportino in modo strano
    -qualsiasi cosa succeda
    LiquidSmooth is e una rom basata sull' Android Open Source Project.
    Creata per garantire la più reattiva, stabile, e veloce rom.
    Liquid0624
    Deadman96385
    jsnweitzel
    Somber73
    TheBr0ken
    Cdub50
    Code:
    MiRaGe Kernel for KitKatKernel overclockable up to 1728 MhzION & PMEM memory allocations!Sweep2WakeUSB OTG support, using powered USB OTG cableLinaro 4.8 GCC ToolchainO3 Strict-Aliasing & ISO C++11 ModeARM Optimized String Handling RoutinesLinaro and Code Aurora OptimaztionsSlims DPI on the flyCustom animation controlsTRDS 3.0 (Liquid Blackout in settings)Active DisplaySlims QuickSettingsHalo (Renamed to bubble in settings)Ram BarT-Mobile Theme EnginePrivacy GuardBuilt in SuperUserWorking wifi TetheringCell BroadcastsSlims Configurable Power MenuSlims Configurable Nav BarGamma Configuration supportCustom animation controls (Listview)LockScreen NotificationsAnd way more than this...
    changelog
    LiquidSmooth source
    kernel source
    bank gapps thread
    BUGS
    3D recording not working
    In-call volume sometimes gets reseted to maximum. Temporary fix:ENABLE TOUCH SOUNDS
    Hdmi not working
    Sending MMS's might not work for everyone, receiving works.
    There are some graphical tears on recorded videos.
    Recording it's working only when started horizontal, on stock camera app
    There is a delay when you start recording a video
    There are some audio issues.
    ART is not working.
    RECOMANDATIONS
    Use the latest 4EXT Recovery
    Do not use superwipes
    Required HBOOT : 1.49.xxxx
    S-OFF
    Radio : 11.77.3504.00P_11.25.3504.06_M get it from
    qui
    4ext recovery
    Follow these exact steps to install the ROM :
    If coming from an other ROM do this :
    1. Wipe data, cache, and system (wipe all partitions except sdcard if on 4ext recovery) if coming from any other ROM
    2. Flash ROM
    3. Flash GAPPS
    4. Reboot
    5. ???
    6. Profit
    If coming from previous build of this ROM :
    1. Wipe cache and dalvik-cache
    2. Flash ROM
    3. Flash GAPPS
    4. Reboot
    5. ???
    6. Profit
    To enable Developer Options and Performance go to Settings > About Phone and repeatedly press Build Number.
    If you have a problem with ADB, update your android-sdk to latest version.
    To enable Advanced reboot menu got Settings > Developer Options > check Advanced reboot
    THANKS TO
    Agrabren
    mrg666
    android1234567(sultanxda)
    Dastin1015
    Helicopter88
    LaidbackNikez
    sjoerd0301
    Bigwillyg
    Evervolv Team
    GOO.IM TEAM
    xda thread:
    http://forum.xda-developers.com/showthread.php?t=2638534
  2. Il seguente Utente ha ringraziato Sduzz per il post:
    danipisca07 (16-11-14)
    milano
    08 March :
    Rom:
    • Replaced Performance Control with Kernel Tweaker
    • Google Recents
    • Fix Active Display crash on some devices
    • Status Bar Color
    • IME animations
    • Custom scrolling values
    • Battery BAr
    • Chaos Labs
    • Chaos App SideBar
    • OTA is now working
    • No need to reflash GAPPS after updating, ROM now has a backup tool
    Kernel:
    • vidc: Clean up memory-type references(sultanxda)
    Issues:
    • Screen capture is not working for us...yet
    md5: e7d83144bb7625493656c4f6a8f75509
  5. #3
    Ho installato questa Rom e la trovo praticamente perfetta...più reattiva e personalizzabile della cyano, ma ha un solo fastidiosissimo bug : spesso e volentieri la tastiera smette di funzionare costringendomi a riavviare il cell per poter scrivere. Spero che risolveranno presto questo difetto altrimenti mi vedrò costretto a passare ad altro.
  6. #4
    Androidiano VIP L'avatar di Snoob
    Torino
    HTC EVO 3D X515m
    Ringraziato 443 volte in 384 Posts
    Quote Originariamente inviato da MattewR1 Visualizza il messaggio
    qualunque tastiera o solo quella inclusa??
    - - merge - -
    Clicca QUI per registrarti a dropbox! Guadagneremo entrambi 500mb di spazio in più
  7. #5
    Qualunque tastiera
  8. #6
    Baby Droid L'avatar di Andrew96ize
    Ferrara
    HTC Evo 3D, Samsung Galaxy S6
    Sapete se è possibile tradurre completamente in italiano questa rom? tempo fa avevo provato una release, notando che molte voci del menù non le avevano tradotte dall'inglese, sebbene avessi selezionato italiano..
  9. #7
    Torino
    HTC EVO 3D X515m
    Quote Originariamente inviato da Andrew96ize Visualizza il messaggio
    è difficile, di solito le traduzioni mancanti sono quelle delle voci delle feature aggiunte, quindi bisogna contattare i creatori della rom! insomma, non ci conterei troppo! a me non sembrano troppo invasive, ma io per dire tengo il 90% delle volte le rom in inglese :P
  10. #8
    Ferrara
    ahh capito.. grazie lo stesso snoob25
  11. #9
    Androidiano L'avatar di danipisca07
    ehyla ragazzi, appena installata, ma come faccio ad acquisire i permessi di root? ho provato a installare i file .zip di superuser e supersu dalla recovery ma quando entro e apro superuser sembra andar tutto bene, vado dentro update su binary e mi dice failed nell'aggiornamento dell' manifest, quindi ho provato ad aggiustare con su binary update fixer ma mi da failed nel gaining root access, nel caso di supersu invece mi dice che non trova i binary di su... :\
    HTC EVO 3D
    Bootloader modificato con metodo HTC-Dev
    Recovery: 4EXT Recovery Touch
    S-OFF con juopunutbear
    ROM: LiquidSmooth v3.0 [4.4.4]
  12. #10
    Torino
    HTC EVO 3D X515m
    Quote Originariamente inviato da danipisca07 Visualizza il messaggio
    la rom è già rootata, non devi fare nulla di tutto ciò! fai un dirty flash della rom, poi vai in impostazioni/info sul telefono, e premi più volte sul numero di build, verranno sbloccate le impostazioni sviluppatore e altre cose, se non trovi superuser nelle impostazioni prova a guardare in impostazioni/sicurezza
  13. Il seguente Utente ha ringraziato Snoob per il post:
    danipisca07 (17-11-14)
