[ROM] Rodriguezstyle MoDaCoMoD V1.5 Clean & Fast
Rodriguezstyle MoDaCoMoD Rom V2.1 Vivid Sense
Only for Rooted HTC Legends
a modded stable mix of MoDaCo Custom ROM r1 & r2 for HTC Legend
Stock Version:1.31.405.4
Radio Version: Last available...47.26.35.04U_7.05.35.26L
Changelog Rodriguezstyle MoDaCoMoD V1.0 - V1.9:
- A2SD added
- Nexus One Live Wallpapers (not with Sense)
- Nexus One Dailer App
- Nexus One Contacts App
- Nexus One Musik Player
- Nexus One Bootanimation as default
- Nexus Deskclock
- Nexus Genie' News and Weather Widget (Transparent)
- Facebook Widget (Transparent)
- MotoDroid Effects & Equlizer
- New Wireless Tether for Legend pre6 by Harry
- Jbed Java
- Spare Parts
- Skype
- Updated Google Maps
- Voice Search added
- Google Googles
- Hi MSN
- Astro File Manager
- Night Stand Clock
- Lock 2.0 as LockScreen (Start it one time to Activate)
- Last Radio Rom added (because reported Wifi/Signal Problems)
- some mods for better Performance
- some mods for Faster Booting
- ROM is Stripped & Zipped to the Maximum
- FW info shows Rodriguezstyle Now
Changelog Rodriguezstyle MoDaCoMoD V2 Vivid Sense:
- Mounted on a New Rom
- all older Features added
- htc.massage.uploader error Fixed
- A2SD Reworked (if it not work Reboot or clean the Caches in Recovery)
- Move Cache app added
- New Default LWP added (Live Sense & Starfield)
- Full LiveWallpaper support with HTC Sense **** canīt believe yeah
read more infos about LWP in Sense here:
http://geekfor.me/fixes/rosie-lwp-fix-opengl/
Deleted:
- Boot Sound
- HTC Lockscreen
- HTC Musik Player (only supports 10 Lpīs)
A2SD:
Note that although applications are moved to SD,
dalvik-cache remains in the data partition. To use A2SD,
you should partition your SD card to have a FAT32 partition first,
then an EXT3 partition second.
in some cases you have Disk Space Error..
resolve this by booting in the recovery mode and wiping the cache & dalvik-cache
MoDaCo Version r1 & r2 (the base of this Rom) Changelog:
# Pre-rooted with su and Superuser Permissions application
# Built with the MCR build process which reduces the size and boosts the speed of the ROM
# Patched 'Rosie' (Sense) to allow click-drag homescreen rearrange when pinch-zoomed out
# busybox with Droid Explorer support
# MCR version displayed in 'About' screen
# OpenVPN binary
# terminfo and settings in boot.img to allow nano etc. use
# Updated 'cachedalvikcache' script
# Odex'd /system/app directory to save space in dalvik-cache
# Added A2SD+ with dalvik-cache on SD
# Temporarily removed HTC_IME mod
# Updated build.prop
# Minor fixes
Download ROM:
Please make a backup of your current System before install !!!
Rodriguezstyle MoDaCoMoD Rom V2.1 Vivid Sense A2SD: [ NEW&STABLE !!! ]
http://rapidshare.com/files/38844616...ivid_Sense.zip
How to install with A2SD? Please read we need swap now !!!
- Format your SD FAT32
- put the Rom on it
- go in the Recovery mode (if your Phone is Rooted you know how)
- and Wipe all options
- install the Rom.zip
- than create a Partition in Superuser
- 32 MB SWAP / 1-1500 MB ext2 / Rest FAT32
- Convert it to ext3
- Reboot (takes a while)
- Login & Reboot again (to cleanup Cache)
ORIGINAL HTC LockScreen & HTC MUSIC App/Widget V2 NEW&WORKING
if you want the Original HTC Lock & Music Player back, install this Zip in Recovery Mode..
http://rapidshare.com/files/38843951...KSCREEN_V2.zip
Thankīs to Paul for the Rom as base, Helix for the Launcher,
dsixda for the Kitchen,Harry for Wireless Tether &
zifnab, jcase & MagnusRagnarok for LWP with Sense
LINK AL THREAD ORIGINALE SU XDA ---> QUI
[ROM] HTC Legend Rodriguezstyle MoDaCoMoD V1.3 fast as Hell!
Io faccio parte dei coraggiosi che non sono riusciti a completare il root! :D
Bloccato allo step 2 con un "device not found" da parte sia di PC che Mac... :(
Siamo diversi su MoDaCo in questa situazione ma non arrivano aiuti!
Re: [ROM] HTC Legend Rodriguezstyle MoDaCoMoD V1.3 fast as Hell!
Boh? Stasera rifaccio la procedura di installazione driver su pc, č l'unica cosa che penso potrebbe interferire nel riconoscere il telefono.
Anche se ho lo stesso problema su Mac, dove driver non esistono....
Sent from my Nexus One using Tapatalk
Root eseguito e giā provata questa Rom. Troppo personalizzata per i miei gusti, market che crasha spesso, non completamente tradotta in italiana.
Sent from my HTC Legend using Tapatalk
