Utente della settimana: 9mm con ben 5 Thanks ricevuti negli ultimi sette giorni
Utente del mese: megthebest con ben 22 Thanks ricevuti nell'ultimo mese
Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 19
[ROM] Rodriguezstyle MoDaCoMoDrOm V2.3 Fix Vivid Sense [Online NOW!!!]
    May 2009
    Pordenone
    Rodriguezstyle MoDaCoMoD Rom V2.3 Fix Vivid Sense
    Only for Rooted HTC Legends
    a modded stable mix of MoDaCo Custom ROM r1 & r2 for HTC Legend
    Stock Version: 1.31.405.4
    Radio Version: 47.26.35.04U_7.05.35.26L
    Changelog Rodriguezstyle MoDaCoMoD V1.0 - V2.2 Fix Vivid Sense:
    codice:
    - A2SD added
    - Nexus One Live Wallpapers (with & without Sense)
    - Nexus One Dailer App
    - Nexus One Contacts App
    - Nexus One Musik Player
    - Nexus One Bootanimation (By Rodriguezstyle)
    - Nexus Deskclock
    - Nexus Genie' News and Weather Widget (Transparent)
    - Facebook Widget (Transparent)
    - MotoDroid Effects & Equlizer
    - New Wireless Tether for Legend pre6 by Harry
    - Jbed Java
    - Spare Parts
    - Skype
    - Updated Google Maps
    - Voice Search added
    - Google Googles
    - Hi MSN
    - Astro File Manager
    - Night Stand Clock
    - Lock 2.0
    - Last Radio Rom added (because reported Wifi/Signal Problems)
    - htc.massage.uploader error Fixed
    - A2SD Reworked (if it not work Reboot or clean the Caches in Recovery)
    - Move Cache app added
    - New Default LWP added (Live Sense & Starfield)
    - Full LiveWallpaper support with HTC Sense **** can´t believe yeah
    - latest Market Version installed on the Phone Core Memory not on SD !!!
    - All Market Problems Fixed Now !!!
    - a lot minor bugs fixed
    - some mods for better Performance
    - some mods for Faster Booting
    - ROM is Stripped & Zipped to the Maximum
    - FW info shows Rodriguezstyle MoDaCoMoDrOm
    Changelog Rodriguezstyle MoDaCoMoD V2.3 Fix Vivid Sense:
    codice:
    - Facebook widget Fixed
    - decompressed apk´s Odex'd directory added to save space in dalvik-cache
    - all working r2 parts added
    - Now 2 Versions with & without A2SD
    - Many FC´s Fixed
    - Finally is the 2.3 without A2SD the only right working MCR r2 Version Online !!!
    Deleted:
    codice:
    - Boot Sound
    - a lot of not needed files (tune up)
    - Big Rings & Wally´s
    solution for htc.message.uploader errors :
    go to:
    Settings / Application / Manage-Apps / htc.message.uploader / Stop / Delete
    works... but i hope it never come back...
    MoDaCo Version r1 & r2 (the base of this Rom) Changelog:
    codice:
    # Pre-rooted with su and Superuser Permissions application
    # Built with the MCR build process which reduces the size and boosts the speed of the ROM
    # Patched 'Rosie' (Sense) to allow click-drag homescreen rearrange when pinch-zoomed out
    # busybox with Droid Explorer support
    # MCR version displayed in 'About' screen
    # OpenVPN binary
    # terminfo and settings in boot.img to allow nano etc. use
    # Updated 'cachedalvikcache' script
    # Odex'd /system/app directory to save space in dalvik-cache
    # Added A2SD+ with dalvik-cache on SD
    # Temporarily removed HTC_IME mod
    # Updated build.prop
    # Minor fixes
    Please make a backup of your current System before install !!!
    Download ROM:
    Version without A2SD
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Version with A2SD (TEST-RELEAS)
    How to install without A2SD?
    codice:
    - put the Rom on it
    - go in the Recovery mode (if your Phone is Rooted you know how)
    - and Wipe all options
    - install the Rom.zip
    - Reboot (takes a while)
    - Login & Reboot again (to cleanup Cache)
    How to install with A2SD? Please read we need swap now !!!
    codice:
    - Format your SD FAT32
    - put the Rom on it
    - than create a Partition in Superuser
    - 32 MB SWAP / 32-1012 MB ext2 / Rest FAT32
    - Convert it to ext3
    A2SD:
    Note that although applications are moved to SD,
    dalvik-cache remains in the data partition. To use A2SD,
    you should partition your SD card to have a FAT32 partition first,
    then an EXT3 partition second.
    in some cases you got Disk Space Error while installing Market apps
    resolve this by booting in the recovery mode and wiping the cache & dalvik-cache
    LWP@SENSE are Patched & Created by Rodriguezstyle don´t share without giving Thank´s & Credits
    Thank´s to Paul,dsixda,Harry,zifnab, jcase & MagnusRagnarok
    __________________
    LINK AL THREAD ORIGINALE
    were you expecting a signature? no! sorry! I've nothing to say.
    Apr 2010
    se qualcuno la mette faccia sapere kome va!!Grz
    May 2010
    io l'ho provata va molto bene rom pulita utile con programmi molto buoni insomma io la sto usando e non ho trovato nessun problema...
    Apr 2010
    Scusate ma come si fa a installarla???? Facendo Flash form SD dalla recovery??
    Ho già rootato il legend eh...
    Feb 2010
    Salerno
    galaxy s4/Htc ONE
    Ringraziato 34 volte in 30 Posts
    Si,devi mettere il file zip sulla microsd,vai in recovery effettui un backup e installi il file zip.
    Apr 2010
    Allora la rom l'ho provata ma sono ritornato a quella di paul, a parte i live wallpapers non c'era nulla di che a mio parere...
    Unica domanda, come entro in recovery? (quello col menu verde per intenderci...)
    Perchè ogni volta lanciare lo script quello di paul mi sembra stupido, c'è una maniera più semplice?
    p.S: Posso installare i live wallpaper senza mettere di nuovo questa rom?? Sai come si fa?
    Feb 2010
    Salerno
    galaxy s4/Htc ONE
    Purtroppo per ora solo recovery-windows.bat e vai in recovery,non ci sono alternative.
    Per i wallpaper non so come aiutarti,personalmente sono una cosa di cui se ne puo' fare a meno.
  9. #8
    Apr 2010
    Si certamente, diciamo che li volevo come sfizio, provati su quella rom devo dire che il Legend non ne soffre assolutamente, non capisco perchè li abbiano bloccati, forse per fare andare sul Desire i gonzi che hanno i soldi per permetterselo
  10. #9
    Androidiano L'avatar di lizz
    Nov 2009
    Questo è l'errore:
    The file could not be found. Please check the download link.
    Non riesco a scaricare il primo link
  11. #10
    Feb 2010
    Salerno
    galaxy s4/Htc ONE
    Vai al tread originale e scarica da li.
