[ROM][32B] TMUS-32B-Froyo-CM6Remix - Official T-Mobile ROOTED
Questa rom si basa sull'ultimo aggiornamento T-mobile OTA con qualche modifica.
Non richiede il cambio Radio/SPL
E' solo in inglese e spagnolo, prima della configurazione iniziale controllate l'APN (con il tasto menu)
Link originale XDA:
[ROM][32B] TMUS-32B-Froyo-CM6Remix - Official T-Mobile ROOTED, 10/18/2010 - xda-developers
10/18/2010 - minor update, APN list updated to match from CM6, WIFI should be working out of the box now.
A FULL WIPE IS REQUIRED. IF YOU DO NOT KNOW HOW TO DO SO WITH FASTBOOT APPLY BELOW ZIP BEFORE FLASHING THE ROM, IF YOU BOOTLOOP, WIPE AGAIN AND REPEAT, IT'S NOT MY ROM, IT'S YOUR PHONE.
wipe /data /cache /system
What you won't get:
JIT - It is off by default and breaks several of the apps in the tmobile package. This sucker is pretty fast without it.
ADW - Launcher2 is default, live with it.
User interface tweaks/ CM Settings
Live Wallpapers
Spare Parts (search the market)
And others...
32A - Flash Stable CM6 bcrook kernel or latest
Mytouch 1.2/Fender LE Current CM6 Kernels contain zinx verituse's patches so no kernel change is required.
G1 DangerSPL or equivalent
Link rom 32/B
Download TMUS-32B-Froyo-CM6Remix.zip from Sendspace.com - send big files the easy way
-or-
