		[ROM] Dirty Unicorns
		http://i.imgur.com/oR0KIrV.png
http://i.imgur.com/R3AxhGJ.png
Dirty Unicorns è una ROM personalizzata , che porta con se una grande personalizzazione e stabilità. L'idea di creare questa rom da parte degli sviluppatori è partita per combattere la noia inizialmente, ma poi è stata trasformata in un mix di dipendenza, insomma un ottimo compromesso per un buon progetto.
 http://i.imgur.com/uBHbp4C.png
Omni-ROM | AOKP | ChaOS | Paranoidandroid | SlimROMs | Preludedrew | Official Testers / Translators | Team Blackout
 http://i.imgur.com/LdRPVIa.png
	codice:
 -- Built-in ad blocker (able to update hosts on the fly)
 -- Ability to disable FC notifications
 -- Enable pointer/user microphone options (screen record)
 -- Download Center (Gapps, Xposed, etc)
 -- Ability to force Expanded Notifications
 -- Over 100 cloud based wallpapers
 -- Facebook Sync Hack
 -- Immersive mode
 -- Hot Reboot In Power Menu
 -- Appbar (app sidebar)
 -- Customizable Quick Settings
 -- Customizable power menu
 -- Customizable lockscreen shortcuts
 -- App Ops access in Settings
 -- TRDS (built in theme in settings)
 -- Statusbar Clock options
 -- NavBar Options
 -- Halo (multi-tasking tool)
 -- Halo size/color changer
 -- Hardware key remap mod (only for HW button devices)
 -- Battery Bar / Circle batteries
 -- Network speed indicators in statusbar
 -- SuperSU (chainfire)
 -- Build.prop mods
 -- Init.d Tweaks
 -- Active Display (Moto X notifications)
 -- ListView Animations
 -- Custom System Animations
 -- Toast Animations
 -- Custom BusyDialog
 -- Advanced Low Battery Indicator options
 -- ScreenShot QuickTrash
 -- Color Changing PhaseBeam
 -- Gesture Anywhere
 -- Button Light Notification
 -- Statusbar Color options
 -- OmniSwitch (multi-tasking tool)
 -- Driving Mode
 -- Lockscreen theme options
 -- Lockscreen notifications / options
 -- System App Remover
 -- Identicons
 -- Suspend Actions
 -- Wakelock Actions
 -- SlimROM based recents
 -- Contextual notification panel headers
 -- SlimROMs privacy guard
 -- Blacklist calls/sms
 -- E molto altro, lo trovate nei Dirty Tweaks!!!
 CHANGELOG
	codice:
 8.2 - 11/04/14
 - Kernel updates
 - Disable/Enable screenshot sound
 - Navbar: Custom Glow Time
 - SystemUI: Fix crash during notification/theme change
 - Bring back color changer for MIUI-like carrier label
 - Fix carrier label not sticking after a reboot
 - Fixed clear-all button bug
 - Fix auto rotation/battery tile long press
 - Double tap to sleep on navigation bar
 - Add Voice Dialer back
 - Support full size application screenshots
 - Fix bootanimation cut off on HDPI devices
 - NavRing: Last App
 - Fix long press app circlebar QS tile
 DOWNLOAD
DU_4.4.4_v.8.2
GAPPS
		Ragazzi potete riuppare il file delle gapps? è offline
				Originariamente inviato da  Moxy
 Ok sistemato il link in prima per le GAPPS
		Grz mille nightcervant :), l'hai provata?? Consumi?? Poi ti volevo chiedere una cosa in privato se posso
 P.S. scusami un altra cosa, quale gapps devo scaricare ?? Full Modular o Google Stock?? Grazie
 La usavo su M7, sul M8 uso la ViperOne per ora, comunque io ti consiglio le Google Stock ;) puoi chiedere anche qui
		Hai qualche consiglio da darmi per migliorare autonomia batteria?? Se mi consigli di cambiare kernel e mettere l'lelementalx, mi dici quale impostazioni potrei mettere per un uso prolungato dello smartphone?? Vedi tu se mi riesci a dare qualche dritta. Grazie in anticipo :)
 Con questo tipo di rom non puoi installare il kernel ElementalX, già con il kernel stock dovresti trovarti bene, essendo un AOSP. ;)
		Un ultima cosa, so che su queste rom puoi installare blinkeed è vero?? Se si mi dai qualche guida??? Mi trovo molto con blinkfeed e non vorrei abbandonarlo :)
 P.s. ( mi vengono in mente sempre dopo ) non posso installare manco la versione ElementalX per la rom google stock?? Non è compatibile ??
 Purtroppo non ho mai installato blinkfeed però faccio una ricerca e ti scrivo la soluzione qui
		Sei gentilissimo Grazie :)
