[ROM] SinLessROM | GPE
http://s7.postimg.org/oldujx5hn/lordminimal.png
http://s8.postimg.org/wx6r1lk6t/featuresbutton.png
codice:
-KTU84P.H1 (Android 4.4.4)
-DeOdex (ART Works in ART Version)
-Busyboxed
-Rooted
-TN's Own Kernel SinLessKernel (Features Below)
-Native Heads Up Notifications (TN & Audiophile Versions)
-Native Screenrecord (In Power Menu) (TN & Audiophile Versions)
-Added Volume Wake Options (TN & Audiophile Versions)
-Added Volume Media Controls (TN & Audiophile Versions)
-Disable CRT Screen Off Option (TN & Audiophile Versions)
-Don't Wake Phone If Unplugged Option (TN & Audiophile Versions)
-Hide Input Notification Option (TN & Audiophile Versions)
-Google Gallery Added
-Native APM+Screenshot
-Team Nocturnal Settings with many options to choose
-Status Bar Options in TN Settings
-Battery Customizations in TN Settings
-Clock Customization in TN Settings
-App Ops (Permissions)
-build.prop tweaks
-All system apps zipaligned for better ram optimization
-Zipalign on boot data and system
-Debloted (Deleted Google Apps which can be installed via Playstore)
-Fast and Clean (Buttery Smooth)
-Some AOSP goodies
-Pie Controls (LMT or GravityBox)
-Mms with extra options including Emoji support (Inverted ver. In post 3)
-System Tweaks
-Custom Bootanimation
-File Explorer
-Performance Enhanced Tweaks
-Zero Compressed on all apks (System and Data)
-Sqlite3 Tweaks
-Better RAM Optimization Tweaks
-Fantastic battery life
-Sound Enhancements
-and endless/countless customizations
http://s21.postimg.org/ffubo8bhj/changelog.png
codice:
v5.0.0 December 8th 2014
-Updated base to Android 5.0.1
-Rooted with SuperSU
-Busy Box
-Boot.IMG made insecure
-Ext SD Card Write Added
-Symlinkinked ext SD card
-Highly Debloated (Can download via playstore)
-Added Google Messenger
-Added CM11 Gallery
-Tweaked System for better performance
-Ram Optimization Tweaks
-build.prop tweaks
-more I'm forgetting
-Initial release...much more coming in the future
http://s29.postimg.org/yls137xrb/downloads.png
SINLESSROM V.5.0.0
Aggiornato op con download della nuova versione 4.0.0 per ora nessun changelog, la rom e' basata su android lollipop
Aggiornata rom alla 4.0.1 con download e changelog
la1bussola87
Per forza con philz?
Sembra che con la Phil si raggirano un sacco di problemi con la nav bar
Aggiornata OP con la versione 5.0 della ROM
nightcervant
ce l radio fm ??
arhan
ce l radio fm ??
No devi vedere sul playstore se c'è
