Visualizzazione dei risultati da 1 a 10 su 48
[ROM] Android Revolution HD | High Quality & Performance | Android 4.4.2 KitKat
    Zof
    Zof non è in linea
    Androidiani Power User L'avatar di Zof
    Parma
    One Plus 3
    Ringraziato 891 volte in 595 Posts
    Lightbulb
    Vi presentiamo con orgoglio una delle ROM più famose per HTC One...
    I Pareri degli users di XDA:
    "My phone is now perfectly smooth, fast, stable. I do not expect much more from my phone!"
    DarkAdrien
    "This release is amazing! ROM feels super fast! Great job Mike & the team! (...) Never noticed any lag. 1 word: brilliant."
    Selec1
    "Feels a lot smoother in use - scrolling, swiping between sense screens. Much nicer feel. This is a real good one, Mike. Many thanks "
    dsm52
    Informazioni sulla ROM
    Dettagli del sistema:
    • Android 4.4.2 (KitKat) - latest official HTC One 1.54.401.5 (WWE) firmware (2.x series)
    • This is improved version of stock ROM - no visual changes!
    • Very fast, clean & stable!
    • Full HTC Sense 6.0 Interface
    • Multi-language (WWE)
    • For HTC One M8 UL
    • Thanks to HTC for the base firmware
    Dettagli del Kernel:
    • Stock kernel (the most stable)
    Informazioni sulla Rom:
    • Removed software (CPU) rendering - full Snapdragon 801 (GPU) rendering
    • Fully optimized and tweaked
    • Root access
    • Unsecured boot.img
    • Newest BusyBox
    • RAM optimizations
    • System signatures check enabled for system security and safety
    • Improved virtual memory management
    • Speed optimizations
    • Enabled GPU UI rendering
    • Data, cache and system partitions mounting tweaks
    • Bloatware applications removed
    • All /system applications updated to latest available
    • All /data applications updated to latest available
    • Improved CPU governors performance
    • Most optimal system scheduler
    • Disabled kernel debugging for better performance
    • Zipaligned (Improved RAM management)
    • Zipalign on boot (for user applications on data partition)
    • Fully de-odexed
    • init.d scripts (BusyBox run-parts) support
    • Auto init.d permissions set on boot
    • sysro/sysrw commands support
    • Excellent battery life!
    • Improved EXT4 performance
    • OpenVPN support
    • Most up-to-date system files permissions
    • Adobe Flash Player support
    • Support almost 24h a day
    • ...and many more!
    Cosa ti serve:
    • HTC One unlocked with htcdev.com (S-ON) or S-OFF
    • Custom recovery
    Come Installare la ROM:
    • Download ROM and place it on your virtual SD card
    • Boot your phone in recovery mode (vol down + power)
    • In main menu, select "install zip from sdcard"
    • Select "choose zip from sdcard" and browse to the location of Android Revolution ROM
    • You can use data wiping option in AROMA (optionally if coming from earlier version of my ROM, obligatory if coming from stock or other custom ROM)
    • After flashing process is complete, reboot the device
    Changelog
    Android Revolution HD 10.2
    --- release date: 30 July 2014 ---
    • Fixed kernel module to disable system R/W protection (Thanks to Lizard)
    • Updated Sense 6 Toolbox to latest 1.3.3
    • Updated Harman & Kardon mod to latest 4.0 (no ADSP included) (Thanks to scrosler)
    • Updated HTC Clock
    • Updated HTC Video Hub
    • Other minor changes and fixes
    • Included and updated applications:
    - If your current firmware version doesn't match ROM firmware version, wiping data inside AROMA is highly recommended!
    precedenti:
    Downloads
    CLICCA QUI
    CREDITS: XDA-developers
    precedenti:
    Ultima modifica di Zof; 03-08-14 alle 22:06
    Senior Editor @ Androidiani.com -> Stefano
    Follow me on Twitter-> Stefano
    Follow me on Instagram-> Stefano
    Follow me on Spotify-> Stefano
  2. Il seguente Utente ha ringraziato Zof per il post:
    ultimo125 (20-04-14)
    Zof
    Zof non è in linea
    Parma
    One Plus 3
    riservato per uso futuro
  5. #3
    Zof
    Zof non è in linea
    Parma
    One Plus 3
    ancora uno non si sa mai
  6. #4
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,317 volte in 3,365 Posts
    Android Revolution HD 3.2
    --- release date: 3 April 2014 ---
    • Added system RW protection module by @flar2
    • Improved AROMA installer (@Electronic Punk)
    • Update Sense components
    Ultima modifica di Zof; 31-05-14 alle 16:11
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
  7. Il seguente Utente ha ringraziato iLuke per il post:
  8. #5
    Apr 2014
    o installato lultima rom Android Revolution HD 5.5. con audio harman/kardon pero se ascolto gli mp3 non si sente niente muto
  9. #6
    Zof
    Zof non è in linea
    Parma
    One Plus 3
    Quote Originariamente inviato da puffo56 Visualizza il messaggio
    L'italiano non è un optional, sei in un forum pubblico esprimiti con un linguaggio decente. Non pretendo che tu usi termini eruditi, ma almeno rispettare le basilari regole grammaticali della scuola elementare..... Ti assicuro che leggere quello che scrivi è un pugno nell'occhio.
    Spero che questa sia l'ultima volta in cui dobbiamo richiamarti per il tuo linguaggio, evita di reiterare il comportamento se vieni infrazionato da un Mod....
  10. Il seguente Utente ha ringraziato Zof per il post:
    lallo29 (27-05-14)
  11. #7
    Androidiano VIP L'avatar di ultimo125
    Brindisi (Prov)
    new "HTC ONE M8"
    Ringraziato 1,479 volte in 1,230 Posts
    --- release date: 12 May 2014 ---
    • Improved US AT&T support
    • Added US Sprint support
    • Added US Verizon support
    • Added Harman & Kardon mod to AROMA installer (baadnewz)
    • Updated Sense 6 Toolbox to 1.1
    • Updated all custom applications
    • Updated all Google applications
    • Updated FitBit, VideoHub, Guide & DotMatrix
    • Updated Superuser by Chainfire
    • Updated Xposed
    • Fixed format of system partition
    • Many fixes in the updater script
    Se la versione attuale del firmware non corrisponde alla versione del firmware ROM,
    un WIPE DATA all'interno AROMA è altamente raccomandato !
    --- MD5 Checksum: 3E264D0D54DEBEFB1071476BC8E538A9 ---
    SE TI SONO STATO UTILE PUOI RICAMBIARE CON UN "THANKS"
    Twitter ---- Google+
  12. Il seguente Utente ha ringraziato ultimo125 per il post:
    iLuke (17-05-14)
  13. #8
    Quote Originariamente inviato da ultimo125 Visualizza il messaggio
    • Updated Xposed
    ragazzi ho bisogno del vostro aiuto.
    ho appena acquistato il mio htc m8, ho messo la recovery, ho fatto il root, ed installato questa rom versione 7.0!
    dal primo avvio il telefono mi ha chiesto l'aggiornamento al software: 1.54.401.5 che non ho fatto, sapete dirmi se è il caso che io lo faccia??
    inoltre, perche la sense non mi funziona?? ho i moduli attivi, ma non va.. come mai?? grazie in anticipo
  14. #9
    Zof
    Zof non è in linea
    Parma
    One Plus 3
    Android Revolution HD 7.0
    --- release date: 22 May 2014 ---
    • Based on latest 1.54.401.10 HTC update
    • Updated Xposed
  15. #10
    Senior Droid L'avatar di kintaxfuera
    Nov 2010
    HTC ONE M8, NEXUS 7 LTE
    Ringraziato 47 volte in 46 Posts
    Davvero perfetta questa arhd 7.0
