[MOD] ModPack per HTC SENSE |
    Androidiano VIP L'avatar di nightcervant
    HTC ONE
    Ringraziato 638 volte in 485 Posts
    Lo sviluppatore Lapayota ha creato questo pacchetto di mod che permette di personalizzare le vostre rom Lollipop come meglio credete, inoltre è una vera manna dal cielo in quanto per il momento la personalizzazione delle rom è veramente limitata:
    Testato su base FW: 4.16.401.9 / 4.16.1540.8
    Versione Android: 5.0.1
    Ecco le modifiche che potrete scegliere in AROMA durante il FLASH:
    v.10
    codice:
    longpress backkey kill app
    advanced power menu
    menu navbar persist
    battery %
    change navbar size (48/42/36/32 dpi)
    sweep 2 sleep
    kernel tweaks
    build.prop tweaks
    clean all recent apps for Google card view style
    remove search bar from recents
    centered clock
    right corner pulldown qs
    15 tiles qs
    disable exchange security
    display DPI (480 | 440 | 420 | 400 | 370 | 340 | 300 | 200)
    recent apps button (Settings->display)
    Prism menu
    Flashlight QS Tile
    allow prism landscape
    increase volume steps (20 for media, 7 for others)
    system tweaks (hide alarm notify | hide bluetooth notify | hide headphones notify | hide volume notify | hide gps notify | hide clock | hide am/pm | hide nfc icon | hide power saver | clean data cach)
    data trafic indicator (white | blue | pink | red | green | yellow)
    longpress volume key (show ambient display | Dwn play(pause)/Up skip to next | Dwn skip to previous/Up skip to next )
    ambient display (Settings->display)
    enable 2G only option
    enable music channel
    double tap to sleep status bar
    support voice recording (HTC Dialer -> in call menu, after connection)
    big caller photo
    hide battery (always show | hide with label enabled | always hide)
    flashlight on power longpress
    You can change this options any time, just reflash modPack.
    CREDITS
    dmonium - 15 tiles qs
    blubbers - disable exchange security
    w00dstock - Flashlight QS Tile
    baadnewz - data trafic indicator
    DOWNLOAD #010
    Ultima modifica di nightcervant; 13-02-15 alle 09:53
    HTC ONE
    riservatooooooo
    HTC ONE
    Aggiornato alla versione 7
    Androidiano L'avatar di la1bussola87
    Sep 2014
    Ringraziato 19 volte in 19 Posts
    Non ce il modo per mettere la foto grande alla ricezione e invio di chiamate?
    HTC ONE
    Aggiornato alla versione 8
    Androidiano L'avatar di mak81
    HTC ONE M8 & Galaxy S4 mini
    Con la v. 10 si può mettere la foto grande, basta sceglierlo nelle opzioni. Ma per disinstallarlo secondo voi come si fa? si fa un flash disattivando tutto???
    HTC One (M8) With Samsung EVO 64 GB
    -ViperOne 5.0.1
    iPhone 5 32 Gb
    - 9.2 no Jailbreak
    HTC ONE
    Update versione 10
  9. #8
    Quote Originariamente inviato da nightcervant Visualizza il messaggio
    Update versione 10
    Disponibile la v12, ma una domanda, se volessi disinstallarlo?? Da Aroma non ci ho fatto caso se è possibile farlo, si fa da lì?
    -ViperOne 5.0.1
    iPhone 5 32 Gb
    - 9.2 no Jailbreak
