[ROM] GPE 5.0.1 | CyanoGen Mod Funzioni | Stabile
http://i.imgur.com/KNadSmw.png
http://i.imgur.com/zkuAxKG.png
FUTURES:
-5.0.1 LXR22C.H5 Google Play Edition from graffixnyc
-No rom branding
-Rooted
-Busybox
-Zip aligned
-App ops in security settings
-Advanced power menu
-Clear all in recents
-Expandable volume panel, link/un-link notifications to ringtone
-5.0.2 power off color fade memory bug fix.
-Aroma Options
--Dark material theme / settings, phone, contacts, calculator, framework-re (work in progress)
--Darker material theme
--Moto X camera & gallery
--Sense camera & gallery
--CyanogenMod apps (audioFX, browser, calendar, trebuchet launcher, file manager, music, gallery, sound recorder)
--AOSP email
--HTC keyboard
--MMS apps
--Live wallpapers
--Audio mods (viper4android, volume boost, cyanogenmod ringtones)
--Colorful navbar (mimics status bar)
--De-Bloat menu
--Stock kernel
--Quantum kernel (special thanks to PwnCakes193)
--ElementalX kernel (special thanks to @flar2)
--Elite kernel (special thanks to @buckmarble)
--CodeCraft kernel (special thanks to @Evolutionmods)
-Custom extra settings (change in real time)
--Display
--Screen density (DPI)
--Power saver color (change the battery saver status bar warning color
--Show search bar in recents
--Show clear all recents button
--Location of clear all button
--Status bar
--Show alarm icon
--Show weather in notification header
--Double tap to sleep
--Network traffic meter
--Enable ticker
--Clock position
--AM/PM style
--Day of the week style
--Battery style
--Battery percent options
--Enable/Disable heads up
--Heads up timeout
--Quick Settings tile reorder
--One finger quick settings
--Navigation bar
--Long press recents
--Long press back to kill
--Navigation bar height
--Show arrow keys on navbar while typing
--Navigation bar layout
--Navigation ring targets
--Volume buttons
--Volume panel timeout
--Enable/Disable volume notification sounds
--Volume keys move cursor
--Music Controls, long press up action, long press down action, timeout
--Lock screen
--Quick unlock
--Scramble pin
--Display music visualizer
--Lock screen shortcuts
INSTRUZIONI AL FLASH
E' VIVAMENTE CONSIGLIATO MONTARE L'ULTIMO FW SENSE O CONVERTIRE IL TERMINALE IN GPE
Raccomandiamo la recovery Philz 6.25.x o TWRP 2.8.4.0+
1)Copiare la rom sul terminale/SD e avviare l'installazione da recovery
2)Selezionare il metodo d'installazione (Custom o Default)
3)Seguire le istruzioni in AROMA
4)Riavviare ed Enjoy
Download
M8-GPE-16-03-2015
md5: 15dfcd88561fd492835bd7446292a2a6
ANDROIDFILEHOST
