Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 40
[ROM] Android Revolution HD • ART • High Quality & Performance
    Androidiano VIP L'avatar di nightcervant
    HTC ONE
    Ringraziato 638 volte in 485 Posts
    "My phone is now perfectly smooth, fast, stable. I do not expect much more from my phone!"
    DarkAdrien
    "This release is amazing! ROM feels super fast! Great job Mike & the team! (...) Never noticed any lag. 1 word: brilliant."
    Selec1
    "Feels a lot smoother in use - scrolling, swiping between sense screens. Much nicer feel. This is a real good one, Mike. Many thanks "
    dsm52
    System details:
    Android 5.0.1 (Lollipop) - latest official HTC One 4.16.1540.8 (WWE) firmware (3x.x series)
    Android 4.4.4 (KitKat) - latest official HTC One 3.28.401.9 (WWE) firmware (2x.x series)
    Android 4.4.4 (KitKat) - latest *STOCK* ROMs without modifications ---> click here
    This is improved version of stock ROM - no visual changes!
    Very fast, clean & stable!
    Full HTC Sense 6.0 Interface
    Multi-language (WWE)
    For HTC One M8
    Thanks to HTC for the base firmware
    Included kernel details:
    Stock kernel (the most stable)
    ROM details:
    Removed software (CPU) rendering - full Snapdragon 801 (GPU) rendering
    Fully optimized and tweaked
    Root access
    Unsecured boot.img
    Newest BusyBox
    RAM optimizations
    System signatures check enabled for system security and safety
    Improved virtual memory management
    Speed optimizations
    Enabled GPU UI rendering
    Data, cache and system partitions mounting tweaks
    Bloatware applications removed
    All /system applications updated to latest available
    All /data applications updated to latest available
    Improved CPU governors performance
    Most optimal system scheduler
    Disabled kernel debugging for better performance
    Zipaligned (Improved RAM management)
    Zipalign on boot (for user applications on data partition)
    Fully de-odexed
    init.d scripts (BusyBox run-parts) support
    Auto init.d permissions set on boot
    sysro/sysrw commands support
    Excellent battery life!
    Improved EXT4 performance
    OpenVPN support
    Most up-to-date system files permissions
    Adobe Flash Player support
    Support almost 24h a day
    ...and many more!
    You need:
    HTC One unlocked with htcdev.com (S-ON) or S-OFF
    Custom recovery
    How to flash:
    Download ROM and place it on your virtual SD card
    Boot your phone in recovery mode (vol down + power)
    In main menu, select "install zip from sdcard"
    Select "choose zip from sdcard" and browse to the location of Android Revolution ROM
    You can use data wiping option in AROMA (optionally if coming from earlier version of my ROM, obligatory if coming from stock or other custom ROM)
    After flashing process is complete, reboot the device
    Android Revolution HD 40.2
    --- release date: 17 March 2015 ---
    Based on the M8 software with ported Sense 7.0 components
    This approach gives you the most stable build, because all hardware
    components are working with original libraries and drivers.
    Other minor changes and fixes
    Included and updated applications:
    Android Revolution HD 40.3 LOLLIPOP 5.0.1 - SENSE 7
    Android Revolution HD 22.2
    --- MD5 Checksum: 532B25DE7BDCCCD4FC8BF5F3400CBBBF ---
    3.xx.xxx.x (f.g. 3.28.xxx.x) firmware is required for proper Wi-Fi work
    Ultima modifica di nightcervant; 18-03-15 alle 09:14
    HTC ONE
    Sense 6 Toolbox
    by Mikanoshi & langer hans
    What is Sense 6 Toolbox?
    Sense 6 Toolbox module contains a large variety of mods that will improve almost every aspect of your Sense device. You have to have Xposed installed to use these mods. For more info about Xposed refer to the original thread.
    A note about compatibility. We develop the toolbox on ARHD on the HTC One M7 and M8. That ensures that every mod is compatible with ARHD. We can't test the mods on every other ROM. But as long as the ROM is near stock without deep changes, it should work there too. For the best and most complete experience I recommend using ARHD.
    Which mods are included?
    For a complete list, please head over to Sense 6 Toolbox - List of Mods.
    Here is a summary:
    Interface mods
    Transparent statusbar and notification drawer
    Center clock, AM/PM removal, traffic meter, horizontal EQS
    Gestures to manipulate recent apps and additional information about each app, AOSP styled recents
    [Sense 6] Custom color themes for every app
    Statusbar mods
    Icons by vomer (CleanBeam)
    Customizable color themes for all new statusbar icons
    Ability to hide icons
    Sense mods
    Transparency for many UI elements (dock, clock widget, app drawer, folders, etc)
    Infinite apps in folders, 7 home screens, home popup menu, more grid options for homescreens and app drawer
    Actions for vertical swipes and shaking on homescreens, horizontal swipes on dock
    Messaging mods
    Wake on SMS, increase MMS size
    Replace delivery notifications with toasts
    Increase MMS size
    Controls mods
    Volume2wake
    Activate flashlight on power long press
    Bind actions to hardware buttons (Back long press and swipe up from Home)
    Bind actions to volume keys for camera and music playback controls
    [M8] Smaller softkey bar
    Various mods
    Advanced Power Menu
    Show more information about installed apps and apps that are being installed
    Improved screen locking and unlocking
    Hardware buttons backlight control
    Large caller photo in dialer and on lockscreen during calls
    Disable unwanted notifications and confirmation dialogs
    On/off screen animations (Fade, CRT)
    How to use the Toolbox?
    First you must have Xposed Framework installed (more Info here). After that enable the Sense 6 Toolbox module in the Xposed Installer, set up the mods you like and tap 'Soft Reboot' icon to apply them.
    Backup functionality
    Toolbox supports settings backup and restore using default Andriod cloud capabilities. Enable backup in Settings > Backup & reset. Now every time you uninstall and install Toolbox its settings will be automatically restored. If you want to save/restore settings between reinstallations, use local backup on SDCard function (its button is next to Hot Reboot).
    Changelog:
    1.4.5:
    [New] Haptic feedback duration options for navigation keys, long press and Sense keyboard
    [New] Display alarm icon only for defined number of hours before alarm
    [New] Tap statusbar to scroll to top in Google Play Store
    [Changed] EQS tile added for Music Channel mod
    [Changed] Sense 6 themes performance and compatibility improvements
    [Fixed] Hide USB icon
    [Fixed] Various mod fixes
    DOWNLOAD SENSE 6 TOOLBOX APK
    Ultima modifica di nightcervant; 12-01-15 alle 09:40
    HTC ONE
    Gli alieni sono tra di noiiiiiiiiiiii - riservatoooooo-
    HTC ONE
    Lo sviluppatore informa che questo week-end verrà rilasciata la ARHD 30.0 con montato ANDROID LOLLIPOP
    Androidiano L'avatar di eddy75
    Foggia
    Honor view 10 lite
    Disponibile al download "Android Revolition HD 30.1".......
    HTC ONE
    Aggiornata OP con changelog e DOWNLOAD della nuova versione Buon Lollipop a tutti
    Ultima modifica di nightcervant; 14-01-15 alle 09:12
    Androidiano L'avatar di fabio9090
    Nexus 5
    Ringraziato 24 volte in 18 Posts
    sto avendo problemi a scrivere e leggere sulla SD, quando provo a scaricare un file mi dice che <senza nome> download fallito, ho gia avuto questo problema con la skydragon ma non ricordo la soluzione, mi pare si trattasse di una formattazione diversa...
    qualcuno mi sa aiutare?
    S off
    Firmware 4.xx.xxxx.x
    android revolution hd 30.1
  9. #8
    Senior Droid L'avatar di nerlim
    Apr 2010
    toscana
    op7
    Ringraziato 48 volte in 48 Posts
    Ciao, qualcuno ha avuto il problema Wi-Fi ??? Secondo me andrà aggiornato l'hboot anche in questo caso.
    Inviato dal mio HTC One_M8 usando Androidiani App
  10. #9
    Da viperone basta solo mettere la 30.1 su sd ed installare? E c'è sul serio il problema del wifi? E facendo un nandroid della viper , installando questa se non mi va bene ripristinando il backup della viper ritorno come prima o devo prima flashare qualche firmware in particolare prima del ripristino del nandroid backup? Grazie
    Cellulari posseduti:
    Samsung Galaxy S3 Con ROM PORTING S4
    Samsung Galaxy Note II Con ROM DITTO NOTE 3
    Samsung Galaxy Note III Con Rom X NOTE
    Samsung Galaxy S5 STOCK
    LG G3 Sphinx G3 NEO V2.0 Final
    HTC One M8 con ROM ViperONE M8
    Samsung Galaxy Note 4 STOCK (e ne vado fiero )
  11. #10
    Androidiano VIP L'avatar di sirio87s
    Jan 2011
    Lucera (FG)
    nokia. poi è arrivato android!
    Ringraziato 132 volte in 115 Posts
    qualcuno ha provato la ARHD 30? come va? bug?
    USA I TASTI CERCA E THANKS!
