[rom] android revolution hd
http://xda3.androidrevolution.org/db...s/one_2015.png
http://xda3.androidrevolution.org/db...rs/5/about.png
Versione del Sistema:
Android 5.0.2 (Lollipop) - latest official HTC One 1.32.401.15 (WWE) firmware (34.x series)
This is improved version of stock ROM - no visual changes!
Very fast, clean & stable!
Full HTC Sense 7.0 Interface
Multi-language (WWE)
For HTC One M9
Thanks to HTC for the base firmware
Stock kernel (the most stable)
Dettagli della ROM:
Removed software (CPU) rendering - full Snapdragon 810 (GPU) rendering
Fully optimized and tweaked
Root access
Unsecured boot.img
Newest BusyBox
RAM optimizations
System signatures check enabled for system security and safety
Improved virtual memory management
Speed optimizations
Enabled GPU UI rendering
Data, cache and system partitions mounting tweaks
Bloatware applications removed
All /system applications updated to latest available
All /data applications updated to latest available
Improved CPU governors performance
Most optimal system scheduler
Disabled kernel debugging for better performance
Zipaligned (Improved RAM management)
Zipalign on boot (for user applications on data partition)
Fully de-odexed
init.d scripts (BusyBox run-parts) support
Auto init.d permissions set on boot
sysro/sysrw commands support
Excellent battery life!
Improved EXT4 performance
OpenVPN support
Most up-to-date system files permissions
Adobe Flash Player support
Support almost 24h a day
...and many more!
Requisiti:
HTC One M9 con bootloader sbloccato
Custom recovery
root
Istruzioni:
Usare l'ultima TWRP Beta da qui:
[RECOVERY][Hima] TWRP touch recovery | HTC One (M9) | XDA Forums
prestando attenzione al punto 2 per preservare la possibilità di ritornare full stock e di continuare a poter ricevere gli OTA senza l'uso di una RUU
Scarica la ROM e mettila nella memoria interna del telefono
Avvia il telefono in recovery mode (vol down + power)
Nel menù iniziale seleziona "install zip from sdcard"
Seleziona "choose zip from sdcard" e scrolla fino a trovare il file Android Revolution ROM
OBBLIGATORIO effettuare un wipe completo del telefono, fattibile sia da AROMA che da recovery
Dopo il processo di flash, effettua il restart del dispositivo
http://xda3.androidrevolution.org/db.../changelog.png
Android Revolution HD 4.1
--- release date: 5 April 2015 ---
Removed Docs, Slides and Sheets to reduce ROM size
You can grab all these Gapps from the Google Play if needed.
Removed Cloudex (available in Google Play)
Fixed Facebook streaming
Removed Peel (available in Google Play)
Fixed Google Play Services location
Fixed Smart Lock
Other minor changes and fixes
Included and updated applications:
--- Data partition ---
Adobe Flash Player 11.1.115.81 (minAPI 14)
Adobe Reader 11.7.2 (minAPI 15)
Dropbox 2.4.9.00 (minAPI 15)
ES File Explorer 3.2.4.1 (minAPI 5)
Facebook 24.0.0.30.15 (minAPI 14)
Facebook 29.0.0.23.13 (minAPI 21)
Twitter 5.51.0 (minAPI 14)
--- System partition ---
GmsCore 7.0.99 (minAPI 9 -030)
GmsCore 7.0.99 (minAPI 21 -430)
Gmail 5.0.1 (minAPI 14)
Google Play 5.3.6 (minAPI 9)
SuperSU 2.45
--- Aroma installer ---
Google Hangouts 3.0.87531466 (minAPI 15)
Google Maps 8.1.0 (minAPI 15)
Google Maps 9.6.0 (minAPI 16)
Google Maps 9.6.0 (minAPI 17)
Google Maps 9.6.0 (minAPI 18)
Google Maps 9.6.0 (minAPI 18-x64)
Google Plus 5.1.0 (minAPI 15)
Google Plus 5.2.0 (minAPI 19)
Google Street 1.8.1.2 (minAPI 8)
Google YouTube 10.11.55 (minAPI 15)
Google TalkBack 3.6.0 (minAPI 8)
Google TalkBack 4.1.0 (minAPI 16)
Google Chrome 41.0.2272.96 (minAPI 14)
Google Chrome 41.0.2272.96 (minAPI 14-x64)
Google Music 5.8.1836R.1787745 (minAPI 14)
Google Keep 3.1.10 (minAPI 14)
Google Drive 2.2.083.23.35 (minAPI 14)
Google Search 1.4.1.338691 (minAPI 8)
Google Search 4.3.10.88581490 (minAPI 16)
Google Search 4.3.10.88581490 (minAPI 16-x64)
http://xda3.androidrevolution.org/db.../downloads.png
Downloads - Android Revolution | Mobile Device Technologies
Thread di riferimento
[ROM] Android Revolution HD 4.1 • High Quali… | HTC One (M9) | XDA Forums
