[ROM]&[KERNEL]LeeDrOiD One M9 V7.3.2 | April 24th | 64 Bit | KCal | Tweaks | Super!
roudly presents THE MOST FEATURE PACKED... MOST STABLE & MOST OPTIMISED ROM For your HTC One M9!
The power is in your hands, come along for the ride with one of the longest serving HTC Sense ROM developers EVER!
http://leedroid.co.uk/Images/LeeDrOiD_M9-3.jpg
LeeDrOiD Accepts no responsibility for:
Any damage to your device
Any loss of data
Lack or loss of sleep - Due to but not solely caused by ROM flashing addictions
The end of the world
Or your granny's Alzheimer's (It's a disease, it had nothing to do with me)
All of my builds are tested personally & by a number of close friends, I only develop for devices I own & use
http://leedroid.co.uk/Images/leedroid_what.png
Based On: HTC Europe 1.32.401.17 Official base
LeeDrOiD M9 Kernel - V1.0.0 (Base: himauhl-3.10.49-gf79352d / HTC Asia WWE 1.32.708.15_R1)
Android 5.0.2
HTC Sense 7
Sense 7 Themes Engine
Pure 64bit framework & system*
Rooted with the latest SuperSU thanks to @chainfire
De-odexed
Zip-aligned
init.d support
Disable error reporting
Cleaned up bloat ware
BusyBox installed
SQlite3 support
Bash and Nano shell support
External SD write permissions
Removed lots of HTC logging junk
Package Signature Checking Disabled
Clear cache at boot time
Lots of configuration changes and speed enhancements
Improved battery vs. Stock builds
Created and added Android Logo font pack (Select able in settings)
Enabled blinking LED whilst charging
Enabled flashlight shortcut in power menu
Enabled Zoe camera in camera
Enabled auto selfie feature
Enabled voice activated capture
Multi user support
Call recording support
Up to 15 quick settings items
Advanced Power Menu
Reboot, Download, Recovery, Bootloader & Safe Mode
LeeDrOiD Green % Battery (Stock in Aroma)
Tweaks short-cut in settings
Unlimited App's in folders
Recent apps kill all button
Home shortcut menu (enable and hit menu in Prism)
Improved battery stats
Ambient Display
---Aroma---
Aroma - Optional exchange mail admin hack
Aroma - Optional stock boot animation and audio
Aroma - Remove HTC App's
Aroma - Remove HTC Widget's
Aroma - Remove Google & misc apps
Aroma - Centre status-bar clock
Aroma - Big Caller Photo
Aroma - Nav Bar height 36/42
LeeDrOiD Tweaks!
Tweaks - Enable large Blinkfeed pictures
Tweaks - Prism landscape
Tweaks - Hide recent app search
Tweaks - Tap pull-down clock for world clock
Tweaks - Quick settings quick pulldown from top right corner
Tweaks - Traffic indicator
Tweaks - Traffic Indicator colour wheel selection
Tweaks - Display 4G for LTE*
Tweaks - Hide Battery options
Tweaks - Hide - Clock, GPS, Headphones, Audio profile, am/pm, Bluetooth, alarm, Power saver, NFC icon
Tweaks - Modify recent app button behaviour (press & long press)
Tweaks - Long press back
Tweaks - Show menu button
Tweaks - Hide IME button
Tweaks - Double tap status bar to sleep
Tweaks - Long press power for flashlight when screen off
Tweaks - Added SMS wake screen
Tweaks - Toggle boot audio
Tweaks - Set default app installation location
Tweaks - Use messenger from FB app (Reset on ROM flash)
Tweaks - Fast unlock (Pin & Password)
Tweaks - Allow all rotations
Tweaks - Allow dynamic Navigation Bar colour's (Material design app's only)
Tweaks - Disable SMS to MMS Conversion
Tweaks - Volume key cursor control
Tweaks - Remove caller photo mask
Tweaks - Auto record incoming & outgoing calls
Tweaks - Disable noise suppression (thanks @grgsiocl)
Tweaks - Fix Permissions*
Tweaks - Zipalign apk's*
Tweaks - mount system RO/RW*
Tweaks - Wipe battery stats
Tweaks - Wipe Cache
Tweaks - Wipe Dalvik Cache
LeeDrOiD custom build trickery
LeeDrOiD Boot animation, audio & wallpapers
System clean-up's
And lots more........
Custom LeeDrOiD Locales & Language support
Supported Languages: English, Czech, German, Espanol, French, Italian, Dutch, Polish, Russian, Norwegian, Korean, Greek, Turkish, Swedish, Danish, Portuguese, Finnish, Thai, Korean, Vietnamese, Chinese, Japanese, Portuguese, Croatian & More
Too much to list
Known Issues
None - you tell me!
http://leedroid.co.uk/Images/Leedroid_changelog.png
LeeDrOiD M9 V7.3.2
Added LeeDrOiD Kernel M9 V2.0.0
Kernel - Octacore @ boot time
Kernel - Enabled fast charge
Kernel - SeLinux permissive
Kernel - Added KCal Advanced Colour Control - Massive kudos @savoca
Added Colour Control application - Link to KCal Thread
Temporarily removed carrier support - This is now an international device only build
Disabled headphone safe volume warning
More install script clean-up's
Please make sure you have the latest HTC Hima OTA update installed prior to modifying your device
Use the latest TWRP Beta from here by @captain_throwback and pay close attention to Post 2, this will preserve the ability to restore your stock system image and receive OTA updates without the use of an RUU.
A full wipe is not necessary, although always recommended to avoid issues
First boot will take approximately 10 minutes due to Art optimization
(Your device will get rather warm, don't panic, the M9's super sleek alloy body is like 1 big heatsink)
A quick whistle stop tour of flashing a custom build
Unlock your device boot loader via > HTC Dev
Flash the above mentioned TWRP recovery image
Nandroid backup your entire stock system or previous build
Reboot your device and copy the LeeDrOiD rom. zip to your internal memory
Reboot to recovery (Power off > Hold Vol down & power > reboot to bootloader > reboot to recovery
Select the install option and locate the LeeDrOiD rom zip on your sdcard
Follow the Aroma installer & be patient
http://leedroid.co.uk/Images/Leedroid_download.png
FTP Hosting thanks to the awesome @Leefear
Please SEED and prioritise the torrent or MegaSync to reduce FTP server load
Kernel Download's
LeeDrOiD Kernel M9 - V2.0.0 (LeeDrOiD.co.uk FTP) http://click.xda-developers.com/api/...D.co.uk%20FTP)
Stock M9 Kernel (LeeDrOiD.co.uk FTP) http://click.xda-developers.com/api/...D.co.uk%20FTP)
Full ROM Download's
LeeDrOiD One M9 - v7.3.2 (MegaSync)
MD5# c374e2c9c5ae6445897d7095c2cb0df4 http://click.xda-developers.com/api/...nc)%3Cbr%3E%0A
Enjoy & welcome to the world of LeeDrOiD
