Ragazzi qualcuno ha provato queste due ROM? qual'č secondo voi la migliore?
vorrei rootare il mio one s ma sono parecchio indeciso tra queste due rom...
TrickDroid
http://forum.xda-developers.com/show....php?t=1637102
All tweaks are user configurable - YOU decide what you need and what you don`t
Mods
APM and Auto Brightness
Custom bootanimation
Dark HTC bootanimation
Extended Quick Settings and 1% stock battery
Extended Quick Settings and 1% circle battery
Extended Quick Settings and ICS Statusbar
Extended Quick Settings with tabbed UI - NEW
1% circle battery
Remove 3-dot menu
SuperSmooth Rosie and 6x5 appdrawer
SuperSmooth Rosie and standard appdrawer
SuperSmooth Rosie 6x5 and custom background
SuperSmooth Rosie and custom background
AOSP inverted apps
Google Reader Inverted
Calendar","Install Calendar AOSP Inverted
Contacts AOSP Inverted
Email AOSP Inverted
Gallery AOSP Inverted
Gmail Inverted
MMS AOSP Inverted
Google+ Inverted
Talk Inverted
Play Store Inverted
YouTube Inverted
Restore mods to stock
Restore APM + Auto Brightness
Restore stock bootanimation
Restore from EQS + 1% battery
Restore stock menu
Restore stock Rosie
Restore stock Google Reader
Restore stock Calendar
Restore stock Gmail
Restore stock Google+
Restore stock Talk
Restore Play Store
Restore YouTube
Remove Stuff
Remove Stock app and widget
Remove HTCs PPV service
Remove Flickr support
Remove the boot sound
Remove HTC Sense including its Widgets and use Nova launcher
Remove Facebook
Remove Gmail
Remove Twitter
Remove Books
Remove printer services
Remove HTC Skins
Remove Genie Widget
Remove HTC Feedback
Remove HTC Store
Remove Movie Editor
Remove Google+
Remove Show Me
Remove Teeter
Remove TuneIn
Remove AOSP Email
Remove AOSP Gallery
Remove AOSP Contacts
Remove AOSP MMS
Remove Talk
Remove 7Digital - NEW
Remove SoundHound - NEW
Remove MyHTC - NEW
Remove HTC Skins - NEW
Remove Live Wallpaper - NEW
LeeDrOiD One Supreme
http://forum.xda-developers.com/show....php?t=1658158
What you get
Based on HTC_Europe_1.78.401.2 RUU Android 4.0.3 ICS
LeeDrOiD Tweaks V1.4 (Based on LeeDrOiD Tweaks source by j4n87)
Deodexed, Recompressed & Zipaligned
Rooted with the latest Superuser & binary from Chainfire
Persistent ADB enabled
init.d runparts support
Busybox, bash & nano
Sysrw & Sysro binaries
Memory (RAM) App/Service Priority adjustments
Heavily tuned & Optimized
Multilingual - Full WWE locales list
Aroma installer touch UI (Options list below)
Advanced power menu (Thanks to J4n87) > Original thread <
Enhanced I/O performance
Ensured Journalism is disabled
Partition mount tuneups
EXT4 filesystem tuneups
SQlite 3 DB vacum on boot
App cached cleaned on boot
Applications zipaligned on boot
Faster application loading times
Lots of bloat removed
System heavily cleaned
Tweaked network connectivity configurations
Fancy keyboard animations
Up to 15 tabs in the browser
Screen unlock (Spin in) Animation
Fine tuned & lowered autobrightness algorithm
Fully working HTC Sense account login/creation
Stock & battery display
Scrolling caches disabled
Overscroll animations
Sony Bravia engine
Masses of tuneups
Awsome Super LeeDrOiD SuperDroid Bootanimation & audio by me!
LeeDrOiD Wallpapers....
Aroma install options
These option will be presented whilst flashing
Full wipe / No wipe install
Stock HTC bootanimation & audio
Enhanced GPS configuration
Enable fast dormacy
Remove HTC Sense (For an AOSP look with Nova launcher))
Remove HTC Watch
Remove HTC Stocks
Disable bootsounds
Remove Flickr
Remove Gmail
Remove Facebook
Remove Twitter
Remove Books
Remove Jetcet print
Sony Bravia engine support
Custom GPS configuration by region
Available in LeeDrOiD Tweaks
Statusbar:
Center/hide clock
Choose clock color
Battery Tweaks with MIUI Battery bar!
Custom statusbar caption
Hide/re order Quick settings
Toggle CM Brightness mod
SenseUI:
Enable landscape orientation
Enable unlock animations
Enable transparent nav bar
Lockscreen:
ICS AOSP Lockscreen
Custom carrier lockscreen text
Toggle to use menu key to unlock
Volume wake toggle
Media control
Media control option: choose pause/play or skip track backwards
Unlock with menu or back buttons
Buttons:
Recent apps button toggle
3 dot ICS menu toggle
Long press home
-Recent apps
-Menu
-HTC Speak
-Custom
Misc:
Access ICS power saver settings
Fast dormancy toggle
Custom overscroll color
Volume steps config
Autobacklight brightness array
Button brightness array
MMS Screen on
Disable boot sound
APM Custom options
Advanced Tweaks:
Mount system rw/ro
Wipe cache/dalvik
Wipe Battery stats
Fix permissions
Zipalaign apks
