[KERNEL][AOSP] FUSION ULTIMATE by Klin v4.0
Fusion Ultimate Kernel for all AOSP JB Roms
Post #1 Kernel CM10
Post #2 Kernel CM9
Features:
Linux 3.0.53
synced with latest CM10 sources
CPU frequency control from 192Mhz to 1.89Ghz
voltage control (use System Tuner Lite/Pro)
SmartassV2, Interactive, Conservative, LagFree, Lionheart, BrazilianWax, InteractiveX, Intellidemand, SavagedZen, and Smartass (V1) CPU governors added
Simple IO (SIO) and V(R) scheduler added
capacitive LED lights dimmed to 2mA
lowmemorykiller and OOM fixes
enabled zRam (see FAQ for a detailed explanation of what it does)
disabled fsync
optimized and tweaked
Sweep2Wake
compiled with Linaro 4.7 toolchain
XZ kernel compression
overall good battery life and performance
much more; check the changlog or my GitHub if you want to know the specifics
DOWNLOAD Fusion Ultimate 4
Installazione per Hboot 1.09 e inferiori
1. Vedrete due cartelle, stock e overclocked, estraete la boot-xxxxxx.zip che volete.
2. Riavviate in TWRP e flashate direttamente lo zip e riavviate, flasherà la recovery la boot.img per voi
Installazione per Hboot 1.13 e superiori
1. Vedrete due cartelle, stock e overclocked, estraete la boot-xxxxxx.zip che volete e copiatela nella sd e flashate.
2. copiate la boot.img nella cartella dove avete adb e digitate:
codice:
adb reboot bootloader
fastboot flash boot boot.img
fastboot erase cache
fastboot reboot
Altrimenti usate l'app FLASH IMAGE GUI (CONSIGLIATO) estraendo lo zip boot-xxxxxxx.zip a seconda se lo volete stock o con overclock, mettendolo nella sd e cercatelo con l'app
