intervigil,
xkonni
CM-Team (for CyanogenMod)
Team-Win (for HTC-Dumlock)
Amarullz (for his Aroma-Installer)
xHausx (for his S-On Kernel Installer)
ock (for his AlphaBlue Theme, and the permission to use his Theme, as a base for my modded theme)
acquariusoft (for the UpdateMe App)
dc211 (for Radios)
yzoni (for Radios)
Kurosoul (for the VF-UK 1.08es-Radio)
Korumera (Big thanks for his Filehosting @XDA File Server)
TweetyPeety (for Custom-Android.de and Filehosting @Custom-Android-Fileserver)
jrummy16 (for the Root-Browser App)
owain94 (for the Code of my first Source-Code changes)
...Awesome... (for his AwesomeBeats app)
Based on my Unoffical CM10.1 Build
Customizable installation with AROMA Installer
Aroma Installer with english or german language
Aroma Installer option to customize the installed Dark Jelly S Edition
Full-/Non-Wipe option in AROMA Installer
Preinstalled HTCDumlock
Selectable Baseband/Radio
Preinstalled gapps
Selectable bootanimationen (Galaxy Nexus , CM7 oder CM10)
Backup-Function, (Ringtones, Notificationtones, Alarmtones, Bootanimation)
Ubuntu- or Roboto-Font
Clock Position Option
Dark Jelly S Edition Changelog
Build-Version at "about phone"
The superuser App can be choosen in Aroma Installer, (SuperUser or SuperSu)
OTA Dark Jelly S Edition Updates (with UpdateMe App)
Deleted CM-Updater
Included AwesomeBeats, (Big Thanks to ...Awesome...)
AlphaBlueMod-Theme, (original AlphaBlue Theme by ock)
Holo (Dark) Theme for Calendar,Email, Mms/Sms and Contacts/People, (AlphaBlueMod-Theme)
AOKP Weather-Icons for LockClock, (Chronus), instead of the white CM ones
Added 3 battery icons, (System settings -> System -> Status bar -> Battery status style)
Percentage-Battery-Mod
Additional Apps (uninstallable)
System-Apps are (un-)installable via Aroma-Installer
CM/Android Videos are (un-)installable via Aroma-Installer
- Scaricare il file della Rom e salvarlo nel sd del telefono.
- Andare in recovery
- Flash dello zip della rom
- Nel menu di Aroma installer scegliere "install rom"
- Scegliere le opzioni desiderate ( quali app mettere o meno durante l'installazione )
- Scegliere full wipe
- Riavviare il sistema
Nota: le gapps sono già contenute nella rom
Non c'è bisogno di flashare la boot.img ( non ho potuto verificare personalmente questa opzione perchè ho Hboot 1.06, ma su Xda confermano sia così )
Attenzione che queste ultime versioni su base CyanogenMode hanno problemi con la fotocamera.
Su Xda indicano di copiarsi il file /system/lib/libDxOAF.so da una rom su base CM 10(.1) in modo da poterlo ripristinare ( con tutti i permessi di root rw, r, r, 0644 ) una volta installata la nuova rom.
Paolo
11-02-13, 13:36
maestropaolino
Riservato 2
11-02-13, 13:46
Foff
Come va questa rom?? Sono molto tentato...
PS. se riesci aggiungi anche il link alle Gaps invertite, tipo come nel thread alla dark jelly 4.1.2
11-02-13, 13:56
maestropaolino
La sto provando da quasi una settimana ed è molto stabile e veloce.
Arrivo dalla BAKED 7 anch'essa basata culla CM 10.1 quindi sono rom molto simili, entrambe temate scure, come piace a me.
Ho apprezzato in questa Dark Jelly S il fatto di poter scegliere quale radio utilizzare ( quella europea nel mio caso ) e non so se abbia influito o meno ma mi sembra che il segnale sia più stabile. Nella Baked ogni tanto si perdeva e dovevo passare dalla modalità aereo per ripristinare la connessione.
Sulla batteria, come sempre, sono decisamente poco attendibile perchè tengo molto il cellulare sotto carica per cui non riesco a rendermi conto dell'efficacia della rom in termini di autonomia.
Se servono screenshot chiedete che aggiungo.
Paolo
11-02-13, 13:58
maestropaolino
Originariamente inviato da Foff
Il problema delle gapps invertite è che non capisco mai quali siano quelle giuste.
Vado sempre a tentativi: provo le inverted, poi le JustunBean che per esempio nell'ultima versione mi danno problemi con i contatti.
Comunque adesso cerco il link e lo inserisco.
Paolo
11-02-13, 15:56
Foff
Ottimo! e il wifi come ti va?? A me la dark jell CM10 (ma anche altre rom CM10) mi dava problemi da questo punto di vista....
11-02-13, 16:14
maestropaolino
R: [ROM][S4][AOSP] Dark Jelly S Edition [ JB 4.2.1 ]
Per il momento non ho riscontrato problemi. Tutto liscio.
Paolo
Inviato dal mio One S con Tapatalk 2
11-02-13, 20:28
Richtc
Come va la batteria di questa?
Io con la aokp sono arrivato qui..sempre collegato al wifi
Updated to the latest CM-Source
Based on my Unoffical CM10.1 Build 10.1
Aroma-Installer: Fixed AlphaBlueModLight-Theme installation
Aroma-Installer: Changed preselection of CM-Videos to "don`t install"
Fixed Torch Power Widget
Expanded Statusbar: Fixed clock shortcut
Calendar, (Update): Added more theming possibilities for Theme-Chooser Themes
AlphaBlueMod-Theme, (Calendar): Changed some colors, to get closer to the original Holo (Dark) Theme in Android
Theme-Chooser: Added device and Rom specific preview pic
AlphaBlueMod(Light)-Theme: Added theme, device and Rom specific preview pics
(texts on preview pics is only on previews)
AlphaBlueMod(Light)-Theme: Fixed missing assets error, (hopefully)
Updated GoogleMusic
Paolo
p.s. aggiornato il link in prima pagina
15-02-13, 13:30
marik2292
Commento anche io perché è da molto che provo questa rom, anche se la versione 10.1 non la ho ancora testata, è una buona rom sopratutto per il tema scuro che si addice e anche perchè da la possibilità di avere l'ultima radio. Però il fatto negativo riguarda la fluidità in quanto ho notato che ha qualche difetto grafico che mi crea una riga di squadrettamento sul terminale ogni volta cha cambio pagina sulla home che sul drawer.
15-02-13, 18:31
Foff
Originariamente inviato da marik2292
Fai così:
1) Prima di tutto abilita le Opzioni sviluppatore se non lo hai già fatto. Per farlo vai in impostazioni->Informazioni e clicca 7 volte su Numero Build.
2) Entra nelle opzioni sviluppatore e disabilita l'hw overlays, forza il gpu rendering, e forza il 4x msaa
Dovresti risolvere
Based on my Unoffical CM10.1 Build 11.1
Added "support" for S-off devices
AlphaBlueMod-Theme: Fixed Contacts/People launcher icons
Added catergories to System settings -> "About phone"
Sorted preferences, System settings -> "About phone" to the new catergories,
(General, CyanogenMod, Dark Jelly Edition, Hardware and Software)
Ora aggiorno la prima pagina.
Paolo
25-02-13, 21:42
ferdix
Fai così:
Dovresti risolvere
Ho notato anch'io questo difetto, con tutte le rom che non abbiano la Sense ed è piuttosto fastidioso. Cmq abilitando queste impostazioni sulla dark jelly S ho notato che l'effetto diminuisce, ma non è svanito del tutto. Scrollando velocemente nelle impostazioni non si nota, ma se lo faccio con il browser noto un effetto onda e un tremolio dei caratteri, che ri assestano non appena ho finito lo scroll...a cosa può essere dovuto?
Prima che me lo chiedi ti anticipo dicendo che ho anche rifatto i vari wipe :D
Based on my Unoffical CM10.1 Build 12.1
Aroma Installer: Deactivated Kernel Install Screen, if choosen "Customize Rom"
Aroma Installer: Added TMUS 1.13 Radio
System settings: About phone: Added/Changed strings for CyanogenMod/"Dark Jelly Edition" Changelog, and OTA Updates
Updated Play Store
Paolo
02-03-13, 10:38
zartas91
Originariamente inviato da ferdix
niente da fare, i glitches li fa sempre... c'è un modo per far rimanere abilitate le 3 opzioni? mi si resettano quando riavvio :((
Based on my Unoffical CM10.1 Build 15.1
Pie-Control: Added "pie sysbar icons", (to deactivate the theming)
Pie-Control: Added german tranlation
Updated RootBrowser
Updated GMail
